Question about Video Game Consoles & Games
When i switch my ps3 on a message appears saying that the hard drive will now be rebuilt. i press x on the controller it switches off then back on and the process starts all over again
  • 73 Answers
It means that there is a bad sector on your hd.i would recommend replacing it with a new one since it is starting to give error.there is a way to format your old hd but im afraid it will be back again to the previous problem.so its better to grab the first option.
Posted on Jan 01, 2009
Ps3 system update error
Sorry its so long but its step by step ;)
1. Download the update onto a USB stick using your pc. (Hopefully you have one). Create a new folder named UPDATE and drag the file into it. Then create a folder called PS3 and drag the 'UPDATE' folder into that. Note the folders must be in capitals.....
2. Underneath your console is a small panel near the front that pops open to reveal a small screw. Unscrew it and then remove a bigger panel on the actually front of the console to reveal the hard drive. It has a wire handle that will help you remove the hard drive. (Don't take it out yet)
3. Turn your console on and when the update loop begins take the hard drive out. After a minute or so it will realise this has happened and a error message will appear and a 60 second countdown will start. Let this time countdown and allow the console to restart. ( a post a read on a forum said that the console will restart on a screen that will allow you to download the update via USB but is did not happen for me and the system said it was unable to start because it could not detect a hard drive.)
4. Turn the console totally off and insert the hard drive. Turn it back on and as it is beginning to start carefully take the hard drive back out. Then a screen will hopefully appear that says to connect your controller to the USB wire and press the ps button. Do this and then it will give you the option to update via USB. Insert your USB drive and press start and select on your controller.
5. Then comes a step that I can't really explain and is the trial and error part of the process. When the system is searching for the USB update I inserted the hard drive. On the first try it didn't find the update and a error message appeared, but as I tried the whole process again it found the update and completely the process. I didn't lose any saves and more importantly, didn't pay a penny!!
Jul 30, 2014 | Sony Playstation 3 (PS3) Console
Ps3 system update error 8002F310
My problem is that that hard drive says it needs to be rebuilt and i press ok and it does that and then restarts and says same thing over again
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in the middle of your controller. There will be a menu with 6 options. Try 2-5. If this doesn't work, you will definitely need to replace your HARD DRIVE. This is a problem that I have faced before.When you replace your hard drive, you will need to have the latest firmware on a usb stick. Download the firmware from the playstation official website onto a usb stick. Once prompted by your system you will need to insert the usb stick into the PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Jan 21, 2011 | Sony Playstation 3 (PS3) Console
My ps3 has stopped working! It says: "Cannot start. Correct hard disk not found." Please, please, please can you help??? Many thanks, Mark & Michelle
Ouch, Bad news Mark and Michelle. This is a fatal error on the hard drive. Basically, the hard drive needs to be replaced :( Sorry
Aug 12, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 screen says " cannot start, the correct hard disk was not found." after turned on. will do nothing else. any ideas?
A long shot but it sounds like your hard drive has basically "switched off". If you have a USB sata hard drive dock I can help but its a bit of a complicated process. You need to remove the hard drive from the PS3 and plug it into the USB sata dock then connect it to your computer. Goto Control Panel -> Administrative Tools -> Computer Management -> Disk Managment. Look in the lower area of the screen that appears for your PS3 drive, probably E:, and look if it says "Not initialized". If it does, right click where it says that then click Initialize Disk. Put it back in your PS3 when it is done and hopefully it will turn back on. You will lose all saved data though as the hard drive will need to be formatted.
Hope this helps
Jul 24, 2010 | Sony Playstation 3 (PS3) Console
Yes my playstation 3 is saying hard disk needs to be rebuilt and it only says ok so i click ok another message pops up and says hard **** not found hard disk data will be deleted and lets you selesct ok or...
you could try to remove the hard drive then boot up, then put the hard drive back in and boot and see if that helps or you can try to rebuild the file system and database.
To get to ps3 recovery console to rebuild the database or the file system(neither will format the hard drive), when the ps3 is in standby mode(red light) press and hold the power button till you hear a double beep.
Most of the time the double beep comes after the ps3 beeps once then twice then turns red again when red again release and press again real fast and hold,... this time you will here a "beep" then " double beep beep" then you release and you will have the options to rebuild the database or the file system. basicly keep holding power button from standby till you here a double beep, if it shuts down try again, once you get the hang of it its easy.
if rebuild database and file system doesnt work then you may have to choose yes on the reformat option but it will wont hurt the ps3 itself just anything you have saved on it.
Sep 22, 2009 | Sony Playstation 3 (PS3) Console
Start up problems
if there is any way that you can get to your ps3's main memory, either restore your system or open up your ps3 and find its memory and take it out and put it back in.
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
Playstation needs to be rebuilt
If it keeps saying that the hard drive needs to be reformatted, then you you have a bad hard drive if it will not reformat. It's very easy to replace your hard drive. Thanks!
Oct 25, 2008 | Sony Playstation 3 (PS3) Console
Ps3 Can't start - correct hard disk not found
I do believe that it is a firmware issue and not a hard drive issue. If it where a true hard drive failure, your hard drive would be completely useless. Since this error only happens at start up i believe this is what happens.
1) PS3 starts-up and displays the "wave" and plays the "music"
2) The hard drive spins and the PS3 firmware is looking for the "files" on the hard drive for start-up
3) If the start-up files are not found in a certain amount of time, this message is displayed.
I may be wrong but this is my guess.
May 31, 2008 | Sony Playstation 3 (PS3) Console
Hard disk database
I look all over the net but could't find anything, until i found a site that said they
could show me how to fix any problem with my ps3. At first i was not so
sure about ordering the manual but i did, whats $5 plus i used paypal, but
long story short i fix my ps3, i recomend this site www.gameme.20fr.com
i hope this help you like it help me. PLAYSTATION1.gif FAN FOR LIFE! waiting on PS4
Mar 09, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
46 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
