Question about Aiwa AV-S17 Receiver
Power on problem
Hey guys, my receiver seems to work great once it powers up, but getting it to turn on can be a problem. For a couple years it's had some kind of issue where if I unplug the unit and it completely powers down, it really has problems turning back on. When plugged back in, the red light by the letters "ECO" will be on, but when I press the power button the speakers make a deep pop sound, the red light goes off, and then a second later the red light comes back on and the unit has not powered up. I used to be able to get it to turn on after hitting the power button several times, but now this doesn't seem to work. Is the unit toast or is there anything I can do? Thanks!
  • 1 more comment
  • pjor Jan 09, 2008
    I moved my system and when I went to plug it in it did the same thing as described...............anyone know what to do ??
  • amosbanjo Jun 02, 2008
    Same symptoms exactly. The "reset" procedure in the owner;s manual no longer works. If I turn off the speaker select buttons, the pop every 2 seconds stops and the ECO light stays on. No power up.
    rlh
  • jerry5usa Oct 13, 2008
    same problem here. no power to the display either. DOA? help?
Well this helped me find the relay but I found that after i pulled it off the board that it has some corosion around the metal prongs that hold it to the board. Could not get the relay open to do what is posted above , tryed opening it several times. Not sure if you are supposed to open it but could someone let me know. I am scraping around the prongs to get the corosion off hoping it will help but might just replace it alltogether. Further info on how to open the relay to do what is posted would help, I would appreciate any help, plzzzzz! :)
Posted on Aug 28, 2008
Left channel does not work
Posted on Sep 14, 2008
I found a solution at the following link:
http://geeksquad.fixya.com/support/t146684-power_problem
or
http://geeksquad.fixya.com/support/t129317-not_powering_up
OR just search on AIWA AV D57.
This guy figured out a fix on a newer model of the AIWA, but the symptoms sound the same. It's worth a try.
amosbanjo
Posted on Jun 11, 2008
  • amosbanjo Jun 13, 2008
    It worked! Be careful popping the cover off the relay so you don't injure the very fine wire on the coil windings. I suspect this relay is the ECO option. Even if the relay is blocked "on", it only disables your ECO option (no big deal). My humble opinion.
    amosbanjo
Blank screen panasonic plasma tv
Plasma screen expired how old is it how many hours function does it have ?
Nov 17, 2017 | Televison & Video
The solid red light and the glow of the screen indicated the set is on . also if set is on a red light should be emmiting from the optical out jack. Seem like you have lost audio and video. If no menu appears when pressed on remote the replace the main board. Panasonic calls this the A board.
Jan 06, 2014 | Televison & Video
Hey everyone, I have an issue with my foxtel box. The power point was turned off, and once I turned it back on, the green light on the foxtel box is on. The remote control works seems to work as I can use...
If power was lost likely a glitch in the unit, try to unplug it for a while and if no help something was damaged when power went off and came back on.
Nov 06, 2012 | Televison & Video
I have a AVR 3805 running my theater room. I'm not getting sound. How do I reset it? My sound guy did that once before and it worked. He cant get here for 2 days though... Any ideas
Turn off main power, press "direct" and "pure direct" simultaneously while turning main power on. The display starts blinking, reset is done.
Oct 31, 2009 | Denon AVR-3805 Receiver
D61w20 rca turns on and off
I have a RCA D61W20 chassis ITC222, I had the same problem and my repair guy found out the blue bulb was the main problem, along with replacing some transisters on one of the power boards, He also had to adjust the service convergence (not auto convergence). Works great now!
Aug 27, 2009 | RCA D61W20 61" Rear Projection Television
Power issue NEC PX-42VM5A
Most likely a transistor - NEC used FSM series for a while which are now discontinued. Let me know if you need info on how to find/tell which parts are bad.
Jun 22, 2009 | Emerson LC320EM8 32 in. LCD TV
Vizio HDTV totally not workinig
It sounds like a problem with the power supply. I had the same thing happen on a TV that was only a couple of years old. It did the same thing that you have mentioned. Once in a great while, it would turn on, and then we'd just leave it on because we didn't know when we would be able to get it to work again. The problem was, to buy a power supply for it we could get another TV. It just wasn't worth it.
Your flatscreen might be under warranty. I would look into that.
Jun 11, 2009 | Vizio L30WGU 30 in. HD-Ready LCD...
Will not power on
Did you use rechargeable batteries? The Garmin seems to be extremely picky about enough voltage. I had good rechargeables which I use in my foto flashlights, but they did not suffice for the Gamin. Simple non-rechargeable batteries ones solved my problem. Not good for the environment, but for my bearings...
Apr 21, 2009 | Garmin GPSMAP 176C GPS Receiver
Aspire 5100 won't turn on
try this with only the power and not the battery just to check something out
Mar 10, 2008 | Acer Aspire 5100 Notebook
JVC RX-884VBK RECEIVER
The JVC RX-884VBK is a great machine, I had it for over 5 years and had no problem at all. I came across the (NO SOUND at all) and I believe it is an easy fix. Check the Front left, there are 2 keys marked 1 and 2 for SPEAKERS output, sometimes you don't notice that you connected the speakers to 1 and the 2 key is pressed. You could have both keys pressed and you will get the sound. I hope that helps.
Nov 29, 2007 | JVC RX-884V Receiver
Aiwa AV-S17 Receiver Logo
1,206 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
