Question about Pioneer AVX-P7300DVD
Volume button where is it?
Hi i have the remote for the unit but i stil cant find the volume button can you please help me locate it
U need a remote
Posted on Jan 06, 2009
Why cant I get my volume buttons to work on my all in one remote for tv
Check the setup manual, you need to re-assign the function of the volume buttons to the selected function.
Jun 17, 2016 | Televison & Video
Rca 42pa30rq
Hi! Hope this will give hint... I understand some televisions nowadays are fully controlled using remote but there is always a standby power button for the television remote function. If the there is no power after turning on using the standby power button please check power cables, supplies and fuses. If the television has a standby power waiting the remote to act on but no response after pushing the remote's power button check the battery and its contact. Goodluck.
Mar 18, 2014 | Televison & Video
Cant use scart socket
Press the "TV/AV/PC" button to display the choice of input sources, move to the required choice (SCART in your case) using the channel up/down buttons, then press the volume + or - button to selectyour choice.
Feb 18, 2010 | Televison & Video
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
Volume buttons don't work on center unit or with remote
i know your problem it might be the carbon contact point is weak due to old, please send it to qualified technician to make some remedies.
Aug 09, 2009 | Audio Players & Recorders
Remote control setup
please follow the steps below:
TV
RED + SELECT
TV
0056
try your volume button if this works press the SELECT button to save the code. if not press TV and then try the volume again. repeat this step until the volume works. then remember to press the select button to save the code
cheers
Little Dish Fitter
Jan 07, 2009 | LG 42LC2D 42 in. LCD HDTV
W220 hearing problem!
The internal screen settings only adjust volume of ringer, the external button on side adjusts ear piece/hand set volume.
If the volume buttons do not turn up the volume of the hand set then the handset is defective
Mar 27, 2008 | Motorola Mobility W220 Cellular Phone
RE: VOLUME BUTTON POSITION ON FACE OF UNIT
if there is a knob rotate it clock wise / to the right, to increase the volume, & anti clock wise to the left, to decrease the volume.
there may be buttons with this symbol ' ^ ' or ' + ' means volume up, there may be a ' - ' or ' v ' to decrease the volume.
or this one ' > 'can also mean up & this one ' < ' can mean down.
Hope this helps?
Dec 15, 2007 | Car Audio & Video
Pioneer AVX-P7300DVD Logo
124 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
