Question about Dacor Viper Tec Scuba Regulator
Dacor Viper regulator leaks water
When I tilt my head to the right causing the exhaust port to point up, excessive sea water enters the regulator. However keeping my head level or tilting it to the left canting the exhaust down, the regulator breathes fine.
Is there a fix for this?
  • sickaroll Apr 09, 2009
    I had the same problem, and almost no one had even heard of Dacor regs, so I couldn't get a service!
    Actually Dacor and Mares are almost part-for-part the same regs, I brought mine into a dive shop (The Great Outdoors in Dublin) and they send them off to a guy in Achill Island who does them. Came back without the problem.
    18 months on and my primary 2nd stage now hisses, it might be time for a new set from a recognised manufacturer!
A Dacor Viper is a Mares MV they are the same product. Mares bought Dacor (a highly respected manufacturer) and renamed the viper and put their name on it. Any Mares stockist should be happy to service it for you.
Posted on Oct 05, 2012
Pressure inside 2nd stage should be the same as ambient so no water should enter. Maybe should adjust to freeflow and then a nough
back until free flow just stop. careful your reg will now be very sensitive.
Another problem could be a worn exhaust valve - change a new one, see if it helps.
Good luck,
Eddie Foo (Malaysia)
Posted on May 31, 2009
My car has white smoke coming from the exhaust
he causes of white exhaust smoke can vary; however, it is common to see white exhaust smoke when first starting a car, especially on cooler days. This is generally steam caused by condensation. As the engine warms up and the condensation dissipates the white exhaust smoke (steam) is no longer seen. If excessive white exhaust smoke is present well after the engine warms up, it is necessary to have the car inspected for possible internal coolant leaks. Indicators of an internal coolant leak include billowing white exhaust smoke accompanied by a sweet odor or a low coolant reservoir level. An internal coolant leak can also contaminate the engine oil giving it a frothy, milky appearance. Even small amounts of coolant entering the combustion chamber will produce white exhaust smoke.
One of the main causes of white exhaust smoke and coolant loss is a cracked or warped cylinder head, a cracked engine block, or head gasket failure caused by overheating. A cracked head may allow coolant to leak into one or more cylinders or into the combustion chamber of the engine. Dirty coolant, a poorly maintained cooling system, a low coolant level, or a non-functioning cooling fan can cause engine overheating. In addition, engine wear can eventually cause the gaskets to lose their capacity to seal properly allowing internal coolant loss. Intake manifold gasket and head gasket failures are two of the most common sources of internal coolant loss caused by engine wear.
Never remove the radiator cap or coolant reservoir cap while the engine is hot or running as it can cause serious injury; always allow the car to cool down completely first. Checking for a low coolant level in the reservoir is the first step in determining if coolant loss is causing the white exhaust smoke. If the coolant reservoir is at the proper level but excessive white exhaust smoke is present, a cooling system pressure check is required to determine where, if any, coolant leaks are located.
Nov 17, 2016 | Cars & Trucks
I'm looking to purchase a used car. I've been doing online research and saw this webpage http://www.usedcarsmells.com . They talk about exhaust color and smells. Is it true that you could tell a lot about...
Yes this is correct, you can get important information from the colour of smoke from the exhaust:
Blue/Gray Smoke: Blue/gray exhaust smoke is an indication of oil burning in the combustion chamber. These are possible symptoms and causes:
Valve Seals: Leaking valve seals will cause blue/gray smoke at startup because oil leaks past the seals into the cylinder after the engine shuts down.
Valve Guides: Excessive clearance between the valve stem and the valve guide allows oil to leak past the gap into the cylinder.
Piston Rings: Worn or damaged piston rings will cause blow-by resulting in blue/gray smoke.
Worn Cylinder Walls: Worn cylinder walls cause blow-by resulting in blue/gray smoke.
PCV System: A stuck closed PCV valve will cause excessive crankcase pressure resulting in blue/gray smoke.
Black Smoke: Black exhaust smoke is an indication of a rich fuel condition. These are possible causes:
Fuel Injectors: A leaking or dripping fuel injector will cause a rich fuel condition.
Fuel Pressure Regulator: A stuck closed fuel pressure regulator will cause a rich fuel condition.
Fuel Return: A restricted fuel return line will cause a rich fuel condition.
White/Gray Smoke: White exhaust smoke is an indication that coolant is burning in the combustion chamber. These are possible causes:
Cylinder Head: A crack in the cylinder head (around the coolant jacket) will cause coolant to enter the combustion chamber.
Engine Block: A crack in the deck of an engine block near the coolant jacket will cause coolant to enter the combustion chamber.
Head Gasket: A damaged or blown head gasket will cause coolant to enter the combustion chamber resulting in white/gray smoke coming from the tailpipe.
Jan 17, 2015 | Cars & Trucks
My 1998 Mazda millenia Is shorting white smoke more tell pipe what could be the problem
It is common to see white exhaust smoke when first starting a car, especially on cooler days. This is generally steam caused by condensation. As the engine warms up and the condensation dissipates the white exhaust smoke (steam) is no longer seen. If excessive white exhaust smoke is present well after the engine warms up, it is necessary to have the car inspected for possible internal coolant leaks. Indicators of an internal coolant leak include billowing white exhaust smoke accompanied by a sweet odor or a low coolant reservoir level. An internal coolant leak can also contaminate the engine oil giving it a frothy, milky appearance. Even small amounts of coolant entering the combustion chamber will produce white exhaust smoke. One of the main causes of white exhaust smoke and coolant loss is a cracked or warped cylinder head, a cracked engine block, or head gasket failure caused by overheating. A cracked head may allow coolant to leak into one or more cylinders or into the combustion chamber of the engine. Dirty coolant, a poorly maintained cooling system, a low coolant level, or a non-functioning cooling fan can cause engine overheating. In addition, engine wear can eventually cause the gaskets to lose their capacity to seal properly allowing internal coolant loss. Intake manifold gasket and head gasket failures are two of the most common sources of internal coolant loss caused by engine wear.
Never remove the radiator cap or coolant reservoir cap while the engine is hot or running as it can cause serious injury; always allow the car to cool down completely first. Checking for a low coolant level in the reservoir is the first step in determining if coolant loss is causing the white exhaust smoke. If the coolant reservoir is at the proper level but excessive white exhaust smoke is present, a cooling system pressure check is required to determine where, if any, coolant leaks are located. THESE LEAKS WILL CAUSE SEVERE ENGINE DAMAGE! Have the car inspected immediately.
I
Internal coolant leaks can and will cause
Jul 30, 2014 | Cars & Trucks
Dumping coolant out of the exhaust pipe
  • coolant from exhaust indicates a blown head gasket or a cracked head on the block
May 13, 2014 | Chevrolet Cavalier Cars & Trucks
Black smoke from exhaust
Black smoke is an indication of too much fuel-running rich-in the cylinders. The air/fuel mixture is way off-too much fuel. Possible causes are cylinder misfires (runs and idles rough, a noticeable miss), leaking fuel injectors, or a failed fuel pressure regulator.
Take off the vacuum line to the regulator (on the fuel rail?)-if there is evidence of gas in the vacuum line, the regulator has failed and excess gas is being sucked into the engine through the vacuum line.
You should take a fuel pressure reading to check pressure against the specification for your car.
Also possible that the fuel metering is correct, but the air being supplied to the cylinders is lacking. A clogged air filter could cause that, but you would also experience a rough running condition. Since you didn't mention that, I would think the fuel metering is wrong-too much gas.
Apr 10, 2014 | 2006 Peugeot 604
2002 ktm 250 dirtbikes oil leak between cylinder and head by exhuast port
Hi, Anonymous to find the source of your oil leak, start at the point where you see oil and trace its path going up and forward, blowing baby powder from the palm of your hand will help in those difficult to see areas if there is too much oil present then buy a spray can of engine degreaser apply it to the affected area then rinse off with a pressure wand or garden hose, use compressed air to blow off excess water or just let it drip dry, take your bike for a 15 minute ride and check for the leak.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2002 250 EXC Case Oil Leak
Engine leaking oil through tiny cast hole under exhaust
KTM 250 SX 2005 Repair Manual
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 250 SX Owner Manual
Apr 02, 2017 | KTM SX 250 Motorcycles
E 200 2006 loosing coolant
What colour is the exhaust gasses and oil. White exhaust gasses after the engine is warm indicate water ingress. Sludgy emulsion under the oil filler cap, if excessive suggests a leak into the oil system or sump either can be caused by head gasket, crack in head or block
Feb 07, 2013 | Mercedes-Benz Cars & Trucks
How to know if I have a blown head gasket what is the symptom. 1999 Cadillac deville
The following are the most important symptoms with severity:
1. Leaking radiator.
2. Overheating and change of oil to milky appearance.
3. White smoke from exhaust
4. Coolant leaks.
5. Low of compression.
6. Coolant in cylinders.
Nov 13, 2010 | Cadillac DeVille Cars & Trucks
Who services Dacor Viper scuba regulators
Depends really where you are in the world, but most reputable scuba service centres should be able to help you.
Aug 26, 2010 | Dacor Viper Tec Scuba Regulator
Excessive Leak
Remove the plug and tilt the AC slightly downward on the outside so the water will flow outside where it is supposed to go. Thanks, Sea Breeze
Aug 29, 2009 | LG Heat cool Window Air Conditioner
Dacor Viper Tec Scuba Regulator Logo
771 people viewed this question
Top Dacor Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Dacor Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
