Message flashes no disc
When I try to play disc the machine flashes no disc
    President:
  • 1,990 Answers
Get a Cleaner Disk for it. It will Clean the Reading Lens and Should Help with this Problem. Also, Make sure that the Disks that you are trying to Play are Completely Clean and no Smudges or Fingerprints.
Posted on Jan 01, 2009
Yes when I try to open the Xbox 360 disc tray the power button in the center flashes as if the disc tray is opening, but doesnt open. it flashes even when i havnt pressed a button for it to open the d
Try turning off the 360 then turning the xbox on its side, turn the machine back on holding the eject button and the power button together for about 30 secs then the machine should function normally
Jun 19, 2014 | Microsoft Xbox 360 Console
No disc message
1 - Try a different disc.
Either works, or not.
If works, problem original non-playng disc.
If not working, problem is player (or another faulty disc).
2. If player is problem:
Try using a 'head-cleaner' disc (from store).
These usually play whilst cleaning.
If no play - problem is 'read head' in player.
If it plays, then try ( a known good - works in another machine), disc.
3. If 'read head' is faulty, you need a techy to replace, or throw it away, buy a new one (more likely).
Rafe
'Live long and prosper'
Sep 07, 2013 | Craig CVD327 DVD Player
After trying to load disc, message says "cannot play disc" , the machine was previously playing the same disc without issue.
Its time to service ur player. If it reads some discs and some it doesn't read, then switch it off for 10 minutes, let it be on cool mode. Turn it on, try diff discs. If still same, then you may take it to any local tech store for a service.
Jan 17, 2010 | Sony Televison & Video
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Dvd disc not playing
Buy a cleaning disc for about $15.00. If that doesn't work it's time to buy a new one.
Mar 16, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Won't Play Games, DVD and CD fine
I am guessing that when it was refurbished, it was because of a disc drive error... so i am about 90% sure that they didn't flash the disc drive and that would be their mistake. Disc Drives have their own memory and would still be able to play cd's and dvd's without problems... but if they are not flashed correctly through a sata computer with the correct hardware, they will not play games. My opinion is that you should contact the place which you bought it from, it's not your fault.
Dec 26, 2008 | Microsoft Xbox 360 Console
ERROR MESSAGE:
If these disks have not been finialized then they will not play on the dvd player. Turn your computer on and see if they will play. If they will then you will need to the dvd palyer finialize them. I hope this helps you. If not get back to me and then we can try a different way.
Aug 15, 2008 | Hitachi 168589 DVD Player/VCR
Keeps flashing "Bad disc".....
Try playing a CD instead of a DVD, if the audio CD plays normally that means that the laser on the DVD side is defective. This devices come with 2 laser picks, one for CD and the other one for DVDs.
Apr 04, 2008 | GoVideo DV2150 DVD Player/VCR
Disc will not play or record message disc empty disk full
did you try a dvd movie do they play if so buy a different brand of blank dvd this happened to me i use
dvdr= sony ok
retail plus ok wal-mart brand
imation ok
at&t nogood on the rca machine
dvdrw= dataware ok
imation ok
cdr =tdk ok
these are all the brands a know are working on rca machines!
but keep in mind you can buy the most expensive blanks and they may or may not work on different machines
Dec 04, 2007 | RCA DRC8052N DVD Recorder
Stuck minidisc
Turn the power off and back on at the mains. With the machine now in standby, press and hold the "Play Mode" and "Minidisc Play/Pause" buttons together. The machine will enter test mode and the disc should eject. Switch the power on and off again at the mains and the machine should be back to normal.
Oct 16, 2007 | Sony DHC-MD333 Shelf System
114 people viewed this question
 Grubhead
Grubhead
