B&O Beomaster 8000 wont power up.
I have a Beomaster 8000 that won't turn on anymore? The stand-by light illuminates. Occaisionally it with spring to life of its own accord, stay on for about 10 seconds then go to stand-by again. I have checked all fuses, I am getting 5V to IC3 + 4. Earths check out OK.
  • dean4sam Jan 02, 2009
    It appears to have an earth fault on the main IC. I will let you know the outcome
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls be informed that I am not familiar with the model. But with your indulgence, a couple of ideas on similar concerns you may want to consider/explore:
  • the illuminated standby light and the +5 VDC correlates;
  • "Occaisionally it with spring to life of its own accord" - do you mean simply power ON, or work as in sound is produced normally;
  • "stay on for about 10 seconds then go to stand-by" - indicates auto protect mode;
  • it would appear intermittent, then possibilities are leaky power supply capacitor, loose connection, cold solder (most likely), fault relay, relay driver, relay driver capacitor;
  • of course primary suspect would be the finals and presence/absence of +/- supply voltage.
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Jan 01, 2009
    Brigadier General:
  • 5,158 Answers
A component is overheating... likely in the power supply area. you need some compressed air to blow air on different parts till you narrow down what is overheating.
Robert
  • Roberta Smith
    Roberta Smith Jan 01, 2009
    you can get the service manual for that receiver here.
    http://www.hifiengine.com/manuals/bang-a...
    you'll need to register (free) please not when you look for the manual it's under bang olufsen
    Robert
LG 60PN6500 plasma tv power surged. has no picture and i think no sound. tv wont turn on but stand by light illuminates but then shuts off. in a cycle fashion. cant find my multi-meter to check fuses
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 20, 2017 | LG Televison & Video
My 1997 Suzuki Bandit600 won't start, the battery
during the battery replacement did you manage to either forget or damage a wire that powers up say your ignition module... ?
Sep 15, 2014 | 1997 Suzuki GSF 600 S Bandit
Emerson tv....won't turn on...stand by light won't go off
Not making it on or out of standby---first place to look is the power supply for signs of damage or puffed up filter caps there.
Dec 10, 2012 | Emerson SLC195EM8 LCD TV
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My turn signal won't lit when activate and my brake light also wont also but is illuminate. The Top Brake light do light up when but only when the lights are turned on manual setting if they are on...
possible multifunction switch gone bad for turn signal problem. do headlihgts come on in a dark setting on automatic or not? if they don't come on when it is dark then most likely bad light sensor in top of dash or maybe unplugged if recent dash work has been done.
Jul 13, 2011 | 2002 Mercury Mountaineer
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
Ps3 wont turn on
hi Juan,
this is all i could find on the internet on what it might be.
Power supply is probably fried, but just try holding your finger down on the eject button and then flip the power switch back to on postion, it might help because this holding sequence re-boots the system and fixes some things.
or you could try this link to a youtube video,but what ever you try its at your own risk.
What to do when your ps3 won turn on
or see if this one helps you out.
Ps3 wont turn on Google Search
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Janome 8000
I took my machine in with the same problem and they told me the display was bad. They told me that they did not make this part anymore. Try and find a parts machine.
Mar 16, 2008 | Janome 8080 Computerized Sewing Machine
263 people viewed this question
 Grubhead
Grubhead
