Question about Zenith ZTG Nema-3R, 400 Amps Three Phase, Automatic Transfer Switch (ZN3NEMA3R400) UPS System
Zenith mx 100 hangs up on retransfer,stays in neutral position
The switch starts the genset,it transfers ok but when utility returns the switch gets stusk in neutral,ive cleaned the relays in the rt box,ive cleaned and even replaced the micro switches but problem still happens once and a while-not everytime.
    Problem Solver:
  • 16 Answers
Call GE Zenith 24x7 tech support team @ 1-800-637-1738, option # 3
www.gedigitalenergy.com/pq
Posted on Nov 08, 2009
Gen runs when switch in auto even though power avail. Tried resetting ATS - waited 30 min. No luck. Only way to turn off is to move switch to stop/reset. Any ideas on what is broken?
have an electrician check the relay that is activated when the utility power fails
that is what starts the genset when it is in auto
it should also stop the get set when utility power comes back on
Nov 03, 2015 | Kohler 17RES 17 kW Generator
1998 blazer 4x4 cannot get it into 4 wheel high when i pus the button th4x4 and low range lights both blink and it goes back to 2 wheel high
Transfer Case Shift Control Switch Indicator Flashes and Returns to Original Mode.
Circuit Description
This symptom usually occurs when a shift into or out of 4LOW will not occur. When the transfer case control module (TCCM) receives a request to shift into or out of 4LOW, the TCCM must see the following parameters before the shift routine can start:
The vehicle speed must be below 3 MPH.
The transmission must be in neutral.
If the TCCM does not see these conditions the shift control switch indicator lamp will flash for approximately 5 seconds and then return to the original gear.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
  1. This step tests the operation of the transfer case shift control switch to help determine if the system is operating properly.
  2. This step determines if the vehicle speed sensor reading is correct.
  3. This step determines if the park switch reading is correct.
Switch Indicator Lamp Flashes and Returns to Original Mode
Step
Action
Value(s)
Yes
No
Schematic Reference: Transfer Case Control Schematics
Important: The transfer case shift control module is not a class 2 device, and therefore a scan tool can not be utilized on this transfer case.
Did you perform A Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check
  1. Start the engine.
  2. Place the transmission into NEUTRAL.
  3. Set the park brake.
  4. Depress each of the shift control switch buttons.
Does the transfer case range change with the press of all of the shift control switch buttons?
Go to
Testing for Intermittent Conditions and Poor Connections
Go to Step 3
Use the scan tool in order to read the vehicle speed sensor on the transmission control Data Lists.
Is the vehicle speed within the specified range?
0 km/h (0 mph)
Go to Step 4
Go to
Powertrain On Board Diagnostic (OBD) System Check for the 4.3L engine
  1. Put the transmission in neutral.
  2. Observe the current state of the transmission on the scan tool in the transmission control Data 2 List.
Does the scan tool indicate the transmission is in Neutral?
Go to Step 5
Go to
5
Replace the transfer case shift control module. Refer to Transfer Case Shift Control Module Replacement .
Did you complete the replacement?
Go to Step 6
6
Operate the vehicle within the conditions for causing the symptom as specified in the supporting text.
Does the symptom re-occur?
Go to Step 2
System OK
Feb 12, 2015 | 1998 Chevrolet Blazer
Proper use fwd nissan xterra
turn selector switch clockwise to the push position then push and while pushing return to desired position and release. the vehichle should be stopped and in neutral at the time you are switching between 2 and 4 wheel drive
Dec 29, 2012 | Cars & Trucks
Starter staying engaged after starting on 2005 malibu ls
check to engagement wire at the starter, make sure that power is only present when key is in the start position.if this is the case, then your sarter bendix is hanging up on the flywheel, this is caused by either inproper shiming where the starter is bolted to the block, or having the wrong bendix on the starter, there or several different bendix s general motors uses, also if the return spring in the solonoid is broken or not strong enough the starter could hang up. if the problem is power continuing to feed the solonoid with the key in the run position you could have a bad or out of adjustment ignition switch, since the power feeds the solonoid directly from the ignition switch, other than the neutral switch on the colomn
Jul 23, 2012 | 2005 Chevrolet Malibu
The generator doesn't turn off after transfering power back to the utility
The transfer switch is responsible for starting / stopping the generator. Check your auto - start circuit. It is 2 wires that go between the genset and ATS. They are generally normally open. When the genset is to shut down this circuit needs to change state.
Jul 09, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
HOW TO SHIFT TO 4 WHEEL DRIVE
Hi - Here is instruction how to do.
From N to 4H
Stop the vehicle completely, place the
transmission in "N" (Neutral) and depress
the brake pedal and the clutch pedal fully
(if equipped), then push in and turn the
switch to shift into "4H".
From 4H to 4H LOCK
You can operate the transfer switch either
when the vehicle is stopped or while the
vehicle is moving.
Position the front wheels straight ahead
and turn the switch to shift into "4H LOCK".
If the vehicle is moving, we recommend
that the speed be less than 100 km/h (60
mph) during this operation.
NOTE:
• When shifting between the transfer
switch position and the transfer gear
position is unmatched, all 4WD indicators
will blink and the buzzer will sound.
• If it is difficult to shift between "4H" and
"4H LOCK" while the vehicle is moving,
try accelerating and decelerating your
vehicle several times after turning the
transfer switch. Be sure to wait until traffic
conditions allow you to accelerate and
decelerate safety before using this procedure.
From 4H LOCK to 4L LOCK
switch to shift into "4L LOCK".
From 4L LOCK to 4H LOCK
From 4H LOCK to 4H
vehicle is moving.
and turn the switch to shift into "4H". If the
vehicle is moving, we recommend that the
speed be less than 100 km/h (60 mph) during
this operation.
NOTE:
From 4H to N
64J209
switch to the mark (1) at the left of the "N"
position, and hold the switch in this posi-
tion for 5 seconds until the "N" indicator
blinks, then turn the switch to the "N" position.
When you turn the transfer switch to the
"N" position, "N" indicator will come on with
the buzzer sound.
CAUTION
• Be sure to stop the vehicle completely
before operating the transfer
switch to shift between "N" and
"4H", or between "4H LOCK" and
"4L LOCK".
• Do not shift between "4H" and "4H
LOCK" unless the front wheels are
in the straight-ahead position and
we recommend that the vehicle
mph).
Do not operate the transfer switch
while tires are racing.
• Do not operate your vehicle in "4H
LOCK" or "4L LOCK" on dry, hard
surfaces.
(Continued)
CAUTION
(Continued)
• Do not operate the vehicle while a
4WD mode indicator is blinking
except when shifting between "4H"
and "4L LOCK".
If you operate the vehicle while a
4WD mode indicator is blinking, a
buzzer will sound and the transfer
will shift to "N" (Neutral) to prevent
transfer case damage.
In this case, use the following procedure.
1) Depress the clutch pedal fully (if
equipped) or shift the automatic
transmission gearshift lever to the
"N" position.
2) Turn the transfer switch to the
position previously selected.
3) Operate the transfer switch again.
Feb 01, 2011 | 2007 Suzuki Grand Vitara 4WD
Generator Transfer Problem
There isn't much you can do with servicing the generator set or transfer switch unless you've got lots of experience in diagnoising semi-conductors and electronic components.
Depending on the age of the system, it would be benificial to have a qualified service tech take a look at it.
As an electrician, I've installed several back up generator sets in homes for customers and have had a few of these automatic transfer switches with intermittent operation issues. Sometimes it's the switch and other times it's the Generator that is causing the problems.
Hope this helps, and best regards!
Aug 07, 2009 | Generac 100 Amp 120/240-Volt Transfer...
6.5 RV Onan generaotr wont kick in when loaded. checked automatic transfer switch and excited it manually, worked one time but never again,
1. Does the generator stay running when you start it the first time?
2. What color is the housing on this generator? Try to get the model number and serial number.
If the genset is shutting down on the first try, then your probably not creating voltage. However, if this is an older unit then the genset may stay running although no voltage is created. Place a volt meter on the genset to check for output voltage.
Mar 08, 2009 | Watts Onan Portable Generator - 5000 ,...
Computers & Internet Logo
444 people viewed this question
Top Zenith Computers & Internet Experts
Are you a Zenith Computer and Internet Expert? Answer questions, earn points and help others
