Question about Carrier Heating & Cooling
Just washed permanent filter on older Carrier heater/ air in garage. (Can't find model No.) IT'S TALL. a/c coil sits on top of it. The top panel on heater has vent slits.. The bottom panel is solid and the filter is a metal washable filter that fits in bottom of lower section. When I insert lower door that pushes a button in and heater starts. 1) Having trouble getting lower and upper doors back in. 2)Filter is still slightly damp from washing it...ok to reinsert? 3) Is it necessary to cut power to heater when changing filter? I'm 70 yr old female and haven't done this before.
    Scholar:
  • 140 Answers
Hello.
A slightly damp filter is ok. The heater will dry it out. If you turn the thermostat to off it will be ok. Just keep your hands and loose clothing away from moving parts. Good luck and Happy New Year!
Posted on Jan 01, 2009
  • 700 Answers
No wehen you take the bottom panel off to get to the filteer what happens is that there is a blower door saftey switch that opens until the door is replaced correctly on the furnace so that there is no recirculation of the combustion air thru your return. the panel for the top that has the vent slits in it usually goes on after the blower door is correctly installed and secured. i commend you for changinf your filter your self but i also am affraid that you may not be able to get the panels back on correctly and the furnace not come back on. usually you have to put the bottom panel on with it appproximately 1" above the middle part of the furnace and then push it in and down to engage correctly. then the top gets put on simularly but on the upper part of the furnace then pusked in and down until it locks in place. Hope that htis helps you and have a Happy New Year.
How do I clean it?
1. remover the filter and vacume the indoor coils if they are dirty.2. after you clean the indoor coils you can take some hot soapy water and wash out the drain pan to the indoor coil and wipe any slime from the pan if possible.
3. the ourside coil can be vacumed as well . shut down the power to the unit before you proceed. You can also wash the coils with water being careful not ot get the whole thing wet but just the coils.check the air flow and wash against the direction of the air flow.
The most inportant thing you can do is keep you filters serviced. I know this is often difficult to understand but a little dirty filter is better then a clean filter.. So if it just a bit dirty it fine Ceck it monthly and if possible use a 2 inch thick pleated filter. cost more but it is the best filter for the $.
Hope this helps .. let me know .. Jon
Aug 01, 2011 | Carrier 36KCARMS Air Conditioner
Ice has formed on the bottom of the freezer about 1/4 inch thick. Refrigerator section is hot.
Most likely the cause of your problem is a faulty defrost system. The ice is building up on the evap coil in the freezer, so the air from the fridge can't get cooled by the coil. The common failures are the defrost heater burning out, or a defective defrost timer if yours is an older model. The heater is mounted on the coil. To get access, you will need to remove the back panel in the freezer. There you will find the coil and heater. You will need to use a hair dryer to melt the ice off the coil.
Jun 30, 2011 | Kenmore Top Freezer Refrigerator
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
Older model R71-305 Rheem Electric Water Heater
the top element is in the same position where your electrical come in..it is just under the thermostat also there is a special wrench for removal of element...dont forget to turn of the power and shut off the water and release the pressure from the tank..
Jul 05, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Whistle noise from the air handler
Check the filter and change if dirty or restricted. Make sure the blower access panel is secured. Make sure the cooling coil is clean on the top (outside) and on the bottom (inside).
May 26, 2010 | Carrier 38CKC036 Air Conditioner
Carrier model #58rav070-08 flashing error code #31
I would check the back of the unit to see if any debris has accumulated then check for the filter and make sure it is clean. Look at the front of the a/c where the filter sits and see if the coil behind the filter is dirty. If so the unit needes to be cleaned. This can be done by purchasing a can of coil cleaner at the hardware store and follow the directions to clean the coil. What the system is saying is there is a blockage somewhere causing this code. Not being serviced in 4 years would be the possible cause because of the amount of debris in the air over that 4 year period. Good luck on the repair hope this helped you.
Dave
Dec 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
May 04, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Carrier Product # 38BRC042320
This unit was manufactured 1/8/00 and is a 4 1/2 system
Sep 30, 2008 | Carrier 38CKC036 Air Conditioner
Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Feb 25, 2008 | Carrier 52PQ307 Wall/Window Air...
Heating & Cooling Logo
47 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
