Question about IBM ThinkPad A22m 2628 Notebook
While in BIOS command mode, turned of - not possible to start anymore
Hi, I have been working in the BIOS command mode (while starting up, I got to the selection menu, asking in which mode I want to start the OS - from there I pressed the key "c"(?) and got to a command prompt). At this stage I was detracted and left the computer - without executing any command. When I returned, the computer was shut off. There was no password or so. Now, I am no more able to start it. When I press the power button, I just get a short noise (0.5 second) from the hard disk. That's all. I have pressed the power button for 10 sec, I have removed the power plug and accu for 20 sec, nothing. Can anybody help me? Many many thanks! -marc
    New Friend:
Thanks i guess i will call netflix for help
Posted on Oct 06, 2013
  • 4 Answers
Hi Marc, Hope you doing good. Please try the following solution : 1. Disconnect the power cable. 2. Take out the battery 3. Keep holding down the power button for 60 seconds. 4. Put the battery back in. 5. Connect the power adapter 6. Make sure the Power adapter is switched on and laptop is on AC Power 7. Wait for 5 minutes and try to restart the computer 8. If it still doesn't starts. 9. Hold down the power button for 60 seconds with AC adapter and battery connected 10. Try to restart now and check. 11. If it still doesn't switch on 12. Take out the battery and run on only Ac adapter and restart. Please advise if this still doesn't helps.
Posted on Jun 12, 2007
Unlock system password
Remove system(BIOS)battery for 5 sec,it may help sometimes.
Oct 29, 2014 | Computers & Internet
How can i open a bios set up of my apple mac laptap
Macs do not have a BIOS. You can start up in verbose mode by holding Command+V on startup, and you can select various boot-up options by holding down various keys. For example, holding down 'alt' (Option) gives you a list of all the possible start up volumes.
Have a look here: http://support.apple.com/kb/ht1343 for all of these options.
Depending on what you're trying to change, it's entirely possible that you can do it through System Preferences. What is it you are trying to change?
Jan 19, 2011 | Apple Computers & Internet
My laptop screen has gone blank can you help me
hi
well it's a problem with ur BIOS so u need either to update ur BIOS if it's still work or u need to chabge it with new one
good luck
Aug 03, 2009 | Computers & Internet
Start up problem
Restart the Laptop and press F8 you will get a option that sayd repair my computer select the option,
If repair mu Computer doesn't work than go to BIOS and check if the Hard drive is detected in BIOS or not and than perform Hard drive test in BIOS there is utility which will allow to perform the test of hardwares.
If Hard drive is detected in BIOS nad Hard drive test passedthan you need to reinstall the windows.
If Hard drive test failed or it is not reflected in Windows than replaced the hard drive and install OS on new hard drive.
Thanks and Regards
Jul 05, 2009 | Compaq Presario 700 470024-192 Notebook
No programs, no buttons work, mouse works, starts but thats it
Restart and keep pressing F8 key. Select safe mode option. IF it will boot into safe mode ok then go to start->all programs->Accessories->system tools->system restore. REstore computer back to previous date.
If this will not be possible.Restart and keep pressing F8 key and select safe mode with command prompt. In command prompt window type in "chkdsk /r " this will run checkdisk and restore missing files.
Please leave your feedback if issue was solved
May 27, 2009 | Dell Inspiron B130 Notebook
Can,t get imac G5 W Tiger to Boot all the way to desktop.Turns on,I get,Taa Daa sound,then just folder w flashing question mark.?How do I access Bios?
Hi, You need a Tiger or Leopard installation disk. Then You start up the system holding down "C" instead of installing you start the "disk utillity" and repair it.
You can access singel user mode by starting up the system holding down command + S.
/Per
Mar 23, 2009 | Apple iMac G5 Desktop
Bios setup for MacBook?
Command Button(the one with the apple logo) + Option + F + 0 when it boots
Nov 12, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Dell Latitude c640 Disable BIOS memory
Just use recovery console of windows xp bootable media and use the following command.
chkdsk (to check the volume).
fixmbr
fixboot
It happens due to improper shutdown methods which has caused the system volume to corrupt the MBR.
Dec 13, 2007 | Dell Latitude D600 Notebook
Laptop start up problem
go into bios and turn off virus i assume you have xp
Oct 25, 2007 | Compaq Presario V4000 Notebook
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
IBM ThinkPad A22m 2628 Notebook Logo
148 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
