Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Philips Projection HDTV 51pp9303h/17
Trouble philips,mod 51pp9303h/17, need parts number for convergence ic. I got problem I got sound ,but no Picture, all systems start and there is a very high pitch sound, how do I fix it ?
  • Philips Master
  • 3,459 Answers
In your set you have three circuit boards.
The one on the far left is the SSB, middle board is the LSB, and the board on the right is the power supply board.
Try yanking cable 1516 that connects the SSB to the LSB. Its a small white ribbon cable.
Does the set turn on now?
If so your convergence chips are shot and need to be repalced. You can get a replacement kit and instructions from www.TvRepairKits.com.  If the set tubes still don't light up after yanking 1516 the problem is elsewhere. Most likely the HVG.
Posted on Jan 07, 2009
  • Philips Master
  • 5,138 Answers
Number is on your STKs in TV Two big black ICs STK392-110s 150s, use 180s For Parts Electronix 1-800-223-3205 As for sound replace microboard has #P on it.
Posted on Jan 01, 2009
Adjust color on philips 51pp930h-17 tv
done with the remote in the customer menu under convergence.
Apr 29, 2012 | Philips 51PP9303H Rear Projection...
I got sound no picture
Most common problem Have sound no Picture Is Flyback Transformer is Bad on LSB
May 15, 2010 | Philips 51PP9303H Rear Projection...
Repair man said my philips tv model #51pp9303h/17 needs coupler.
Tries Shopjimmy.com,Partstore.som,or Ebay.com.These Websites have refurbish old and new tv parts.
Dec 28, 2009 | Televison & Video
Replacing STK-392-120 ICs on Philips TV
Ok, I can tell you not to remove the circuit board--best way with this set is to put the entire chassis--all three circuit boards in the"SERVICE" POSITION.
LET ME KNOW IF YOU WANT TO KNOW HOW TO DO THIS---YOU ARE RIGHT--YOU TRY TO REMOVE THE BOARD WITH THE CHIPS--SEVERAL OR ALL THE PLUGS ARE NOT MARKED WITH NUMBERS--THERE IS A SIMPLE WAY TO DO THIS.
LET ME KNOW AND i WILL ASSIST YOU.
Oct 13, 2009 | Philips 51PP9303H Rear Projection...
STKs in your set should be on same board that has tuners on it board you connect cable too.If different model they will be on board to very right end STK ICs are big black chips Two of them together.will have part number on them.
Jan 03, 2009 | Televison & Video
Convergence trouble philips mod 51pp9303h/17
You can get a convergence kit with a photo instuction guide from www.TvRepairKits.com. The kit is for your exact model and includes the 6.8 ohm resistors.
Dec 07, 2008 | Philips 55PW9363 55" Rear Projection...
Need Parts Number For Flyback In Philips W/S TV Model # 51PP9303H/17
If you are not sure how to find/repair/replace the HVG yourself goto www.TvRepairKits.com to get their how to guide that includes the part numbers, suppliers, instructions, etc.
Oct 16, 2008 | Philips 51PP9303H Rear Projection...
STK392-120 you will need to replace both of them
Mar 17, 2008 | Televison & Video
Philips 50PP9202 50 in. Rear Projection HDTV-Ready Television?
Hello Anthony14,
This is an indication the the red convergence amplifier has goone bad you will need to replace the convergence correction modules. Now before replacing these you may want to make sure that the bias resistors and the zener diodes are ok. The convergence ICs are part number STK329-110 or STK329-150.
I would suggest that you get a schematic and equipment to make the needed tests, or take the set to a shop to replace the bad components.
I hope this helps,
Thank you,
Shuttle83
Oct 14, 2007 | Philips 60PP9202 60" Rear Projection...
Color on my big screen tv
sounds like you need to have the two convergence IC's replaced. These are soldered on the main board. Good Luck
Jul 16, 2007 | Philips 46PP9302 46" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
193 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
