Question about GE Spacemaker Washer and Dryer Electric Laundry Center
GE spacemaker dryer won't start
My GE spacemaker dryer won't start. I don't think it is the belt because it does not have a burning smell.
  • Anonymous Feb 01, 2009
    Mine will start for 1 second and then stop. The lights then start to flash and it turns off.  Any recommendations?
  • Anonymous Mar 14, 2014
    Dryer does not start up
    Problem Solver:
  • 8 Answers
Have you tried keepin the dryer door open, depressing the safety switch which enables the dryer to work when it is closed, and then turn on the dryer to see if it turns at all? Sometimes its the smallest things that cause these problems. That switch that gets pressed when the door closes, sometimes malfunctions. Sometimes the door of the dryer gets out of whack and doesnt really make contact with the switch enough to trigger the flow of electricity.
Posted on Jan 13, 2009
Thank you so much!  This solution saved my afternoon.  It would have never occurred to me.  Well done!
Posted on Feb 20, 2009
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Aug 04, 2013 | GE Dryers
Laundry machine won't drain, burning smell
check the pump under the washing machine might be a coin jammed in little fan in side the pump use a hose pipe to drain out the water
Jan 29, 2013 | GE Spacemaker Washer and Dryer Electric...
Kenmore whirlpool dryer won't start and has a bad burning smell
You may have an overheat sensor that is burning up. The dryer won't start because the heat would be uncontrollably high otherwise
Jan 29, 2013 | GE Profile DPSF495EW Dryer
Burned rubber smell after replacing motor coupler, otherwise runs
The most common cause for the coupler failing is a bad gearcase. The machine should go through a neutral drain before the spin if it doesn't drain the water first it over works the motor trying to spin a full tub. No belt on this one, odor could be from the motor or the coupler starting to shred again.
Mar 01, 2010 | GE Spacemaker Washer and Dryer Electric...
I have a used GE DCLR333ETOAA model and last time was used it work for few mins. but smell like burn and then stop working. What you think it is?
If the machine quit and won't restart, I would be looking at the drum belt. Some machines will not start if the belt is broken. If the smell you are getting is more electrtical than a rubber smell you need to be checking the thermostats and make sure the venting from the back of the dryer to the outside is not full of lint because the safety thermostat will shut the dryer down so it doesn't overheat.
Jan 24, 2010 | GE Dryers
My ge stackable smells like it is burning. How do I fix this?
Well, you do not mention which machine causes the smell. My concern is fire hazzard, be sure to check the dryer hose system, and DO NOT USE plactic vent hose, major fire hazzard, they make the same thing in metal and it works better....
Sep 20, 2009 | GE Spacemaker Washer and Dryer Electric...
Washer stopped spin cycle smell like burning rubber
hello if the belt is broken quite easy to put back on .take the back off you should see the belt if it has snaped or just come off .at the bottom of the washer you should see the motor at the back of the motor you should see 2 nuts this holds the motor on get a felt tip pen and mark the 2 nuts where they are fixed so you know where to tighten back on . get spanner and loosen the 2 nuts the motor should drop down put the belt back on and tighten up good luck
shaun
Mar 31, 2009 | GE Washing Machines
GE Dryer smells like its burning
the burning smell may be caused by a belt some have a look at the belt
Mar 07, 2009 | GE Dryers
Smells like belts are burning during rinse cycle while washing
TAKE OFF THE FRONT PANEL BY TAKING OUT THE TWO SCREWS AT THE BOTTOM. SLIDE THE PANEL DOWN ABOUT HALF AN INCH AND THEN PULL OUT. YOU CAN NOW SEE THE INNER WORKINGS. AS FOR PARTS, TRY WWW.MARCONE.COM
Jan 07, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Burning smell
Sounds like your drier is over loaded. Belt slipping due to : to much weight in drier. The drier motor is an adjustable. Belt test: If you can twist belt more than a half a turn it is to lose. Replace belt.
Feb 10, 2018 | Kenmore Elite HE4 Electric Dryer
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
1,075 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
