Question about AMD Athlon64 2800+, 1.8 GHz Athlon 64 (amdada2800axbox) Processor
CMOS error - defaults loaded.
I am using an AMD 2800+ processor and Jetway motherboard. My problem recently is when I turn on my regulator my PC boots automatically and stops with a CMOS error- defaults loaded on the screen and it resume from booting when i press F1. Can anybody helped fix my PC?
  • 3 more comments
  • Jimix Eouex
    Jimix Eouex Jan 01, 2009
    I am using Power surge protector and the model # is K8M8MSR2.
    It boots into the operating system.
    How long does a battery lasts before it needs a change?
  • Jimix Eouex
    Does changing that battery with my bare hands dos not affect the processor? (for Howardepgco)
  • Jimix Eouex
    Jimix Eouex Jan 07, 2009
    Sir. I changed a new battery but i had to reset my motherboard to fix my problem.everything now is ok. thanks a lot!
  • Tim Hallman May 11, 2010
    Also, please provide the model # of your Jetway mobo if possible.
    When you press F1 does it boot into the operating system?
    It sounds like your cmos got reset, or is resetting with each boot for some reason.  You may have to reconfigure your BIOS.
    You may need a new battery.
    Also, what do you mean by "regulator"?  Power surge protector, power strip, or power supply?
    Scholar:
  • 35 Answers
You most certainly need a new battery by the sound of it.  No, changing the battery with your hands will not affect the motherboard or cpu, but try not to touch too many parts of the motherboard while changing it, as a static shock can damage your pc components.  Before removing the battery, touch something metal (other than the pc), to discharge any static electricity you may have picked up.  Once you have the battery removed, take it to Radio Shack or the like and get a replacement.  After replacing the battery you should only be greated with cmos error screen once more, and then everything should be fine.
Posted on Jan 01, 2009
  • 341 Answers
It is possible that your CMOS battery is low or dead.It retains the memory power to the CMOS when you turn off your computer. Change it and see if you problem goes away. It's a round silver disk.They are sometimes called coin batteries because they look like a coin. They come out easy and your local Radio Shack or Batteries Plus will have them.
  • Howard Lester Jan 01, 2009
    Nope won't hurt a thing. Just touch the case do discharge the static electricity in your body. Then change it.
Hi, I have recently built my own computer with the ASUS M4A88TM motherboard and and AMD Athlon II X3 CPU and every time I load it up I get a message saying 'Bad BIOS checksum'. So I put in the CD...
This is common with some ASUS motherboards. Windows is finding bios settings it didn't expect
Try substituting the PSU first if you have a spare with a reasonable wattage, this was oddly a common problem that was cured by a new PSU suggest 550 watts
Then remove the CMOS battery, leave for a minute and replace it, try booting to factory defaults.
If no joy, disconnect all drives and try rebooting, see if this is a hardware error
Assume you checked the ram you are using is compatible with the mobo? Visit Asus site to check
In the bios, check the voltage from the rails
12 volt
5 volt
3.3 volt
if any are down below 10% of the above, looking like the PSu
Jan 09, 2011 | ASUS M4A88TM Motherboard and AMD...
How to download jetway lan driver
Go to the site of the manufacturer...
Jun 25, 2010 | AMD Sempron 2800, 2.0 GHz 2800+...
WHILE BOOTING MY PC I GET A PROBLEM OR ERROR NAMED AS CMOS CHECKSUM ERROR DEFAULTS LOADED
Usually when I see this problem it is because the cmos battery is bad. Replace the cmos battery and see if that fixes the problem. If it doesn't, then you really do have a problem. :)
Mar 10, 2010 | AMD Sempron 2800, 2.0 GHz 2800+...
Cmos error-defaults loaded failed!
Please follow the following step to correct this error:
1. Change the CMOS battery,
2. Reset the CMOS Settings by using the CMOS Jumpers on the Motherboard.
3. Start the PC, enter BIOS setup.
4. Load the default settings
5. Save, Exit and restart the PC
Thanks
Geodavis
Nov 20, 2009 | Intel Motherboard
Cmos reloaded changed my cpu from a amd 2800+ to a 2200
When rebooting, go into BIOS and select the feature for Clocking. Most motherboards will go to a default setting and underclock your processor. In Clocking, you should see your processor identified as 2200 with an option to change it to 2800. Best of luck and post back if you have any more questions.
Greg
Jun 11, 2009 | DFI NFII Ultra INFINITY Motherboard
I had lost my driver CD. What can I do now?
You don't need a driver for your processor, the utilities for AMD processors can be found on the AMD website. You probablly lost the motherboard drivers, for that you need to go to the motherboard manufacturers website an download the drivers for the model you have. It should work with the windows default drivers
Apr 30, 2009 | AMD Sempron 2800, 2.0 GHz 2800+...
VGA driver...
Is it a Jetway M26GT3-SVP motherboard? if you are using the onboard video (video from motherboard) here is the link to the driver
http://216.185.128.200/temp/jetway0c/downloads/driver/mcp61_2kxp.rar
if you are using a Video card? what is its model ATI or Nvidia?
Feb 01, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Jetway 939 gt motherboard install
What install disk are you talking about, and sorry ,need to know the error too.
Nov 18, 2007 | Jetway 939GT4-SLI-G Motherboard
JetwayV266b (REV: 3.00) - Max processor speed??
Design ATX form factor 4 layers PCB size: 30.5x24.4cm Chipset VIA KT266A/VT8233A Chipset CPU Socket Support AMD Athlon 700MHz∼1.4GHz processor Support AMD Athlon XP 1500+ 2600+ processor Support AMD Duron 600MHz 1.3GHz processor Support 200MHz/266MHz (Double Data Rate) Front Side Bus frequency processors Reserves support for future AMD processors 2600+ is the highest it will go. http://www.machspeed.com/manuals/VIPER/V266B.pdf page 3
Sep 17, 2007 | Jetway V266B Motherboard
Cmos error
ok, a checksum error can refer to a flat cr2032 cmos battery, especially if the time is wrong at every boot.
May 26, 2007 | Intel SuperMicro SUPER Motherboard - 810...
AMD Athlon64 2800+, 1.8 GHz Athlon 64 (amdada2800axbox) Processor Logo
151 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
