My portable air conditioner has stopped pumping water to the tank
  • Anonymous Apr 27, 2009
    my portable air condition has stopped pumping water from the a.c. unit through the little hose that came with the unit. i have to manually drain my a.c. unit everyday. i have the frididaire portable air conditioner
  • 311 Answers
This would be a swamp cooler.if you have water in it and its not pumping.its going tobe the pump but i would see if the pump is getting voltage first before i bought a new pump.where doyou live that your worried about a cooler?
Posted on Jan 01, 2009
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
My dad has a portable Whirlpool ac unit. for the last couple of days it stops running and needs to have water emptied. Can I fix this for him?
you would need to drill the pan ad install a drain hose on or around the bottom of the water tank, you will need a place for that water to drain to, there is auto drain pumps that are used on under cabinet ice machines also, but $$$ .. hope i was of help.. jay
Jul 25, 2011 | Whirlpool ACP102PS Portable Air...
There is no drain pipe for the unit I have. It has a cap on the back but no hold, how does the condensation.
Self Evaporating Technology - During the cooling process, water is extracted from the air into the unit. Most of this water is then recycled and used to cool the unit and make it run more efficiently. Approximately 65 to 70% of water condensed is evaporated out with the exhaust air, reducing the hassle of emptying the water tank constantly. This unit has a built-in water tank (not removable) with a drain outlet, and a water tube. When the tank fills, the compressor stops operating and the power light will flash. This indicates that the tank should be emptied.
Jul 21, 2011 | Amcor ALTL-12000E Portable Air Conditioner
We have a soleusair portable heat pump air conditioner PH5(S) series. The tank full light is on and won't go off. We have drained the unit and still the light stays on. We are trying to use as a...
Remove the water tank and look or feel up to where the float is at and see if it is stuck in the raised position. This is what is keeping the light on and not letting the compressor start.
Jun 20, 2011 | Soleus Ph5-13r-35d Portable Air...
No water comming into machine
On a portable AC, the only way water can be distributed is by a pump which pumps the water out of the collector tank. Chances are that the impellor inside the pump has stripped or is slipping, therefore not pumping the water. ( that is , I am assuming , this model is an evaporative type cooler?? ) if it is a refrigerated type, there shouldnt be any need for water , however , it will have a condensate pan which catches the water produced by the refrigeration cycle.
Jun 18, 2011 | Midea MPM-08CR-BB4 Portable Air...
The E5 code is on, emptied the water tank; still on
AC Water Level Sensor for C475 and C360 Alen Portable Air Conditioners This is a replacement water level sensor for the Check out this sight. Good luck
Aug 31, 2009 | Alen C475 Portable Air Conditioner
I have a portable air conditioner and the water condensation tank fills in about 4 hours of constant use. Is there any kind of portable water tank that I could attach to my unit that would allow me to...
I would suggest putting a condensate pump in the reservoir, find the tube that empties the water into the reservoir and direct that into the pump. You can run tubing from the pump to a sink or any other drain in the house that is convenient. Putting the pump inside the reservoir is a safe guard in case the pump fails, the water will fill and turn the unit off instead of flooding the floor. It would actually probably trip your breaker once the water hit the voltage on the pump but always better safe then sorry. Check out these pumps at amazon, you don't need anything fancy.
Good Luck
Jun 11, 2009 | GE APN10AA Portable Air Conditioner
Heating & Cooling Logo
127 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
