Question about LG Electronic Window Air Conditioner
Aircon makes a noise
During operation the machine makes a noise as if it could be out of balance and sounds as if a blade is making contact with something. The cold air does not come through after this happens. We switch off and wait and turn on again and it resets itself only to happen again at times. Filters have all been cleaned, machine is approximately 4 or 5 years old
  • David Robinson May 11, 2010
    Hello, What is the model number of your LG a/c?
Might be coming from the following....
1) fan motor- bearings or bushings need replacement
2) fan shroud has deformed due to age and is obstructing the fan rotation
3) motor control circuit contacts are dirty or defective hence have less voltage running thru thus an underpowered system
Posted on May 27, 2009
Why Electrolux front load making knocking sounds during spin cycle. Model ewf1087
Good Morning Friend,
I understand your Electrolux washer, model# EWF1087, is making knocking sounds during the spin cycle. In researching your model number, I show that your appliance was manufactured in Australia. If this were manufactured in the U.S., I would suggest making sure that the load was balanced. Balance your wash load and if you are still having trouble, I suggest contacting the manufacturer in Australia. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Electrolux EW1200i Front Load Washer /...
My washer makes alound grindin noise wen trying to empty
1) most Noises coming from washing machines coming during the cycles of SPIN .Clothes load can be un-balance. Stop the machine and balance the clothes.Start again, and repeat the step if necessary.
God bless you
Jun 28, 2012 | Washing Machines
There's a knocking noise coming from my dashboard on the passenger side of my car a have a 05 cavalier and it kinda sounds like it has to do with the AC or heater any know how to fix this problem?
It is probably the blower motor itself, does it change sounds or quit when operating the fan? possible debris is in fan cage, fan has a bad bearing, or a blade balancer slip on weight fell off. remove and inspect, possibly plug fan in when removed and check for operation,while fan is removed check housing compartment for debris or foreign material laying in the bottom, check fan blade for signs of rubbing contacts or broken fins
Jan 21, 2011 | 2005 Chevrolet Cavalier
When I start juicing, the machine works beautifully. By the time I am finishing the machine is making a very loud noise and the machine shakes. Any idea what is going on? The machine is less than a year...
It's going out of balance like a washing machine with the clothes
on one side during the spin cycle. I've had mine for 20 years and
have not completely mastered the balance problem. Just try to
feed produce as slowly and as evenly as you can. If it really starts
to vibrate too badly, turn it off immediately or the blade will jump
and cut the feed chute.
Jan 15, 2011 | Acme 6001 Juice Extractor
GE WSXH208A makes a lound noise during the spin
check to see if the washer is balanced (cloths are evenly placed in drum) if it sounds like banging noise
Jan 20, 2010 | Washing Machines
Washing machine drum out of balance when spinning. have balanced machine and it does not vibrate or jump around. worse when on slow spin, real knocking sound
mine is also making noise during the spin cycle. Just paid $95AUD for the repairman to tell me it needs news bearings and that will be a further $300!
Oct 10, 2009 | Electrolux Washing Machines
Lawn mover will not start, was flipped over
The clicking noise may be the blade hitting the side of the mower or it was not put on properly. It needs a balance to the aluminum flywheel on top of the engine. The blade adapter and blade provide this balance for the engine to run.
Good Day.
Oct 07, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Loud Popping Sounds
If this is a heat pump system it is possible that your fan blade is hitting ice on your condenser coil.
Nov 17, 2007 | GE Zoneline AZ55H07D Air Conditioner
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
LG Electronic Window Air Conditioner Logo
170 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
