Question about Nintendo GameCube Console
Bought a wii, can't get TV to the correct TV input selection
The TV is one we don't have an owner manual to, so we have no way of finding how to get it to the right input.W,e can get to a block situation,and then we go to the unblocked section we click menu to set it and it cuts us off and goes right back to the same screen again.Help!!!!!
  • Anonymous Feb 04, 2009
    I have a Phillips TV. Can't figure out the right input for the Wii even with the manual. I did get it working once, but haven't been able to do it again. Does it have anything to do with the cable box or the DVD player?
  • Jim Strowe May 11, 2010
    Make and model of tv is???
  • 3 Answers
Di you put in the blackthingi were you have to aim or you have to put the cables in the red white yellow or you are on the wrong input go 2 input 1 or 2
Posted on Feb 13, 2009
We are trying to set up wii-through the dvr to play on Sharp LC-PD50U-unable to get it to work.
Connect the Wii directly to the TV either using the HDMI cable or the Hi def cable(5 RCA connectors) that come with the Wii. Then select the input number on the TV to get a picture .
Dec 25, 2012 | Sharp Aquos LC-PD50U 50 in. Plasma...
How to switch tv to play games
well there should be an option on your remote labled either source or input. that allows you to change from the iputs on your tv. you need to know which input you plugged your wii into. if you select the option and match your tv input to where you plugged your wii into and you still have no pic.make sure your wii is powered on. as well make sure you plugged the cables in correctly. if your using componet cables its red green blue for video and red and white for audio. make sure the audio and video are not crossed that will cause pic distortion. and if your using composite cables makes sure its red yellow and white plugged into red yellow and white. yellow is for video and red and white are your audio. if all this is correct and still no pic. then it's either your wii or your TV.
Aug 20, 2012 | Toshiba 30HF66 30" TV
How do I program the tv to watch Wii?
You can use your remote to change the video source to the one you have your Wii plugged into on your tv.
  1. Press the Menu button on your remote
  2. Press Enter or the Right Arrow button to access the Setup menu
  3. Use the up/down arrow to select Main Input
  4. Press Enter or the Right Arrow to enter the Main Input menu and then use the Up/Down arrow to select the correct input.
  5. Press Exit to exit the menus and go back to full screen.
Note: The Input you want should be labeled where you plugged in the Wii.
The directions (with pictures) to do this are in the following link to page 25 of the manual for your tv:
http://www.fixya.com/support/p169140-zenith_e44w46lcd_44_in_rear_projection/manual-6442/page-25
Mar 03, 2011 | Zenith E44W46LCD 44" Rear Projection...
Wii powers up doesnt have a picture or sound tv screen.
    • With the yellow, white, and red AV cables that came with your system:
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs? If so,click here for complete information on doing this type of hook up.
      • If this is your first time hooking up the Wii console or have you moved it to another TV, please click here to review our step-by-step connection guide. Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
    • With the blue, green, white, and red component cables (sold separately):
      • Review our step-by-step Wii Component Cable connection guide to make sure the cables are properly inserted and that your TV is set to the proper input.
    If you have verified the connection is correct, and are still receiving a blank or black and white screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700
Dec 29, 2010 | Nintendo Wii Console
New Wii is in black and white on my Samsung tv...any suggested fix?
    What to do will depend on how you're connecting your Wii console to your TV.
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs.
      • If this is your first time hooking up the Wii console or have you moved it to another TV, Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
      • Review our step-by-step Wii Component Cable to make sure the cables are properly inserted and that your TV is set to the proper input.
Dec 26, 2010 | Nintendo Wii Console
I plugged our wii into new tv. the screen shows a black and white picture. how do i fix it?
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs... if this is your first time hooking up the Wii console or have you moved it to another TV, . Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
Just bought my wii. have it all setup, howeve i cant get it on the tv. cant find select on my remote for the tv. can you help me. thanks
Usually there is a button to change the input device. The one on my remote is titled "input". Press that button to cycle through the available input device channels until you find which one your wii is on. (of course having the wii "on" when doing this will help)
Feb 19, 2010 | Nintendo Wii Console
I have a logitech remote for my tv, just bought a wii game. Do i need to program it into my remote as i cannot get the wii to work?
Because the Wii does not have IR receivers, it is not directly compatible with the Harmony remotes. However, you can still create a "Play Wii" activity that will turn on your other devices that are needed for the activity and set them to the correct inputs. So, for example, you would still need to turn the Wii on manually, but you the "Play Wii" activity would turn the TV on, set the correct input for the Wii and activate your sound system (if separate from the TV). Hope this helps!
Feb 17, 2010 | Logitech Harmony 880 LCD Remote Control
Bush LCD tv wont allow Wii to be tuned thru AV
Hi, the av lead with the three connectors at the end make sure you have them connected correctly -
Yellow - Video
White - Left Audio
Red - Right Audio
It's a simple mistake to make , but check it.
Let me know - Anthony
Feb 10, 2010 | Televison & Video
Old Sony Triniton KV-M2 with no instructions how to tune in Wii?
HI,TV MUST HAVE A SCRAT SCOKET IN BACK?,OR THE WI WOULD WORK ON AV SETTING ON SET ,OR GO THROUGH CHANNELS WITH WI ON AND IT SHOULD WORK,THANKS
Jan 02, 2009 | Televison & Video
Nintendo GameCube Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
