Question about Canon imageRUNNER 1023iF Black and White Copier
Our Canon NP 1215 photostate machine often breaks gear.
Even service engineer replace the gear, it works only two to three months and six months in rare case. Here is no service available at Haridwar (Uttarakhand) in India. So we have to request frequently to Roorkee dealer who attend our complaints after a long time due to which we have to arrange the engineer at local level without considering whether it is genuine or not it doesn't matter. After all, we have to manage our work in time. Three days back we approached Mr. Ashish Jha who deals in canon items and his engineer visited our above photostate machine but no response is there since then.
Hiii we can solve this prob
we have 1215 photostate machine in best quality, iam sure it will work
so u can contact us
Posted on Apr 09, 2009
  • Canon Expert
  • 1,326 Answers
If I were you I would find another dealer on the web who can service your copier correctly. I would go back to the dealer you got the copier from. Also, it seems like they just fixed the gear and did not look further into the real problem.
Posted on Jan 02, 2009
Need service manual for canon copier np-1215
hello, you can find the canon np1215 series service manual in below link:
http://goo.gl/1sdGnj
thank you
Apr 27, 2012 | Canon Office Equipment & Supplies
I want to download technical support manual for canon np 6030 what should i do?
you can do a search online to see if there is someplace that sells the service manual for the NP6030 and purchase it from them. other than that i don't know of any other way to get a copy of it of if there is even a pdf file for the service manual for that machine. It is a analog copier and has been out of service for a long time
Jun 18, 2010 | Canon NP 6035 Copier
Requist for sugasion kyocera km-1500 toner
it is support cnon np 1215 toner
first time
you clean copier toner unite clean complite previous toner then put canon np 1215 toner print ok
May 28, 2009 | Kyocera KM-1505 Copier
Warm up problem NP 1215
all support and parts have ended for this very old copier.
Jan 12, 2009 | Canon imageRUNNER 1023iF Black and White...
Canon NP 1215 copier:
there is a drive gear, clutch or electromagnetic clutch that is either broken or dirty(slipping)
FIX
remove the back cover and manually move the image assembly back and forth on the rail
determine were the drive gear, cable or motor is connected to the scan/image assembley
See if you can observe the mechanism from the back or top of the machine by ressing th eprint button
(caution do not touch any electrical connections) you may have to trip any safety switches to get machine to come on with covers off
This drive assembly can be complicated if it is a series of cables if it is just an electromagnetic clutch with a gear it is relatively easy (may need ring clip remover or allen head (metric wrench) remove the assemby and clean it
If the assembly does not move after you have done the following the drive motor/clutch needs to be replaced( usually requires technician) YOu must be very mechanically inclined
Jan 04, 2009 | Canon imageRUNNER 1023iF Black and White...
Canon NP-1215
1-toner may be bad (moisture)
2-primary wire not charging - no contact or broken (unit with a thin wire above drum)
3-seperation unit shorting out (wires under the drum)
Sep 01, 2008 | Canon imageRUNNER 1023iF Black and White...
Canon imageRUNNER 1023iF Black and White Copier Logo
193 people viewed this question
old marine
old marine
