Printer won't print.
My printer will not print. How do I get it to print from computer.
  • Anonymous Jan 22, 2009
    did that twice.. still doesn't work. The printer worked when first installed. After sitting for awhile, it quit working and hasn't ever since. Can't get test pattern or any test page to try to get it to work. I took the disk that came with it, reinstalled and still nothing.
  • 446 Answers
You need to install appropiate driver first corrresponding to your printer brand and model and the OS platform you ar eusing say XP or vista
Posted on Jan 01, 2009
My 9500 series Lexmark won't print, computer says its not communication
1. Check your printer to be sure your printer is listed as installed
2. If the print queue is full it can become confused and just hang up so turn off the printer to empty the queue
3. Power up the printer and send one document to print as a test
4. If the printer works, you should be back in business
Jan 20, 2013 | Office Equipment & Supplies
Won't print. Power is on, cable attached, computer says it is going to print. Says there is no 2 way communication between the printer and ?
You must firmly insert the cables that connects b/w PC and printer or buy new connector. Or, you may reinstall the driver..
Oct 20, 2012 | HP Deskjet D4360 InkJet Printer
Printer is paused all the time
Hello, sounds like your drivers are messed up, reload them to the computer or the connection cable maybe bad. If neither of these fix then the printer is bad.
Sep 05, 2012 | Canon PIXMA MX870 Wireless Office...
Pc won't accept printer via usb connection
So why won't it accept the printer? Is the printer and your operating system on the computer compatible? Did you install the printer and drivers? Are you sure the USB Port works?
Have you tried a different USB Port?
Click Start/Control Panel and look for Printers. Open it and make sure you don't have more than one instance of the printer installed. If you do, then you're confusing the computer. You can also check to see if more than one of the same printer is installed by opening a word document, then click File, then Print, and when the print window opens up click the Down Arrow on the line that shows the printer name. This will show you all other installed printers.
Mar 25, 2012 | Computers & Internet
How to put printer in print mode
Actually, it does not matter what mode your printer is on when printing from your computer. Whenever your printer detects a print job sent to it, the printer will automatically acknowledge the signal and print the file - no matter if it's on Copy, Scan or Fax Mode.
Aug 26, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
My printer won't print from computer to printer
check all cables are fixed. You are printing to printer not to a file. Printer driver is installed. Printer is not offline.
Jun 26, 2011 | Office Equipment & Supplies
My Dell V505 printer won't print documents from the computer, when I press print the printer prints a page of dash's and ticks. there is ink in the cartridges. i've disconnected the power....
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
May 09, 2011 | Dell AllinOne Multifunctional (v515w)...
Printer won 't print have turned off and b ack on can find printer but won't print
Have you tried using the other printer that is not checked? Make it your default printer if it works, and delete the other one.
If neither works, then delete both, and reinstall software.
Apr 20, 2009 | Office Equipment & Supplies
32 people viewed this question
jasbo
jasbo
