I have a tx srs575 av reciever wen i switch it on it stays for 2 secs n shuts off by itself were the red light flashes.then i tried everything which is posted on this site..bt in vain then i jst gave bang!! on the top cover it worked fine...bt it was fine fr a day then bak to same.. so i reckon its a loose connection...bt i cant find were it is?...any other suggestions?
Disconnect everything from the amp except the power cord, then power on the amp. If the receiver still shuts down, your problem is inside the case and unless you can perform electronic repair yourself you will probably need to take it in for service. If it does not shut down with nothing connected, power it off, connect one speaker or component and power on again. Repeat the process until the amp shuts down and you may have found the bad speaker or other component.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
