Question about Sony DRU-810A DVD RW Dual Layer Burner
DVD BURNER DISAPPERS FROM "MY COMPUTER"
My dvd burner disappers (and will not fuction)from the computer(other drive on same cable and ide channel doen't disappear). Restarting the computer solves the problem, but then the computer loses it again. Sony Corp is no help as the drive is over 1 year old
    President:
  • 2,961 Answers
You can try using the ide cable connector that the other drive is on and swap them round just to illiminate the cable connector, but at the end of the day i think your DVD burner is faulty and requires replacing, as they are very innexpensive to replace as you wili probably know,so don't waste too much time trying to solve it. The drives dont last as long as they used to because, keeping the price of burners down, like anything else means cutting corners and costs and in burners cases as was the case with PS2's the lasers are cheap and soon fail.
Posted on May 07, 2007
Need install cd burner in windows xp
IDE or SATA connections ??????
To enable CD burning for your computer is a relatively simple process in Windows XP.
All you need is a CD burner drive installed in your computer, the disk with the drivers and software that goes with it and an XP-loaded personal computer.
Once your driver is installed, the process is almost automatic.
Here are the steps you should follow to begin creating your own CDs.
Check your system requirements before installing the CD burner and make sure that your system can handle the speed and memory requirements of the drive.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Turn off the computer, disconnect the power cord and remove the cover from the case.
Check the IDE cables inside your computer.
You may be able to connect the optical CD drive to the same ribbon cable as the hard drive if it is set up as a secondary or slave drive or to a separate ATA/IDE channel by a second cable.
Find an empty CD drive slot, remove the plastic cover from the outside, slide the drive in through the back and screw it in place.
If you are using a SATA CD burner, you'll need to connect the red SATA cable from the CD drive to the SATA connection on the motherboard or on your SATA drive controller card.
With SATA drives, you don't have to fool with jumpers.
Attach one end of the separate ATA/IDE cable to the motherboard if you have an IDE drive and the other to the back of the CD burner.
If slaving the drive, hook the drive to the second connection on the main hard drive cable to the burner drive.
If you do that, you'll have to set the jumpers on the CD drive to the "slave" position.
The drive's installation instructions will show you where the jumper pins are and how to set them to the slave position.
If using a separate IDE cable, just leave the jumpers in the factory setting.
If this is an older drive, you may have an analog audio cable as well that connects to the motherboard.
Follow the installation instructions for hooking it up.
Close the case and reconnect the power cord and other cables.
Turn on the computer and let it boot up.
Open the "My Computer" folder and make sure there is a new icon for the drive that you just installed.
XP will generally recognize it automatically, but if it doesn't you'll have to reboot the computer and open the CMOS setup program.
Follow the instructions for your particular PC to open the CMOS window.
Check the ATA channels to make sure both are enabled in setup and that, if you are using a master/slave setup, that the CMOS selections match that setup.
Reboot the system.
If the CMOS settings are correct, the XP operating system will set your drive so that it uses either digital CD playback (no audio cable) or analog playback (with audio cable). To check, open the "My Computer" window, choose "Properties" then "Hardware" then "Device Manager".
You'll see a "DVD/CD-ROM Drives" icon.
Click the plus sign next to DVD/CD-ROM Drives folder.
Click it, then right-click the icon for the new CD burner drive.
Now choose "Properties".
If you don't have an audio cable, left click on the selection box for "Enable digital CD audio for this CD-ROM device".
Insert the CD burner software disk that came with your CD burner.
Insert the disk that came with the drive into the CD drive and install the software following the prompts.
If the drive doesn't come with CD burner software, Windows XP comes with a lite version of Roxio's Easy CD Creator that detects blank CDs.
Just insert a blank CD in the burner and XP offers you a "burn CD" option when you have autoplay set up for the CD-drive.
There are lots of freeware burning software on the internet.
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files.
Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner.
http://www.freeware-downloads.com/nero_essentials.htm
nero 8.1 essentials free
This is the newest version of the most known CD and DVD burning software, but now with the capability to burn HD DVDs, and Blu-ray Discs
http://nero-free.soft32.com/
Nero 9 .4.12 free Create, rip, copy, burn, edit, share, and upload online
Nov 10, 2013 | Broderbund Computers & Internet
D945gtp how to connect cd-rom hardware
1) IDE {PATA} DVD burner drive:
For an IDE { PATA } DVD burner, connect to the 40-pin IDE header on the motherboard. This is located to the right side of the Ram Memory slots.
It is the longer header that has 40 contact pins. {39 actually}
( The shorter connector on the motherboard is for a Floppy Drive.
{34 pins} It is above the IDE 40-pin connector )
NOTE*
The IDE connector on the motherboard should be keyed. Should have a cutout on one side. This is so the Number 1 pin in the flat IDE ribbon cable, will line up with Number 1 pin in the motherboard connector.
Some flat IDE ribbon cables, do not have a Locating Lug on the connector. (Small rectangular 'bump')
Number 1 pin on the IDE ribbon cable will be on the side that has a faint RED stripe on it.
Number 1 pin in the motherboard connector is at the Bottom, with the motherboard installed.
The side of the flat ribbon IDE cable that has the faint red stripe on it, goes DOWN, when installed in the motherboard connector.
If the DVD drive does not have a cutout for it's circuit board, the faint red stripe of the flat ribbon IDE cable, goes towards the power cable connection.
2) SATA DVD burner drive:
You have 4 Serial ATA headers (Connectors) on the motherboard.
Your SATA harddrive should be plugged into the SATA1 header.
You can choose any open available SATA header, to plug your SATA DVD burner drive into.
BIOS will see it once you turn the computer on.
3) If you somehow have been using an IDE {PATA} harddrive, and have it connected to your IDE connector on the motherboard, you SHOULD not use a DVD drive on that flat IDE ribbon cable, also.
BIOS has to find which device has the Operating System on it, (Windows), and then hand the computer over to the Operating System.
To state again, BIOS will look at both devices connected to that flat ribbon cable. The Harddrive, and the DVD drive.
It will then determine that the Harddrive, is the device that has Windows on it, not the DVD drive.
This slows the computer down, and could result in a blue screen.
If you have an IDE harddrive plugged into the motherboard, it would be best to use a SATA DVD drive.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Intel D945GTP Motherboard
My sony external dvd drive DRX-S70U, is not being recognised by computer. I am presently using Vista basic.
Hello Crazee,
May be the data cable of external drive is not fuctioning properly. Please replace the data cable and then check it. Also upadate the usb drivers installed on the laptop.
May 19, 2011 | Sony DRX-S70U-R DVD±RW Dual Layer Burner
Cant get burner to reconised on pc
Since this is an IDE drive, please check the Master/Slave/Cable Select jumpers, if you've connected the drive in the same cable of your hard drive, you should check its jumper settings, if hard drive is set as Master, the DVD writer it should be as Slave, if the hard disk jumper is set to Cable Select (CS), the DVD should be in the same way too. After this check if DVD drive is identified correctly in BIOS, it's a good idea to set drive detection as Auto, if this all is OK, check its driver in Windows, it must be appear as a DVD-RW drive.
Mar 03, 2011 | LG GH22NP21 DVD-Writer - Internal...
IDE channel fail to work. After some time, IDE DVD RW is not displayed either in windows, or BIOS!
First be sure that the IDE cable is firmly pushed into the socket on the mother board then Check that the DVD player is set on cable select on the back of the DVD burner, if the jumper is not set right the Computer won't see the drive. If this does not correct the problem make sure that your plugged into an IDE interface and not a raid Plug. If you plug it into a raid device then you must have the software installed and you have to set the jumpers on the back of the DVD player/burner. Do you have the correct Ribbon? hope this helps.
Feb 22, 2010 | Gigabyte GA-73VM-S2 - Motherboard - micro...
I'm trying to install a DVD burner into my Dell GX520 (mini tower) and can't work it out ... can anyone help?
If you install the DVD drive on the same IDE cable as the hard drive using the second connector, then the jumper on the DVD burner has to be set to SLAVE.
If you elect to install the DVD burner on the cable which is connected to the second IDE controller (this is the preferred way), then the jumper setting can be set to either MASTER or SLAVE provided there are no other devices on this cable.
When the computer boots up go into the BIOS configuration to see if the BIOS detects the DVD burner, if not then the jumper settings on the DVD burner is not correct.
Oct 09, 2009 | Dell Optiplex GX520 Desktop PC - Intel...
I have a TDK DVD/CD burner that my computer does not recognize. When I turn it on my computer makes a sound like it knows it has been turned on but when I go to burn a music cd it says that there is no CD...
hi blgard,
please ensure u have wired up this internal combo drive properly,
- that IDE cables and power cable is connected, that the jumper setting
is properly(if using this as a single drive without any harddrive connected to the same IDE cable jumper must be set to single!)
- that in BIOS both ODE channels are activated and drive detection is set to auto
when done this properly, the drives will be listed when booting up(press pause button, right before windows is loading, to see list)
if not, use the other channel(echange IDE plugs on the mainboard), retry
and see.
when booting the green lamp of the drive should light up shortly!
then goto windows/setting/hardware, run hardware detection/device manager and wait for the new device to show up. Make sure you have the driver CD ready for windows will ask for it, (if you don't have another cd-drive ready, copy content of cd onto usb-stick/thumbdrive instead )
le win search for the drivers on the cd/usb-device,
proceed installing, finish and reboot.
if now windows can't find the drive (see win explorer)
but it is listed when booting up, get the latest drivers from the manufacturer's homepage and reinstall drivers!
I hope this works for You!
Sep 07, 2009 | TDK (ai-4800drombx-b) CD-RW/DVD-ROM...
How do I connect Burner to IDE cable?
Yeah its a SATA and you need a SaTa controller to put into your computer you cannot connect this via ide
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | ASUS DRW-2014L1T DVD-RAM Burner
Burner problems
First check if device is recognised in bios, if it is then you need to fixwindows. If you cannot see cd unit in bios then check that slave/master / cable bridge settings at back of cd are fine.In this case the fastest way to test your unit is to connect it as single unit with a tested ide cable on the computer, just to test it. On the other channel you connect the hd. Eventually switch channels and cables between hd and cd.
Feb 19, 2008 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Computer won't recognize sata dvd burner
is jumpers on corect cant u just use ide cable instaed u said your going from ide to sata cable ?
Jan 19, 2008 | EliteGroup P4VXMS (P4VXMS-R) Motherboard
Sony DRU-810A DVD RW Dual Layer Burner Logo
83 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
