Yamaha AX-930 Audio Amplifier
Hello Big Red,
I think it's the speaker protection circuit coming on and off on the second channel. I swapped speaker channels after the first channel gave up. Before it died it started to take a long time for it to click in.
  • 1,175 Answers
Do a websearch for a competent repair shop in your region or ask the stereo folks where you got the amp.
It WILL need surgery.
Posted on Jan 03, 2009
No sound coming out on any channel
I would also guess you have a flashing indicator, correct? If you do, your amplifier has DC Offset(a damaged amplifier). If this is the case, the protection circuit will not allow audio on any channel.
If you are interested in having your Yamaha repaired, please look at my website, You may contact me there. Thank you.
Jul 13, 2015 | Yamaha DSP-A1000 5-Channel Amplifier
I have a Yamaha rx-v367. The HDMI plays video from my blue Ray but no sound. Tuner, no sound. IPod, no sound. Phone was hooked up in multiple inputs. No sound. I'm stuck here. Please help.
It sounds like the Yam can switch video sources but the audio amplifier section is dead. Although I'm not familiar with this unit, simple logic tells me that unless it's a mulit-channel and/or surround sound" setting, the audio section of your Yamaha has failed. If the Yam has speaker protection mode (5-10 sec. delay when 1st turned on) it's possible that a defective speaker (or speaker wire) could be causing the protection circuit to NOT connect amp-to-speakers. Disconnect one speaker at a time (at rear connection on Yamaha) to see if audio returns.
Mar 26, 2015 | Yamaha Audio Players & Recorders
Yamaha home theatre system RXV 350 amplifier
Check it without speaker connection. If the set does not go to protection mode, check all the speakers by connecting one by one at a time and switch the set ON; to find the faulty speaker. If the set goes to protection mode even no speaker connected, check and replace damaged components at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Oct 07, 2014 | Yamaha RXV-350 Receiver
Hitachi ax-m68 no functions
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers.Check manual to see if there is a reset or the processor can be a suspect.
Jun 26, 2012 | Audio Players & Recorders
When i turn power on it came on and says protect then turn off..please help
The reason why this is happening is because the reciever is going into protection mode due to a short circuit to the amplifier. It might be a speaker that is shorted out internally or there might be some speaker wires making contact with each other at the back of the reciever or at the speaker. The first thing I would do is disconnect all the speaker wires from the back of the reciever(make sure to label them before removing so you know how they go back). After removing the speaker wires turn on the reciever and see if it goes into protection mode. If it does then there is a good possibility that the internal amplifier might have a short. If it does not go into protection mode then that is good because there is more than likely a short on one of the speaker wires or speaker itself. Now connect one set of speaker wires at a time. After you connect each one try turning on the reciever until it goes into protection mode again. When it does you will have your culprit. Then try swapping speakers with that problem wire set and see if it still does it. If it does then it could just be the wires but also switch the wires to verify that the amplifier does not have a bad channel. If swapping both the wires and the speaker swapping produces the protection mode then that channel for the amplifier will be defective. I hope I have not confused you too much.
Aug 17, 2010 | Audio Players & Recorders
Hello i was wanting to know if i could hook up my AX-596 amplifier to my Yamaha HTR-5860 reciver
I assume you want to slave it to the receiver and drive some more speakers with it.
Connect some RCA cables from whichever channel pre-outs you want on the HTR-5860 to any input on the AX-596.
Set the AX volume to something sufficiently high, run through the HTR's speaker level setup and match the AX volume to match the channels on the receiver. Then leave the AX's volume alone.
If you just want the AX to have access to program sources of the HTR, run the RCA cables to it from one of the VCR1 or 2 Out (but DO NOT select whichever one you use via the front panel). These are not affected by the HTR's volume controls.
May 07, 2010 | Yamaha AX-596 Amplifier
Protect mode
Protection circuit.
Checek the wiring of the amp and speakers, don' forget to look for shorts at the speakers. Make sure no wires are touching each other
Apr 30, 2010 | Volfenhag 1600 WATT CHROME AMP AMPLIFIER 2...
Audio thump on changing any parameter
My bet is a faulty electrolytic capacitor! Don't know which. but would look around the circuit of those stages.
May 30, 2009 | Yamaha DSP-AX1 10-Channel Amplifier
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
657 people viewed this question
