Question about Texas Instruments TI-84 Plus Calculator
Vista on Core 2 Duo 64 bit with Ti 84 Calculator
I am unable to connect because of the lack of a driver. Any known fixes?
  • 1 more comment
  • omarnaji2003 Jan 21, 2009
    I have the same problem.
    I think they have a driver for 32-bit vista but not 64-bit.
  • Anonymous Jan 21, 2009
    texas instruments says that the ti-84 does not work on the 64 bit systems
  • losallstarte Jan 27, 2009
    I called TI Support and they said there is no software for Windows Vista 64-bit and any TI products.
Same problem...
Posted on Apr 06, 2010
When i turn my calculator on it says "RAM cleared". It is then very slow . . . what is wrong and how can I fix it?
Hi yeager anna,
Since the calculator operates slowly even after the RAM has been cleared, I'd say, "Your OS must be corrupt." You need to re-install the Ti 84 Plus OS, ASAP!!! You can fix this problem by installing the newest Ti 84 Plus 2.55v. MP OS, operating system. Use fresh batteries when installing the new OS. If you need additional instructions your welcome to read my Ti 84 Plus solutions. I pretty much tell how you can install the new OS with another Ti 84 Plus calculator or, connecting the computer to the calculator to install the new OS. You can view my solution to install OS by clicking, "Ti 84 Plus OS installation." Just stroll down to oneplusgh's solution at that posting and, I cover a lot of topics you may need advice on to install the new OS.
If you need instructions to downloading and installing TI Connect on a XP or, Mac computer click, "TI Connect on a XP or Mac computer." I realize this posting was for a later OS but, this link will take you to the latest TI Connect software and, newest OS too. Once you get the TI Connect software installed come back to this posting and, follow the instructions above at "Ti 84 Plus OS installation."
If you need instructions to downloading and installing TI Connect on a Windows 7 computer click, "TI Connect on a Windows 7 computer." Just follow Procedure 3. You can also get instructions at this link on how to install the Ti driver to link computer and calculator. I realize this link instructions were for a Ti 89 calculator but, they will work for a Ti 84 Plus too. Once you get the TI Connect software installed come back to this posting and, follow the instructions above at "Ti 84 Plus OS installation."
My instructions is geared to save you a lot of hardship. No matter if your having to install Ti Connect or, the newest OS for your calculator. I do not use TI OSDownloader because, TI OSDownloader might not give you the newest OS for your calculator. My instructions will. If you have any questions just post a comment and, I'll respond quickly.
Jan 20, 2011 | Texas Instruments TI-84 Plus Silver...
My TI-84 plus silver edition calculator is not responding. Whenever I press a button it takes forever to put it up on the screen or it doesn't work at all! I need some serious help with this. I tried...
Hi purzabumafu8,
You need to re-install the Ti 84 Plus OS on both calculators, ASAP!!! You can fix these problems by installing the newest Ti 84 Plus 2.55v. MP OS, operating system. Use fresh batteries.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the USB or, IO link ports. Then they can send you a copy of their OS, while you receive it on your Ti 84 Plus. Hopefully, your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work. Link the two calculator together through the USB or, IO link ports with the proper cable. If don't have another reliable calculator to connect too, you'll have to connect the calculator to a computer to download the OS, goto Procedure 5. If your downloading off another calculator goto Procedure 1.
Important Note: Never disconnect a TI Connectivity Cable during a transfer. Lost of power during installation of OS will destroy your calculator.
Procedure1. Procedure to linking to another calculator.
On their calculator press, [2nd][Link][G] [Right-Arrow]. On your calculator press, [2nd] [Link] [Right-Arrow] [Enter] and, then press [ENTER] on their calculator too. Their calculator should say, "TRANSMIT" and, your's will say "Receiving." Then on both calculators once transfer is complete press, [2nd][MODE] to quit and, return to the Home screen. If the OS was transferred then your finished with these procedures. If your calculator won't turn on or, is locked up try the Procedure 2, below.
Procedure 2.
Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". If calculator did not turn on or, is still locked up goto Procedure 3, unless already did Procedure 3, then goto Procedure 4. If you calculator does come on and is responding and, your connect to another calculator goto Procedure 1. If you calculator does come on and is responding and, your connect to a computer goto Procedure 7.
Procedure 3.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. Goto Procedure 2.
Procedure 4.
If the above process did not work. Try re-doing the Procedure 2, and, this time extend the time in Procedure 3, by 5 minutes to 10 minutes before you put all the batteries back in the calculator. These calculators can be a little stubborn at times so, keep trying Procedure 2.
Procedure 5.
If you can't find a calculator to connect too, you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS.
Procedure 6. Procedure to installing the latest Ti84 Plus 2.55v. MP OS. TI OSDownloader does not always install the latest OS.
You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed. If your calculator will not turn on or, is locked up goto Procedure 2. Or else goto Procedure 7.
Procedure 7.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install. Next, the Ti Device window should pop up and, highlight the port when it finds what your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
Jan 17, 2011 | Texas Instruments TI-84 Plus Silver...
I jus bought a TI-84. when i turned it on it said RAM cleared. now there's a blinker on the screen. every time i press a button, nothing happens. whats wrong with this brad new calculator
You need to re-install or, update the Ti 84 Plus OS. Since you just bought the calculator it is unusual that it is already to that point of clearing the RAM. You can connect a computer and your Ti 84 calculator together once you downloaded and, installed Ti Connect software on the computer. That way you can use the Ti OS Downloader that comes with Ti Connect software to install the newest Ti 84 Plus OS. Or, if you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the IO link ports and, they can send you a copy of their OS while you receive it on your Ti 84.
Get this problem fixed as quick as you can. You do not want your OS to fail any more than what it already has. If you can not find another calculator to connect too, then you can connect through your computer. You may have a long road ahead of you getting the Ti Connect software and, drivers working right. Just remember to come back to your posting here and, post a comment of what ever is failing. This will notify me right away and, I'll walk you though it if necessary.
Jan 12, 2011 | Texas Instruments TI-84 Plus Calculator
Problem with Driver
Try uninstalling and reinstalling the driver. Did you check TI's website? There might be an updated driver you can use. Also, is the calculator on when you plug it into the computer?
May 27, 2010 | Texas Instruments TI-84 Plus Calculator
Can the Dell Latitude D610 run any of the following games: Age of Conan Star Trek Online Champions Online Aion
Check your system if it meets the following requirements
Age of Conan
Required
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
RAM: 1GB RAM
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
Recommended
Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
Video Card: NVIDIA GeForce 7950GX2 or better
RAM: 2GB or more
Enhanced for: DirectX 10, 64-bit processors, multi-core
Supports Parental Controls on Windows Vista
Start Trek
System Requirements
  • OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
  • CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
  • Memory: 1GB RAM
  • Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD Graphics
  • Sound: DirectX 9.0c Compatible Soundcard
  • DirectX: Version 9.0c or Higher
  • HDD: 8GB Free Disk Space
  • Network: Internet Broadband Connection Required
  • Disc: 6X DVD-ROM
Recommended System Configuration
  • CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
  • Memory: 2GB RAM+
  • Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
  • Disc: 6X DVD-ROM
To check your system hardware> click on start>all programs>accessories>system tools> system information.
Thanks for using Fixya
proton
Mar 27, 2010 | Dell Latitude D610 Notebook
Can't find drivers for win 7 64-bit for lenovo y510
Windows 7 is a new platform and every hardware manufacture is developing the driver suits for it.Meanwhile you will have to download the drivers directly from the chip manufacturers site e.g. for sound you can download it from http://www.realtek.com.tw/downloads/.
About the chip manufacturers you can know from the Y510 page where the drivers are there for Vista or XP.
Thanks.
Dec 28, 2009 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
Ti-84 will not connect to windows because calculator does not have vista driver how do i fix this
If it is for the purpose of updating the OS or transfering apps, you can use a calculator to calculator link.
Hope it helps.
Oct 29, 2009 | Texas Instruments TI-84 Plus Silver...
Ti 84 not working
Since it gets tossed around a lot, it is possible though improbable that the batteries lose contacts with the electrical terminals.
You may try to darken the screen a bit.
1. Press [2nd] key and release it
2. Press [UpArrow] and release it.
3. Repeat steps 1 and 2 in sequence until contrast is satisfactory.
If that does not fix the problem, use a calc-to-calc cable and try sending something to it from a working calculator.
You can also download the TIConnect software from education.ti.com and install it on your computer. Then connect the calculator to the computer by means of a USB cable, a TISilverCable, or a TI Graphlink (Black cable). Turn the calculator ON, run TIConnect, connect calc-to-computer and Click TIDEVICEINFO in TIconnect main window.
If it tells you NOT FOUND, on any of the ports, click the communication settings: Set the device type to you calculator model. Set the cable type. Set the port (COM x) or USB1
If calculator is not detected through any of the available ports (COM ports, or USB), then it would suggest that calculator is in need of repairs.
Hope it helps.
Sep 26, 2009 | Texas Instruments TI-84 Plus Calculator
32 bit operating system
well in laymen terms nowadays 64 bit is newer tecnlogy and 64 bits one process 64 units of data at a time as compared to 32 bit OS.
64 bit is in core 2 Duo and later systems..
64 bit OS provide full support to the 64 bit architecture thus gaining the overall efficiency.
Sep 12, 2009 | Microsoft Windows Vista Home Premium with...
Texas Instruments TI-84 Plus Calculator Logo
1,522 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
