Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
Kp46wt520flashes 9 times
My tv flases 9 times between pauses.. I replaced diodes d6116 and d6301 and nothing changed. still flashes 9 times and doesnt turn on? any suggestions greatly appreciated. thanks
  • Sony Master
  • 5,138 Answers
? D6117.
Posted on Jan 01, 2009
  • ladywinn
    ladywinn Jan 08, 2009
    NTE552 General Purpose Fast Switching Diode.D6117
TV has been working great for the past 6 years, this morning when turning on the TV nothing happens except the standby light flashes about 9 times on and off. No click like I usually hear when turning on...
Hi Dave,
We have had this same problem twice now - the first time under warranty (no problem) and now currently. The 9-blink error code refers to needing to replace two diodes on the G board. Specifically, D6301 and D6116.
The warranty time, the repair guy came and resoldered the new diodes onto the G Board, reinstalled the board, and was on his way. We had no problems for the next 3 years.
THIS time I ordered the two diodes from Andrews Electronics (www.andrewselectronics.com) am removing the G board myself and taking JUST THE BOARD to a local TV repair guy. This is a LOT cheaper than calling Sears or taking the whole TV to the repair guy. Here are the links to the specific diodes:
D6301 - http://parts.andrewselectronics.com/search/electronic-parts/parts/7/6-500-567-21.aspx
D6116 - http://parts.andrewselectronics.com/search/electronic-parts/parts/7/8-719-081-97.aspx
They are a heck of a lot less expensive than other places and the customer service I received was great!
I hope this helps!!
Jan 12, 2011 | Sony KP-57WS520 57" Rear Projection...
Standby/light flashes 9 times, what does this means.
call pts electronics replace power board in you tv dont try to fix just replace board
Aug 10, 2010 | Sony KP-51WS520 51" Rear Projection...
Tv wont turn on
You have a zero crossing failure.
Replace diodes D6301 and D6116 on the G board with 1n4002 diodes.
May 17, 2009 | Sony KP-51WS520 51" Rear Projection...
No picture or sounds red light blinks 10 times
The parts you need are two diodes, D6301, D6309, and D6116, Sony part numbers 6-500-567-21 (D6301 and 09) and 8-719-081-97 (D6116), they are located on the G board, and that's located on the left side of the set, as seen from the back.
D6116 is connected to pin 9 of transformer T6101, and D6301 and 09 are in series off of pin 7 of that transformer.
May 05, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Model KDP-51WS655 - blinks 9 times
A 9 flash code is defined as a zero cross failure, basically a power supply fault. It is usually caused by the failure of one or two diodes on the G board D6301 or D6116. D6116 is 871908197 and D6301 is 650056721. If you can get them and are handy with a soldering iron, you can probably replace them. Be sure the set is unplugged and use care when installing them, as high voltages exist in the set even after it is unplugged. If this answer is to your liking, please be sure to rate it. Thanks! Also, a good confirmation of this is to turn the set on using the following error code display method. With the original remote, press the following buttons:
DISPLAY
5
VOL -
POWER
The set will usually turn on this way if the diodes have failed
Oct 26, 2008 | Sony Grand WEGA KDP-51WS655 51" Rear...
KP-57WS520 9 LED blinks
Don't replace the entire G board! that is expensive! The diodes are available from MCM electronics and can be easily replaced.
Aug 18, 2008 | Sony KP-57WS520 57" Rear Projection...
10 flashing lights then 9
make sure it is 9 blinking it may be 10
Aug 15, 2008 | Sony KP-46WT520 46" Rear Projection...
Tv does not turn on
Diode D6116 or D6301 is open on the D board replace those two diodes.
May 22, 2008 | Sony Grand WEGA KDP-57WS655 57" Rear...
Standby flashes 9 times
the 9 flashes means your Diode D6116 or D6301 is open on G board and needs to be replaced ...and your chassis is Ax-1x
Apr 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony rear projection tv How to de-solder
I would suggest not to desolder that transformer until you are certain that is defective.
Try to change D6116 and D6301 first.
You can try Radio Shack or check this site.
Good Luck.
Apr 10, 2008 | Sony KP-57WS520 57" Rear Projection...
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
140 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
