Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Connection problem hello i have a belkin n wireless router. 1.)Connected to the router via wired is pc with a hp desktop printer connected to it.2.)connected to router via wireless 1 laptop.3.)ip address for lap top is 192.168.2.2ip address for pc is 192.168.2.3.4.)Problem 1: can not see or print from printer that is on pc from laptop.5.)problem 2: can not see shared files from pc on lap top or the shared files on lap top can not be seen from pc. 6.)question: would this be a setting problem in the router or on laptop and PC.7.)I did on the pc and lap top went to NETWORK Connections and made sure client for microsoft was checked. Also confirmed that file and printer sharing is active.ThanksGJF
  • tarponjoe Feb 06, 2009
    I have a 2007 Gateway laptop connected via a Realtek wireless router and a Gateway 2000 desktop connected to a LAN, both set up with a workgroup entitled "WORKGROUP", but am unable to share printer (connected to desktop) or files. Please help.
    Problem Solver:
  • 7 Answers
The first thing to check is that both of your computers are assigned to the same workgroup name. Right click 'my computer' and select properties. Change the workgroup name so that they are identical on both machines. You will need to reboot if you change the name one one or both of the machines.
Posted on Jan 01, 2009
I have a laptop which is hooked up to a wireless router (Belkin) and NOBODY can get my wireless kodak printer to work on this system including the tech who came out from the cable co.
How is this printer connected to your PC? If it's connected wirelessly, I would suggest connecting it through a wired connection (if is has Ethernet capability) and trying to install it again. Even if you need to relocate it near your router it may very well fix your problem. Most wireless printers have annoyingly poor wireless cards in them, resulting in problems. you would then install it as a network printer and you can access it from any PC's in range of the router.
If this not have an ethernet port, then I would try connecting it directly to a desktop PC (via USB), and you could share it with other network users. In my experience this works very reliably, with only one caveat: for print jobs to go through the connected computer has to be on.
Aug 04, 2011 | Kodak Office Equipment & Supplies
Do you have to connect the router to the computer to use it
You have to be connected via either Wired or Wireless connection to use a router. You can use wireless exclusively, wired connection is not required, but often handy for troubleshooting connectivity issues. If you are using DSL or Cable modem, the modem is connected to the uplink port of the Router, then you either connect wired via port 1, 2, 3 or 4 (they are all the same) or a wireless connection (Default settings are unsecure wireless for most routers)
Jun 30, 2011 | Belkin F5D8236-4 Router
CHANGE FROM WIRELESS TO WIRED INTERNET CONNECTION
It is possible .. just get youself an ethernet cable .. connect one end to your router and the other end to the back of the pc ( ethernet port ) .. and u will be connected via the wire.. You can disable the wireless connection from the router for that you can either call your Internet service provider or the netgear support team.
All The Best!!!
Please come back to vote, it would be a great appreciation for me and boost my determination to help so that I can keep on helping.
Zooless
May 24, 2010 | Computers & Internet
Can't get the printer to print while connected to a router
Hi! I will be glad to assist you in this issue. This is the link that will help you to fix the issue:
1. Installing the Product Software in Windows XP and Vista for a Wireless Network Connection (Using an Access Point)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01736948&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
2. Installing the Product Software in Windows XP for a Wired (Ethernet) Network Connection
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01708573&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
3. Installing the Product Software in Windows Vista for a Wired (Ethernet) Network Connection
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01710137&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
4. Wireless & Network Issues Link:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=33412&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
Oct 25, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
PC losing connections (ethernet) with Belkin router
This can be a problem with the firmware of the router, so the first thing that you can do to correct this problem is to do a firmware upgrade on the router and that should correct the problem......
Oct 17, 2009 | Belkin (F5D7231-4) Wireless Router
Wireless router - establish wired connection with desktop PC
You are right, cable connection is more secure. The steps are:
1.) Connect the PC to the router with a crossover cable.
2.) Once connected, try to see if you are in the network. If you are, then you are ready to connect to the net.
May 04, 2009 | Computers & Internet
Two PC's,no access to internet upon PC connected by Adaptor.
solution 1:Reset the new password for accessing for internet.
solution 2:check with adapter.plug out and plug in the adapter(and also antenna too )
Feb 27, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot connect to wireless printer, pc is connected to 54g direct
its a bit complicated but we can try out.find out the ip address of teh wireless router,,put it in the address bar and click entera box will com for a username and a passwrd.if u havnt chaged anything.then default username and passwrd is{Belkin
IP : 192.168.2.1
username : admin
Password : (Blank)
try this and u will see a belkin page,,search for connected devices and u will see the printer option there.in the mean time install the drivers of the wireless printers on the desktop pc,,follow the prompts on the installation very carefully,,its easy and then make ita s a default printer,thats it
Feb 07, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin N Modem Router If main PC which is ethernet wired to the modem router is swtiched off, laptops cannot access the internet. Does this mean that the PC to which the modem router is connected has to...
it will as long as the modem/router is connected to a phone line, instead of the pc, the only cable connected to the pc should be a ethernet cable; or you have the pc networking set that it connects via another pc instead of through a gateway, re run the wireless network wizard.
Sep 05, 2008 | Belkin Computers & Internet
Pc connection problems
Sounds like you are setup to use Internet Connection Sharing. don't do this. Have each computer connect to the internet via the router. If the router is wireless connect all computers wirelessly to the router that are wireless capable and any computers that are not wireless capable, connect them to the router via a cat5 cable to the cat5 ports on the router. This will solve your problem. BPCS
Dec 30, 2007 | Belkin (F5D5231-4) Router
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
145 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
