Question about Dynex Enhanced-G Wireless Broadband Router
Dynex Router I did what you told me to do, my problem is I want to get wifi around my house and my routers not transmitting internet.
  • hector_3_men Jan 04, 2009
    Ok...let me put it like this, my router is working fine, it's getting internet to my computer. Now, when i try to use my PSP or Wii for internet using it, I need a wep key or passcode or whatever. Fine. I made one when i got the router, now the problem is: for some apparent reason I can't reach the url of the router and adjust the settings. And even if i could, the router still dosn't transmit internet, it just stopped transmitting a couple days ago. I want to find out what is the problem but i can't do anything since my computer won't let me go to the url of the router. Hope that Helps
  • Pat Batta
    Pat Batta May 11, 2010
    What did you do? following what suggestion?
    could you be more precise?
    Sergeant:
  • 366 Answers
Please go check my tip it can help
Every configuration change on WLAN router must be done via LAN cable: connect router and PC with LAN cable
To connect with your router find gateway IP in your network connection status.
Use this IP in your browser (have Java enabled and use IE: some router refuse different browser)
as soon you get the ID + Password login page enter admin as ID and the password you created OR use default one if you didn't touch it.
You do not tell router model, if you dont have the default code look here to retrieve the manufacturer initial credential.
as soon as you are in the router config pages check if anythig changed in wlan settings: if you saved router config in your PC retrieve it OR create a new set of standard.
Of course security protocol you use (I recommand WPA-PSK with TKIP) must match with clients settings.
configure your console with same protocol and settings.
OR remove any security (not recommanded) and be sure you do not Hide your SSID to be able to see your network in your clients (use a proprietary name for your SSID)
Posted on Jan 10, 2009
How do i re-enable the wifi in my pc
You state that your wifi "router" will not connect to the internet. That is not inside your computer. The router is the cable modem or dsl modem that transmits the internet in your house. Depending on how it is setup, you may have a second device that separately sends a wireless signal out. The best thing to try first is to turn each device off for 10 seconds and then restart. Some modems have battery backups, so be sure to pull the battery if that is the case to ensure a complete power off. Then restart and see if you have your internet back. This fixes 75% of the issues in this situation.
Sep 23, 2014 | Samsung Computers & Internet
Is there a WIFI Signal Booster out there for a Westell A90-750015-07 Router/Modem?
you don't need a signal booster. Instead what you need is a WIFI signal repeater. This device basically captures your router's signal and repeat it to other devices. Basically place is somewhere between the router and your computer.
There are many out there but here's a cheap one on ebay
http://www.ebay.com/itm/like/122201090687?lpid=82&chn=ps&ul_noapp=true
Apr 12, 2017 | Westell Wirespeed Computers & Internet
My laptop is in the living room, my 2WIRE router in the bedroom. When I turn on the MAC it sometimes indicates that I am not connected to the Internet. I then have to fool around with diagnostics to try...
I would boost the signal it can only help I had the same sort of problems but my wireless router quit working properly my iPad wouldn't pick up signal so I had to replace my wireless router hope this helps Merry Christmas
Dec 09, 2017 | 2wire Wireless-G 802.11g ADSL Gateway
After connecting my Dynex DX-E402 wifi router to my desktop computer and running the Quick Setup on the router website I still cannot connect to the internet nor will my Netflix-ready DVD player connect to...
Typically wireless routers have one port labeled WAN and four additional standard network ports. The WAN port should be connected to your broadband device, typically a cable modem or DSL modem. You can configure your router with a direct connection to any of the standard ports connected to your computer. Your router must be configured to DHCP automatically with its connection to the modem through the WAN port. So to repeat, outside world to MODEM, then WAN port on router, the wired or wireless connection to your computer.
Nov 03, 2017 | Dynex DX-E402 Router
My laptop works using my Belkin router, but my desktop will not connect to the internet
hello
your notebook has WiFi, which is radio frequency internet, it transmits and receives radio signals (frequencies) . Your desktop, most likely, does not support WiFi on its own , so you need to use RG45 cable , ethernet cable to be connected from your desktop to the router.
So in other words thsi is what happens with your notebook and the router.
  1. your notebook has built in wireless adapter which translates data into a radio signal and transmits it using an antenna.
  2. A wireless router receives the signal and decodes it. The router sends the information to the Internet using a physical, wired Ethernet connection, to your modem (supplied by your Internet Service Provider)
The process also works in reverse, with the router receiving information from the Internet, translating it into a radio signal and sending it to the computer's wireless adapter.
The radios used for WiFi communication are very similar to the radios used for walkie-talkies, cell phones and other devices.
you need to connect your desktop to the router via RG45 ethernet cable.
was this helpful ?
Nov 15, 2010 | Computers & Internet
My computer is not connecting to my Dynex wireless router. I've called my locate cable subscriber and they told me that it's a router problem. I've disconnected the router several times and it shows that...
First off, verify that you can connect to your cable modem directly. After that, hook up your Dynex wireless router and reboot your cable modem. After this, directly connect your computer to the Dynex router (using a cable). If you cannot get an Internet connection, then there is some issue with your Dynex router configuration. It's possible that there might be an IP address conflict with the cable modem. It would be best to contact support for configuring the Dynex.
If you can connect to the Internet with your computer connected directly to the Dynex router, then there must be some router configuration problem affecting your ability to connect wirelessly. You'll have to check the configuration--might be a good idea to completely reset the router and start over. If that doesn't help, you should contact Dynex customer support, as each router has its own configuration specifics. Good luck.
Nov 07, 2010 | Computers & Internet
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
Can  Dynex 4 Port Router DX-E402 be used to connect internet on a notebook without using cable to notebook?? i.e. Can it be used like a wireless g router??
Unfortunately, the DX-E402 is not a wireless router, so it can not transmit its signal without a physical cable connecting the router to your computer. If you want a wireless router that can also connect to your ISP, check out the Dynex Enhanced Wireless G Router:
http://www.dynexsupport.com/product/?pid=DX-WEGRTR
Nov 28, 2008 | Dynex 4-Port Ethernet Broadband Router...
Need help with best connection type for college student in dorm
The enhaced version just give more range of signal over the normal dynex, regarding the internet provider it depends because sometimes you'll need a password and user to connect to the wireless signal. The dynex is used to connect from a cable signal (RJ-45)internet and then it will transfer the connection to wireless so it can be use from any laptop with wireless connection. So for example you DSL internet connection is a cable (RJ-45) then you connect that cable to the dynex router, then the router will automatically transmit the signal to wireless so any nearby pc can connect to it. If the laptop doesn't have wireless, then you'll have to buy a card to be able to connect to wireless signal or you could by also a (RJ-45 straight-through cable Cat 5e) to connect from one of the ports from the DYNEX to the laptop. Hope it helps.
Aug 19, 2008 | Microsoft Xbox 360 Console
Dynex Enhanced-G Wireless Broadband Router Logo
144 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
