Question about Tasco Essentials 10x50 2023BRZ Wide Angle WA Zip Focus Binoculars
Internal cleaning My binoculars are on my boat most of the summer and they have developed a fog onternally on the left side. I'd like to disassemble them to clean the inner lenses where the fog is but have only been able to get it apart so far. I've been able to remove most of the outer case but am not sure how to remove the clips that hold the optics in place inside. Can you help? Thanks!
  • Jeffrey Tipps May 08, 2007
    They dry out every winter when I bring them into the house. But the fogging remains, I assume because the condensation collected some dirt somehow and got on the optics which now need to be removed and cleaned.
I don't know about disassembling binoculars. However have you tried drying them out, either in a "dry box" or by using silica crystals?
Posted on May 07, 2007
SOURCE:
Why does the right tube on my binoculars not respond to the focus/adjustment knob?
I would not suggest any kind of repair or adjustment yourself - take to a reputable repair facility, and get an estimate, which could be quite high, as it is precision work.
Sep 29, 2016 | Optics
Left lens fogs up
Binoculars are normally purged of air and filled with Nitrogen to prevent this. Each side is done individually. It sounds like a seal has leaked and it needs to be replaced and refilled.
Nov 06, 2013 | Bausch and Lomb Elite 62-0842 (8x42)...
I have a pair of Docter 7x42B and the left lens is foggy. do they have a gas in them? How do I get them fixed?
Binoculars are normally purged of all air and filled with nitrogen to prevent fogging and mould issues. If one side fogs internally it's a sign that a seal has leaked and needs to be replaced. The manufacture or any camera repair store should be able to replace the seal and refill the chamber with nitrogen.
Oct 29, 2013 | Optics
Hi, I have fungus inside the ocular of my Zeiss Jenoptem 10x50 binoculars. How should I open the binoculars in order to clean the fungus? Thank you!
It is possible for someone to disassemble binoculars to clean etc. But if you are not experienced, there is a high chance it will be out of focus once you assemble it. The vision might even become blurry.
So I advise you to get it serviced by a professional.
Sep 02, 2011 | Zeiss Optics
I have a pair of kahles 8 x 42 binoculars that have condensation and fog internally. Can this be fixed? If so how do I go about it? Thanks. Mark.
A good service agent would help. If you are in the USA, Captains Nautical Supply in Seattle is one company that do this type of repair.
Mar 01, 2010 | Kahles Optics
Leica ? Disassemble/ Clean / Reassemble
You're best option is a pair of Canon IS binoculars. I am willing to trade you a 10x30 IS near mint in the box for the Leicas plus $100.
James (718)578-5231
Nov 01, 2009 | Leica 40256 Ultravid 8x20 Compact...
In just a little rain the outer lense fogs up bad enough that I cannot see through them at all.
This is normal enough.. Your binoculars don't have an anti-fog coating on them.
Bushnell do a spray on anti fog if you want to give it a try. Any good Bushnell stockist should be able to get it for you..
Oct 15, 2009 | Pentax DCF HR II Binocular
Bushnell Binoculars
USE ACETONE (FINGERNAIL POLISH REMOVER) PUT IT ON WITH A CLOTH..IT TAKES THE STICKY OFF BUT THE END RESULT ISN'T POLISHED. SO BE EASY WITH THE ACETONE...
Sep 07, 2008 | Oberwerk (11x70) Binocular
Tasco Essentials 10x50 2023BRZ Wide Angle WA Zip Focus Binoculars Logo
797 people viewed this question
Top Tasco Optics Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Tasco Optic Expert? Answer questions, earn points and help others
