Question about Pioneer AVX-P7300DVD
I have the remote for my avx-p7300dvd but...... volume
I have installed the unit and works fine though.. i have the remote but i still dont know how to change the volume.... can anyone help?
Well, maybe u don't have the original control the original one is (CD-R11) and if u do the volume key is located on the side. (rigth side)
Posted on Jan 07, 2009
Why doesnt the volume on my remote control work?
The wrong code on the remote has been used. Though some codes will work parts of the system only the right code will operate all.
If you don't know the code for the TV, then you will have to try ALL the codes until you find one that operates all the controls.
Aug 09, 2017 | Charter Ltd Ocap-4 C4000 & S4000 4-device...
After switching off and on last night the volume and mute on stopped responding on Humax remote. IT is PVR9150T and remote RT531B. TV Remote works fine with volume. Humax remote works fine on all exce
Note that this type of device is designed to be left on at all times, so should not be switched off each night. I suspect that it has some slight corruption in the user-settings, so a factory reset may be required.
Apr 03, 2014 | Humax Televison & Video
Button to turn op the volume of Samsung Star doesn't work..
If it is in warranty you should reach the dealer and get it repaired free of cost. dont wait
Nov 08, 2009 | Samsung Star GT-S5233 Cell Phone
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
Remote wont change the volume... Zone 2 problems...?
you have to turn off zone 2 it mybe on the back of the remote unit the door after you do so the master volume will work
Aug 23, 2009 | Denon AVR-2308CI
Stops working
THEY MIGHT BE DRAWING MORE CURRENT THEN UR ALTERNATOR CAN HANDLE.TRY CONNECTING A CAPACITOR FOR THE SUBS.
Feb 01, 2008 | Bazooka EL1204 Car Subwoofer
Sylvania tv model # ssc719c
I had the same problem programming my directv remote to recognize the ssc719c. What finally worked was programming AV1 (not 'TV') with the sylvania DVD code 20821. This allowed me to turn the tv on and off and change tv channels, but wouldn't allow me to mute or change the volume. To fix this, (at least in my case) you have to program your remote to recognize the volume and mute buttons in the AV1 slide setting. I assume other (non directv) remotes similarly disable the volume and mute buttons when the remote is not in satellite or tv mode. Anyway, here are the instructions that activated the volume & mute buttons on my remote: "Depending on how you set up your remote, the VOL and
MUTE may control the volume only on your TV, regardless
of the position of the MODE switch. This remote can be set
up so that the VOL and MUTE keys work only with the
component selected by the MODE switch. To enable this
feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Now the VOL and MUTE keys will work only for the
component selected by the MODE switch position."
To sum up: if you find a code for your remote that will turn your tv on and off, but doesn't seem to do much of anything else, it's probably the right code; your remote is probably set up not to recognize volume or mute inputs in AV1 or AV2. You change that using a remote-specific code that's probably found somewhere on the remote maker's website.
Jan 31, 2008 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
1200 watt legacy amp not working right
your amp its protect by releas of [powerout]one this releys is dead you mast chenche
Apr 14, 2007 | Pyle Dryver PLAD213 Car Audio Amplifier
Volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Dec 01, 2006 | iLO 2600 Television
Jensen JR500 Remote Volume Control
Try reprogramming the codes into the TV for the volume control.
Jensen JR500 manual - If you cant get it to work using one of these codes it does not support your unit.
http://157.254.235.130/public/IBJ34500SE.pdf
or
http://157.254.235.130/public/J3_4_500_MANUAL_S_E.pdf
Hope that helps! DONT FORGET TO RATE ME on FIXYA!
Sep 04, 2006 | Jensen JR500 Remote Control
Pioneer AVX-P7300DVD Logo
225 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
