Error E000532-8001 on iRC3170
My iRC3170 shows limited functions enabled on the screen. I go into Common Settings and turn off limited functions, power off/on the machine and it displays error E000532-8001 and offers to turn on limited functions again.
The stapler does not work and the paper output is partially reatined in the output slot - not fully discharged onto the output tray.
What can I do?
  • Andrew Clarke Jan 01, 2009
    Thanks for the suggestion. The head does not move at all - if I manually move it half way across and power cycle the machine, it does not go to home position or move at all.
    Do you know how to get better access to the thing so I can check cabling etc? Which panels can I take off to check cabling/sensors/etc?
  • 168 Answers
532 means the staple head is not moving into posistion you might want to open the door and of the finisher and stick some folded up paper in the door interlock and see if the staple head is hitting something when it tries to move good luck
Posted on Jan 01, 2009
  • andzulisv Jan 03, 2009
    allmost everything pugs in the back to the main board if youtake the back cover off you should see the control board you might want to try to replug all connectors
When I turn on my Canon iRC3170 I receive an error code E0748 - 4150. What is wrong?
I have a Canon iRC3170 photocopier, when it is switched on it shows this error message E0748 - 4150. What is wrong? Thank you.
Mar 13, 2014 | Xerox DocuColor 12 Printer
Disable the Key counter on my Konica 7130
HI,
Please refer the manual by clicking on the below link.This will solve your problem.
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Oct 07, 2008 | Office Equipment & Supplies
HOW DO YOU FIX ERROR CODE E000584-0001/
Hello 24,
This code means your (stapler/sorter/finisher...call it what u wish :-) ) experienced a problem as it went thru its normal operations or diagnostics. This typically will cause you to reboot the copier and now the copier will be in "Limited Functions" mode as it tries to protect itself from further possible damage. Limited functions usually keeps the finisher from sorting or stapling. There are certain paper jam situations which can cause the copier to flip out like this so it MAY not be as bad as it sounds.I have not been given alot of detail by you so I have make assumptions. I assume you have turned the main power off at the right side of the copier toward the rear, which is necessary.After that you turned the power back on.If you have done this and your find youself in limited functions mode then press the "additional functions" button to the right of the display. Press"Common Settings".Scroll till u see limited functions and press it. It should be "ON" at this point. Select "OFF" and press OK at the lower right corner of the screen. Now exit your way out of all these screens and turn the main power switch off again.Wait a second or 2 and power up the copier.Lets hope everything fires up properly. If it was a temporary thing then you should be ok.If not you will have heard a weird sound from the finisher and if this is so you will need proffesional help. Like on site copier tech. I can't walk you through 23 years of technical troubleshooting as this problem can be very cmplex if we did not get the device to reset. I hope this helps.I wish you the best........SPINAL
Feb 15, 2011 | Canon ImageRUNNER 3235 Black and White...
Canon eos rebel xsi screen is black when taking a picture but shows picture afterwards..Menu works also so screen works but just black when trying to take a pic..
Set the shooting mode to a Creative Zone mode. Press MENU to enter the menu. Under the Setup tab, select [Live View function settings] then press SET. Select [Live View shoot] and press SET. Select [Enable] and press SET. Press MENU to exit the menu. Press SET. The image should now appear on the LCD instead of through the viewfinder.
Refer to "Live View Shooting," Chapter 5 in the manual for more details and the limitations of the LiveView mode.
Dec 26, 2010 | Canon EOS Rebel XSi Digital Camera
Canon Imagerunner 7200 At the bottom of the screen it says "Finisher Can Not Be Used" Also says "Ready to Copy (Function Limited)"
touch the add func key then common settings scroll till you see limited functions mode touch it then turn limited function to off then turn copier off then on
Nov 18, 2009 | Canon imageRUNNER 7200 Copier
Finisher cant be used
ok touch the add functions key then common settings scroll down till you see limited functions turn that to off then power down machine with switch on right side turn back on . Make sure nothing is in the wayof the sorter bins. if it still throws a error you have a problem with your sorter
Oct 26, 2009 | Canon imageRUNNER 5570 Copier
Finisher setting will not work
touch the additional functions key then touch custom settings scrolll till you find limited function mode touch it then turn limited function off turn copier off then on this should turn the finisher back on unless the finisher has an error
Sep 25, 2009 | Canon imageRUNNER 5000 Copier
Canon IR 7095
if you can not use the finisher and the machine says Functions limited
press additional function
press common settings and then scroll to find limited functions mode if its on press the off button press ok and turn off the machine and then back on
Jul 28, 2009 | Canon imageRUNNER 3570 Copier
Canon IR 5070 Error
542 is a code for your finisher bins not moving or hitting something as the move... you have ti turn off limited functions mode under addinional functions common settings then turn off limited functions then turn copier off then on
Jan 02, 2009 | Office Equipment & Supplies
ImageRunner 6570 Stuck on limited functions
Press the "Additional Functions" button on the control panel. Press the "copier settings" button. Then scroll through the screens to the fourth or fifth screen (I forget which but you'll find it) and you will see "limited functions" "on" and "off". Press "off", then turn the copier off and then turn it back on again. Your finisher should work now.
Jul 29, 2008 | Canon IMAGERUNNER 6570 Copier
888 people viewed this question
k24674
jasbo
jasbo
