Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
As soon as my machine starts, I heard a rattle inleft corner
THen the f30 comes on the display.
  • dnorthwind Jan 01, 2009
    Oh my gosh, you are my hero !!!!!
    Thank-You sooo much, and Happy New Years to you...
    Sergeant:
  • 311 Answers
Hi dnorthwind unplug your washer for 5 min.while waiting remove the detergent dispenser drawer reach all the way back there and move a flaper there from side to side.put back to gether and restart
Posted on Jan 01, 2009
What does the F30 code mean?
F30 code refers to a Dispensor Motor not engaging correctly. Start you cycle and usually you will hear clicking as the motor attempts to engage.
Jan 22, 2012 | Whirlpool WFW8300SW
Showing F-30 error code
F30, indicate an electronic communication problem with the washer. Some Duet models are equipped with electronic displays that will read "F30" when this error occurs. Models without displays instead illuminate a given combination of LEDs to indicate an error. In the Duet Sport, for example, when the "Wash," "Rinse," "Spin" and "Cycle Complete" LEDs are are illuminated at the same time, an F30 error is present.
Other comments about this problem suggest "storing" detergents on the top cover. A new, full bottle of Tide caused problems for us. Cleared the top of it, problem solved.
I suggest visit and check this link: Use and Care Guide
Hope helps.
May 16, 2011 | Whirlpool Washing Machines
F30 comes up and the drain basket is empty
F30/31 - Motor Error
If this error occurs then you should try to run the programme again, but a persistent problem will need to be looked at by a professional. A F30/31 error code can indicate a fault with the carbon brushes, drive belt, motor relay or PCB. You can buy spares for your Hotpoint washing machine at many places on the 'net, simply Google for it.
Nov 09, 2010 | Washing Machines
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
Whirlpool WFW9200SQA10 Front Load Washer displays F30 code. What does F30 mean? Thanks
"F30" indicates "DISPENSER SYSTEM ERROR" When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power. 2. Check mechanical linkage from dispenser motor to the top of the dispenser. 3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU). 4. Check dispenser motor for powered rotations.
Thank you !!
Jun 20, 2010 | Whirlpool WFW9200S Front Load Washer
F35 code
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
XP7230 does not work with Claris F088 filter cartridge installed
You have the filter screwed it too far. As soon as you feel the filter seating do not screw it in any further.
Apr 30, 2009 | Krups XP7230 Compact Super Automatic...
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
F30 error code...what is this problem?
F30 is a dispenser failure code on the Duet Sport washer.
It means the dispenser motor will not go to the proper position.
Remove the top of the washer and inspect the dispenser linkage to see if it is binding up.
Post back with what you find and we will check from there.
Thanks/Mike
Nov 03, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
