Question about LG LS-L1210CL Mini Split Air Conditioner
A/c remote working but system wont respond
I ahve a sanyo split system a/c K185-ys5 the remote works but the system does not respond. how can this be fixed?
    Scholar:
  • 67 Answers
Heya Allhart?
How did you check the remote? Did you check the remote via viewing it on a LCD screen? If the remote is working than you need a new receiver PCB for your air con and would contact Sanyo to see if it is under warranty or for them to get someone out to veiw.
Hope this helps
Posted on Jan 08, 2009
The remote control is working but the ac does not respond. How can I fix it. The AC starts manually. Thanks
Replace new battery and try. If still problem try with another remote of same. If problem remain same, the problem with your receiving sensor in PCB.Repair it.
Dec 19, 2010 | Sanyo Split System Air Conditioner
ERROR CODE BLINKING,THE AIR CONDITIONER DOESNT WORK
it is happening due to blower motor not giving the signal to pcb pls check their is a return signal wire in blower motor is broken or motor is defective.
Jul 20, 2010 | Sanyo Split System Air Conditioner
The air conditioner doesnt respond to the remote
this units ahve a reset boton on the roght side of the unit open the lid like if you was gonna change filters a small boton should be on the right side of the unit push it and if your unit turns on then you need to get a new remote if it doesn't then is your PC board
Jun 02, 2010 | Continental Electric CE-AC7581 Ductless...
NEED THE CODE TO PROGRAM MY SANYO GXDB REMOTE
How can I reset my Sanyo GXDB remote?
It worked at first, then the channel up down buttons were not responding. Now the entire remote isn't responding or lighting up. It's as if the whole thing is blocked.
Yes I tried new batteries etc. I just bought the tv with remoteon Saturday. Please help as the guys at sanyo are useless!!!
Dec 29, 2009 | Sanyo Televison & Video
How do i set unit for moisture removal
there would be a button nameng mode on your remote control press it untill it shows dry mode now it will remove moiture from the room as long as it works in dry mode.
Jul 09, 2009 | Sanyo 12KHS71 Split System Air Conditioner
Remote does not turn on or off the Split System Air Conditioner
take your cellphone and turn on the camera,then put the remote in front of the cell and push any button.if you see the light of the remote to the cell then the remote is ok and the problem is to the eye of the plate.its a small plate in front of the split
May 08, 2009 | Sanyo 18KS52 Air Conditioner
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
Jun 05, 2007 | LG LSC121PMA Split System Air Conditioner
LG LS-L1210CL Mini Split Air Conditioner Logo
554 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
