Gateway address? what is it?
I am not able to teast my connections it fails every test. something about a gateway address. where do i get it from?
    Scholar:
  • 80 Answers
Gateway is the ip address of your router. if you are trying to connect for internet than there will one broadbank adsl router and the ip provided for it must be entered in your gateway.e.g default ip for all router is 192.168.1.1
Posted on Jan 01, 2009
I have a samsung tv , and im setting up my INTERNET@TV , it ticks off everything but the Gateway Ping ! Please Help
If the Gateway Ping test fails, then your TV is not communicating properly with your Router or Modem.
To resolve this, follow these steps:
  1. Power off your TV, Modem, and Router.
  2. Unplug the power for your Modem and Router.
  3. Make sure the ethernet cable is securely connected to both your TV and your Router or Modem.
  4. Plug in your Modem and turn it on.
  5. Plug in your Router and turn it on.
  6. Make sure your IP Address information entered into the TV during the Network Setup matches the information from your Router or Modem.
  • If you are using an Automatic Setup (most users), skip this step.
  • If you are using a Manual Setup (advanced users), contact your network administrator to determine what the correct IP Address information is.
7. Run the Network Test again.
  • If the Gateway Ping test passes, but another test fails, click here to go back to the list of Network Tests.
  • If all tests pass, the TV is successfully connected to your network.
  • If the Gateway Ping test fails again, see below....
If the Gateway Ping test fails again, there may be a problem with your network setup. To determine if there is a problem with your network, follow these steps:
  3. Connect your ethernet cable directly to the TV and Modem.
  5. Power on the TV and run the Network Tests again.
  • If all tests pass successfully, then there is a problem with your Router setup. Contact your network administrator or router manufacturer for information on setting up your network.
  • If all tests do not pass successfully, there may be a problem with the TV. Connect another device (such as a Computer) directly to the modem.
  • If the other device connects to the internet, then the TV will require service. Click the Create online service request button below to have the TV repaired.
  • If the other device does not connect to the internet when directly connected to the modem, then there may be a problem with your modem. Contact your Internet Service Provider for help on troubleshooting your modem.
(from Samsung support)
Hope this helps. -Sa_Les_Ski
Feb 28, 2011 | Televison & Video
Gateway not pinging from dwl 3200 ap . AP=192.168.4.250/24 in the same subnet, gateway=192.168.4.1 , gateway assign also on wireless adapter , wireless adapter address also in the same subnet with right...
Remove the cables from the gateway router to the switch to leave only the uplink cable or connection to your telephone socket.
Test connectivity by plugging your laptop or computer directly in to the gateway router and test web access using an Ethernet cable.
Your laptop /computer may need to be rebooted for new ip. If ok reattach the unmanaged switch a retry by attaching the Ethernet cable to one of the ports on the switch. If ok, this limits the problem to the access point.
The main problem is that you have two layer 3 devices connected together by a layer 2 switch.
The solution would be to retain the configuration on the gateway if all ok. Change the access point to a different sub net and SSID to the gateway router.
If you can shut down the broadcasting from the gateway as all WLAN will be done through the access point.
Ensure that DHCP and DNS is switched on, on the gateway router.
All computers should be configured to use the gateway router address as this will allow the gateway to provide routing across the network.
Jun 30, 2010 | D-Link Computers & Internet
Billionton USB : Class 1 USB Bluetooth adapter
before you try any step i tell you please disable your antivirus and firewall.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Billionton Long Range Bluetooth USB...
Configuration Utility
Can you ping the router? I mean open a dos shell, type ping -tf 192.168.1.254 - what are the results? Maybe the ping fails, because you need to have your pc set to the same subnet address, to access the router on that IP. Test ping to your own gateway address first.. That will work & show you what to expect from a working ping. You get the gateway address by opening a dos shell & typing ipconfig /all - that shows the current IP address plus the gateway address. Actually, the gatway address might be the same as the router config address, unless you have a NAT function turned on.. Anyway, if you change your IP address to 192.168.1.252 - For example, you will no longer be able to access the internet, but shud be able to enter the configuration web page of the router.. Try the router default settings first. Another thing is that some routers require a direct cable called a 'crossover' cable to connect to the router or you have to go via a hub or a switch, with standard ethernet cables.. This probably looks confusing, but if it does not help, pls post your questions here.. Rgds,
Jun 24, 2008 | MSI RG54G2 Router (MS-6848-002)
PS3 can't obtain IP address through LAN switch
wonderful! that's always a good thing to hear - sometimes it is the "make sure you're power cord is plugged in" problem, eh :)
Jan 31, 2008 | Sony Playstation 3 (PS3) Console
Connecting to xbox live with speedstream 4100
force the gateway on the xbox configuration... retrieve gate from command prompt of your pc depending on the os.
Jan 28, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Connecting to xbox live with a speedstream 4100
Cannot connect second computer to my networn
I have listed several things here that you can use to find the problem. Sorry this is so long...network problems can be very tedious to find.
First check your version of Windows:
Double click on "My Computer", then click on "View System Information" to make sure you have at least Service Pack 1...or better yet....Service Pack 2.
Next check your Windows XP network settings:
Click on Start....Control Panel....Network Connections...Local Area Connection...Properties(button). Scroll down the list to find Internet Protocol(TCP/IP) and click on it to highlight it. Now click the properties button below the list. You should now be able to click the small buttons to select both of the "Obtain....automatically" choices for IP address and DNS server. Click on "OK" to close each of the windows.
Now you can test your computer to see if it is "talking" to the router: Click on Start...Run...and type "cmd" in the small box and click "OK". This will open a black command window where you tell the computer what to do. Type the command "ipconfig" and press return (enter). This will list your ip address, subnet mask, and default gateway. Make a note of the default gateway address so you can use it for the next test. If the IP address begins with 192.168...then your computer is probably communicating with the router okay. If your IP address is blank or starts with 169...then your network connection to the router may NOT be working.
The final test!!! Use the default gateway address from the last step to do a "ping" test. In the black command window...type "ping" followed by the default gateway address. For example: IF the default gateway happens to be 192.168.1.1....then type the ping command this way: ping 192.168.1.1
If the result is a list of replies from the gateway address...great!! Your network connection is working. If the ping command results in a list of "request timed out", or something else, then your network connection needs more help.
The ultimate test is to try using the Internet with your browser.
If this works, next try typing your gateway address into the brower address bar. It should connect you to the router setup page.(?)
Let me know the results of each of these tests, and I'll be happy to assist you further, if needed.
Jan 12, 2008 | Computers & Internet
Belkin router
A couple of items to check -- these will not fix the issue but may isolate the problem.
Turn all machines on before the test and do not turn off until after
On at least one wired computer that is working and maybe all wireless computers I want you to do the following
Click Start then All Programs then Accessories then Command Prompt
In the window that opens type
ipconfig /all
press enter then record all of the following for each adapter
  • adapter
  • IP address
  • Subnet Mask
  • Default Gateway
  • one or more DNS addresses
The back in the window enter the following command using the default gateway from the wired connection (your router address)
ping (default gateway)
you will either get 4 timeouts -- the connection fails or 4 messages with elapsed times generally measured in ms or milliseconds.
What you are looking for in the above
Good entries base
x.y.x match each other if subnet mask is right
u should be unique for the network
Wired IP address x.y.z.u not 0.0.0.0 may be 192.168.0.u
SubNet Mask ?.?.?.? assuming 255.255.255.0
Default Gateway x.y.z.? not 0.0.0.0 may be 192.168.0.1
DNS addresses ?.?.?.? not 0.0.0.0
where at least one is not zero.
Then wireless entries should be
SubNet Mask same as wired
Default Gateway same as wired
DNS addresses same as wired
If these are wrong there is a configuration error either in the router or wireless adapters depending on how you want your network setup.
each connected adapter wired and each wireless should also
successfully ping the default gateway or router address
If the ipconfig is right and the wired config has successful pings, then every wireless adapter that fails has a wireless config issue.
If you are willing to work through this let me know and reply with information in a comment to this issue.
You may also want to address wireless security
See this response and let me know what you want to do.
Wireless security
Dec 16, 2007 | Computers & Internet
Open Questions:
Five small tricks to achieve the best results in law assignments in Singapore Many students in Singapore are struggling with their law assignments. These assignments often cause anxiety among students, even if you consider yourself a good writer, law assignments can be mysterious. As you continue to work on law assignments, these are five little tricks to achieve the best results in law assignments in Singapore. 1. Respect the correct format- Format is a vital aspect of legal writing. Your professor probably offered some instructions for the law assignment format, so, you need to follow them to the smallest details. The outline may be frustrating as you have more to say however these boundaries are set for a goal; legal documents have to be very accurate and readable. 2. Improve your grammar- A single grammar or spelling mistake will ruin the overall impression you leave with your law assignment or document. Poor English is not a good basis for developing writing skills. You need to write clear, concise sentences in well-structured paragraphs. 3. Prepare the case for all aspects- In the most assignment of this type; your professor will look forward to you to produce a case with sound legal arguments. They will evaluate not only your writing skills however also your ability to consider different perspectives on the case you are developing. Support all claims and deal with counter arguments to demonstrate your reasoning in an authoritative manner. 4. Keep it simple- Keep this in mind; the excellent legal writing is simple. Do not suffocate the content with legal terms; apply them only when necessary. If you ask for professional business law homework assignments help online, you will notice that real experts don't try to expand their arguments with big words. 5. Recognize the time when you need law assignment assistance- When you realize that you couldn't probably accomplish the assignment with excellence, you require thinking about delegating. There are numerous law assignment writing services in Singapore that can aid you with this task; however, you require being careful with the choice you make. The field of law is so vast and broad that if we start mentioning its areas, it will not simply end. Business law assignment help from the experts of StudentsAssignmentHelp helps you learn more about the legal education. Moreover, we help learners understand the way to write their homework and do extremely well in their classes and become a successful lawyer. Our team is committed to assisting Singapore college students with different areas of law such as business, criminal, civil and employment law. Your work will leave a significant impact on your professor, and the desired grade would be easy to get. Do not hesitate to reach our tutors concerning your homework related to any of the topics mentioned above. We have a team with know-how and experience in academic projects. Our team has professionals with relevant industry experience, who are focused on assisting students with their homework. Our law assignment writers have adopted relevant law strategic frameworks and concepts to solve the law case studies and law homework. Thank You.
Feb 24, 2017 | Best Computers & Internet
Computers & Internet Logo
188 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
