Fisher and Paykel
Problem for Fisher and Paykel (IWL12)
Fisher and Paykel Smartdrive 053 Hot Water filling very slowly
By greg_t_84121 on Jan 01, 2009
I've cleaned filters, switched hoses, and basically come to the conclusion that the HW solenoid is energised but clogged (I can also see discoloration compared to the cold water one).
I wanted to see if I could clean it, or replace it myself if required. I managed to remove the coil but can't see how to disconnect the valve from the mixing tank - can someone help me - it's all plastic and I don't want to start twisting, turning, bending, prying etc without knowing how it is supposed to come apart.
Thanks in advance.
Greg.
Comments:
Jan 01, 2009
- OK - I couldn't help myself. I got the solenoid free.
Unplug the washer, remove the hoses, remove the two screws that are in between the hose connections. This frees the plastic clamp, remove it. The solenoids then pop out of the mixing tank pretty easily but can't be removed all the way yet. Remove the screw in the middle of the mixing tank, remove the screw holding the large green plastic thing, gently raise the mixing tank to unseat the tank, this then gives enough room to remove the solenoid valve.
So here is my next question - poking a thin screw driver up into the valve showed the pin moved - I rinsed/soaked it with vinegar hoping this might dissolve any mineral buildup - put it all back together and unfortunately the problem had not improved. I think I'm going to order a new solenoid coil and valve but wanted to know if anyone has any bright ideas before I do.
Thanks.
Greg.
Jan 04, 2009
- Thanks RescueTech - I'll place an order (for both). You don't happen to know the Australian equivalent for the link you posted do you ?
Thanks,
Greg.
Same Problem
May 06, 2009
-   I have a similar problem but mine is with a Smartdrive 051 and its my cold water. My cold water inlet valve is just allowing a trickle of water in. The hoses are fine, the plastic filter is clean, so I wanted to change the inlet valve.
I opened up the top and tried to remove the valve after following the steps outlined in Greg's post. But I got to the stage where I had to remove the screw holding the large green plastic thing. I don't have one - what is being referred to? I have a large purple plastic thing that looks like it is a housing for electronic bits. It takes up the rest of the area next to the mixing tank. I have undone the single screw that holds this in place and it can move. But its attached to the mixing tank and the mixing tank doesn't seem to raise. I have undone the tank's screw and the plastic clamp just like in greg's post.
The mixing tank is connected to the purple plastic bit and I don't know how to disconnect this part - if I could then the mixing tank could be freed.
Can you give more instructions? I have the cold water inlet valve and am ready to change it.
-   Guest
Apr 15, 2009
-   cold water is the problem, almost no cold water coming out. -   Guest
Best Solution
posted on Jan 02, 2009
Helpful)
RescueTech
Rank: Guru
Rating: 96%, 161 votes
Hi Greg. If I may be candid here? As a technician with years of daily experience repairing appliances, I would advise you and anyone else who happens across this post to take my advice and NEVER, EVER try and "clean" or take apart a water inlet valve in order to try to save a few bucks, When it works, sure, you feel good about how you've saved some money. The problem is, sometimes tiny particles get past the diaphragm and you can end up with a major flood situation if it sticks open. I've seen this too many times and I am here to tell you that damage that can be done to a home, especially one with an up-stairs laundry room with no floor drain can run into the thousands of dollars, all because somebody wanted to save the cost of a water inlet valve.
Just replace the valve. In fact, on machines where there are separate hot and cold, if we go out on a job where one is faulty, I tell the customer we should change them both as a set.
Your question is posted under the IWL12 series, so the part number for the hot water inlet valve is a 420237P. You can get them here:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=34
I hope my candor is not taken wrong, but don't go the cheapo route here, this can turn into a HUGE mess, you can't exaggerate this point. I have seen where people dismiss this advice and end up with a caved-in celing in the room below the laundry after the solenoid sticks open and they happen to be out shopping or walking the dog as the washer keeps filling and filling and filling and... well, I think I made my point. :)
Was this helpful?
Yes
No
Popular Solutions for Fisher and Paykel
Questions and Unsolved Problems for Fisher and Paykel
Do you recommend Fisher and Paykel (IWL12)?
Answer
Answer
HI, lights 3&5 from left.are on and bleep.just as it goes onto spin.water pumps out but no... (More)
Answer
fisher & paykel smartdrive 015 stalls on rinse mode, have to press advance button , also... (More)
Answer
How do you replace the motherboard on a Fisher Paykel drawer type dishwasher?
Answer
Bottom vanes turn; spindle does not. Other functions (wash, drain, rinse & spin) okay.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fisher and Paykel :
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
