Hello, Can you help me with my Akai MPK49? - Computers & Internet
  • Gabriel A Perez
    Gabriel A Perez May 11, 2010
    buffer 9094 error ? Are you connecting this through USB? Can you use a direct MIDI connection?
  • Dick
    Dick May 11, 2010
    Someone can help you, go ahead and post your question.
  • 69 Answers
This can help u,
Posted on Jan 01, 2009
Code for remote control akai amd05
Hello Robertas,
There are several codes listed for Akai products that I found, listed by type:
TV Codes: 1002, 1061, 1427.
HDTV Codes: 1427, 1432.
DVD Code: 2378.
VCR Codes: 3055, 3058.
Receiver/Tuner Code: 5083.
There are no codes for audio or amplifiers beyond the code for the Receiver/Tuner.
I hope that helps.
Jeff at
Apr 14, 2017 | Akai Televison & Video
Some keys on mpk49 do not play unless hit hard
sounds like dust, if you know some one with an air compresser ask them to give it a blow through, if not then it is down to caned compressed air, if that is not enough, you need to open it, and clean the contacts (DVD cleaner is cheap and good)
Aug 29, 2014 | Akai Mpk49 Mpk 49 Midi USB Keyboard With...
How to fix usb port on keyboard controller
I am assuming that you broke the connector off the pcb board? you need a soldering iron about 30W and solder and flux, to remove and short circuit after you solder them back on, using a magnifying glass to make sure none of the 5 termnials are shorted
My akai mpk49 will not turn on from the usb or the power outlet i was woundering if their was a fuse inside i might need to replace?
I'm also having the exact same problem. I have taken it apart and tested a voltmmeter on the main PCB. Got a response from most of the connections except one. I'm afraid you and I are in the same boat, in need of a replacement or a new PCB. Problem there is Akai is not the best with customer service and a replacement can run $100 .
May 14, 2010 | Audio Players & Recorders
Hello I own an mpk 49 keyboard now I'm new at this and I can't figure out if it's internal or external sound the mpk49 gives off. Long story short how do I get the sound out of the keyboard do I have to...
You could look in the manual on Page 5 for connections to external equipment...
Connect a USB cable from your computer to the MPK49. The unit will be powered through the USB connection. Alternatively, if you do not wish to use a computer in your setup or if you wish
to power the MPK49 externally, please plug in a 6V-1A DC power adapter.
2. If you would like to use an external sound module, connect a 5-pin MIDI cable from the MIDI OUT of the MPK49 to the MIDI IN of the external device.
3. If you would like to use another MIDI controller in your setup, connect a 5-pin MIDI cable from the MIDI OUT of the controller to the MIDI IN of the MPK49.
On Page 13 the first of the FAQ's is:
Question: Does the MPK49 have internal sounds?
Answer: No. The MPK49 is a MIDI-controller, which means that it does not contain any sounds inside but is instead used
to control external sound devices, such as hardware and software synthesizers, sequencers and drum machines.
If you lack the manual you can go to and download it for free after you register.
Feb 02, 2010 | Audio Players & Recorders
How do i make my mpk49 pads work with samples, in other words, when i press the pad once the loop will play or the sample will play all the way threw, but right now when i press the pad, it only plays how...
Have a look in your manual at the sections on Note Repeat and Time Division.NOTE REPEAT] – Holding this button while
striking a pad causes the pad to retrigger at a
rate based on the current Tempo and Time
Division settings. The Note Repeat feature can
be synced to an internal or external MIDI Clock
source. [NOTE REPEAT] can function as a
latching or momentary button
19. [TIME DIVISION] – This button is used to specify
the rate of the Note Repeat and Arpeggiator
features. When [TIME DIVISION] is activated,
you can press one of the 8 switches to specify a
time division. [TIME DIVISION] can function as a
momentary or toggle button.
Please note that while [TIME DIVISION] is active,
the 8 assignable buttons will not function as MIDI
CC or Program Change switches until [TIME
DIVISION] has been de-activated.
20. [ARP ON/OFF] – This button enables and The manuals and updates can be downloaded here: Please let me know if this helps.
Nov 30, 2009 | Akai Music
When i plug my akai mpk49 into my usb port it asks
me gonna hack a audition bot did not now how to hack?
May 19, 2009 | HP Computers & Internet
hello I am Jaime from Mexico, i have a 54" akai pt5492s don`t turn on, but timer on in red help me please
Sep 16, 2008 | Akai PT5492S 54" Rear Projection...
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
For PDP4294LV use:
Akai PDP4294LV Power Supply Board Replacement
For PDP4294LV1 use:
Akai PDP4294LV1 Power Supply Board Replacement
Apr 01, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
