Question about GE JGRS14 Gas Single Oven
Temp 50 degree too cold need to adjust thermostat on JGRS14
Replaced thermostat and oven still 50 degree cold. how do you adjust thermostat?
    Sergeant:
  • 311 Answers
Ive installed 100 new thermostats over the years and they are set from the factory.no adjusting.now some knobs have an adjustment on them.and some times customers got knobs mixed up and got the wrong one one there.
Posted on Jan 01, 2009
My Dayton 4lz94 greenhouse thermostat doesn't activate at the set temp. But will turn on when temp is about 5 degrees below. Set temp. Is there a sensitivity adjustment to calibrate for activatio
I am having the same problem with my Dayton greenhouse thermostat, this question was posted in the wrong section...but if you find a solution I'd like to know. I am having problems with the heating thermostat as well as the cooling one.
Jan 27, 2012 | Ovens
Temperature varies
very normal but only during pre heat / once the oven is stable tempt should be 5 to 10 deg above and below the tempt setting and if not replace the oven temp sensor located inside the oven on the back ..mm
Jul 12, 2010 | GE JGRS14 Gas Single Oven
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
Oven temp. is off at times, varies how many degrees
Replace the thermostat, and it should solve your problem.
Please rate my solution.
Thanks.
Nov 09, 2009 | Kenmore Ovens
Oven not achieving correct temperature, 50 degrees too low
Thermostat is not working properly and needs replacement.
Apr 14, 2017 | Ovens
My Whirlpool oven no longer heats to the set temperature.
Temp probe/thermometer inside oven dirty, or off attachment, or defective. On some models, a small screw head adjustment is provided to calibrate thermometer under dial knob. Else, I would just set dial 50 degrees higher rather than expense of new thermometer or dial.
Mar 02, 2009 | Ovens
Adjust oven temp
problem fixed... thank you
Dec 01, 2008 | GE JGRS14 Gas Single Oven
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Jun 25, 2008 | GE Profile JT912 Electric Single Oven
Creda oven
you might have already thought of this, buy an oven thermometer you can pop in the oven.
I bought one from my local cook shop
I have a the same cooker and similar problem - mine gets hotter by 50 degrees so I set the temperature 50 degrees lower than needed.
I noticed the problem a few years a go and luckily hasn't got any worse.
maria
Jan 02, 2008 | Ovens
GE JGRS14 Gas Single Oven Logo
294 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
