Just had a goodman heater installed but I can't find the model # or serial # on it anywhere. I have no paperwork from the manufacturer only the installer which tells nothing.
  • 61 Answers
Take the top door off the furnace and there will be a tag on either the side panel or bottom panel of the unit.
Posted on Jan 01, 2009
Goodman serial numbers
Serial numbers are visible on equipment where you see a permanently attached tag.
The tag will also give model number, motor amps, and other information.
Should say serial number or ser. no.
Jun 30, 2014 | Goodman Manufacturing Goodman R410A 14...
How to get a warenty replacement unit
First, you'll need to gather all pertinent info- including model / serial number and any paperwork indicating date of installation or purchase.
Next, go to Rheem's website. There is help there to assist you to locate your heater's model and serial number if you are unable to / unsure of where to find it. If you live in the U.S. and have the model / serial number data, you can go to the Homeowners Resource Center page and click "Water Heating Product Warranty Verification" link inside the Warranty Section. If you live in Canada, you cannot use the online verification and should call 800 263 8342 instead.
I hope this helps & good luck!
Jan 17, 2013 | Rheem Tankless Hot Water Heater...
Is there a uniform way of reading the serial numbers of all mfrs of A/Cs. Our warranty company needs to quickly establish the age of a A/C unit at the point of claim to determine how much we can authorize...
Unfortunately, no. Each manufacturer has their own coding system for serial numbers. Which to them reveals many things about the unit, regardless of the Model Number. Only Goodman can tell you that. If you live in the USA contact Goodman Residential Customer Support @ 1-877-254-4729.
I really hope this helps you. Please let me know and thanks for choosing FixYa.
Aug 11, 2011 | Goodman GMS90703BXA Heater
I was curious as to when my Rheem 40 gallon electric water heater was purchased and installed. I fear it may be on it's last legs. The serial number is RH0198BO4391. Model # is 71-40D B. It is the...
I think that your water heater was made in 1991 so it would be 20 years old. This is not uncommon for a electric heater but you are probably right about it being on it's last legs. The good news is that a electric water heater for use in a manufactured home is no different then other building types so they are not more expensive. Gas water heaters for manufactured homes cost anywhere between 150.00-200.00 more than standard. Thank you.
Jul 14, 2011 | Heating & Cooling
Is my water heater still under warranty leaking water on top of heater and out from bottom and from plate
1) If water heater is leaking, I suggest you protect yourself first.
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
2) You have to do some work to find out if tank is under warranty.
-Contact manufacturer: http://waterheatertimer.org/Water-heater-manufacturers.html
-Contact installer: If plumber installed heater, then installer backs warranty for some manufacturers. If you installed heater, then warranty is less or void
-Look at paperwork and manual that came with water heater and read about warranty coverage
-Look at markings on tank to see if tank is 6 year, 15 year etc
-Warranty is based on date of manufacture: To find date of water heater, look at serial number located on label on side of tank:
Open link below for serial number decoder by manufacturer.
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
3) If tank is older than 6 years, and tank label shows this is a 6-year tank, then tank is no longer under warranty.
If you have a lifetime tank, then warranty is in effect, so contact manufacturer.
Open following link to see troubleshoot checklist for leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Other things to consider:
-If tank rusted out after a few years and installer did not install a jumper wire between hot and cold pipes, then tank warranty will probably not cover tank.
-If tank rusted out and you have water softener, and did not inspect anode rod or maintain water heater, then you did not read manual or maintain heater, and warranty might not cover problem.
-I suggest you read water heater manual cover to cover so water heater will not start leaking.
Other useful links:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Feb 12, 2011 | Reliance Water Heaters
Is there a warranty on the Inducer draft blower assembly
Many Goodman products carry a 5 to 10 year parts warranty; however, they have to be replaced by a qualified contractor. The labor may not be included in the warranty. Your best bet is to contact your local distributor. Have your model and serial number ready when you call. They should be able to provide the installing contractor's name and offer some warranty information.
I hope you find this helpful. Good Luck!!!!
Feb 06, 2010 | Goodman GMS90703BXA Heater
Please tell me the date of manufacture for Goodman CAP3636C6AA
You will need to post the serial number. The model number does tell me that you have a painted case, three ton coil with a fixed metering device installed, and it fits a 21" furnace or air handler. The first four numbers of the serial number will give the manufacturing date.
Oct 06, 2009 | Goodman GMS90703BXA Heater
The fan seized up on mine too last week.
Some Goodman s had a ten year warranty but you had to purchase it Normally 5 year parts. You need model and serial number but they always give you the paperwork if you buy a ten yea warranty.Russ
Jul 20, 2009 | Goodman Heating & Cooling
Goodman GDS80703ANA
Yes, goodman offers a kit. However you will need a gas technician adjust the pressure for you. The whole conversion will take about an hour. The kit may cost $50 and labor is anyone's guess. Call your gas company and give then the model and serial nimber. They can order it and install it.
Nov 19, 2007 | Goodman GDS80703ANA Open Flame Mid-Size...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
