Want to FAX with My MagicJack(VOIP) using a standard FAX machine
I currently have a Panasonic plain paper fax and copier as well as my Lexmark All in one Printer/Fax. I really want to be able to utilize both of my fax setups here at home, but I am aware that Im using a Digital (VOIP) phone line versus an analog fax machine as well as a V.90 56k modem. I can either use my V.90 56K modem through the computer or use my fax machine, which both of them will dial out the number of the other party; but the other partys FAX machine does not recognize the digital signal, so it fails to go through. I have done some research on the problem at hand, I read up on something called an ATA box; but im not sure if thats going to solve my problem or not. I need something thats not to exspensive that will work for home office use. I am running Windows XP service pack 3, and I am using Clearwire Wireless internet access. I understand that using wireless connections arent good either for what im trying to do, but surely it can be done i would think. Please help.
Thanks,
Clifton
  • Clifton
    Clifton Jan 02, 2009
    What about using an ATA box? I have looked into this device, but im not sure if this is the right device for the job of course. Digital is digital, you know? I need something to convert the outgoing signal so it can be recognized by other analog fax machines. My stepdad said he sees that type of stuff all the time at offices where he goes to fix their equipment, but the stuff his company sells to fix those issues is very expensive. Any other ideas? I know they sell different types of ATA boxes at different prices, but not sure if thats the answer. I know thats a common issue in businesses that have networks that they want to fax through.
  • hankim Apr 16, 2009
    i have lexmark x7170 all in one fax/scan/copier. i tried to fax using the magicjack, but nothing happened. i can not send nor receive faxes. any solutions to this problem?
Holy ****, just google 'magic jack fax' and you'll get all the info you need. digital, analog, who cares, just do it.
Posted on Aug 09, 2009
  • 446 Answers
Im afraid you cannot use the magic jack as a fax feature, though you can use this to place a call but not as a fax, though you can try this steps
  1. Turn off error correction on your fax machine or program
  2. Set the fax machine or program to use the slowest speed available
  3. Increase the speed, checking at each speed that faxes work
Posted on Jan 01, 2009
  • Giulio Moro Dec 16, 2014
    This method does work as I've been using it like this for many years since before MagicJack was being advertised for sale like it is now. Setting the fax to the slowest speed possible does work most of the time, but sometimes the computer being used will garble the data if its slow, or the USB port uses a shared IRQ. Try a different USB port. Sometimes you have to get into the fax service menu to set the fax speed. No worries if it does garble, just resend it for free. An ATA will work just fine for you, but it will not work with MagicJack service as it's not a full or true VOIP service
Adjust baud rate on Sharp UX- 700 fax machine
It won't make any difference if you could. All fax machines are analog devices and won't work reliably on a digital phone line.
Nov 13, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Comm error on a VOIP line
Fax cannot send on a VOIP line unless the VOIP line has T.38 fax protocol service.
Sep 25, 2009 | Brother FAX-575 Plain Paper Thermal
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Fax not going through-Info code 503 coming up
PHONE LINE DISCONNECTED. Check the phone line with a regular phone.
Feb 26, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
I have magicjack phone service how to get and send fax
fax machines are ANALOG, Magicjack is DIGITAL. Your fax machine won't work reliably.
Jan 27, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Drops connection after connect, sends 2-3 pages
The fall-back required for transmission over VOIP is not available on this machine. It is a service mode function and can only be set by a technician. However, VOIP is so iffy for transmission that you may require fall-back to 4800 or even 2400. I have found that forcing fall-back more than 2 steps doesn't work.Also the Line equalisation can't be set as there is only 3 settings, 1.8;3.6; and 7.2 Km. Who knows how far to set VOIP, could be 3000KM. I had more success using a very old fax machine sending at 2400BPS that I could set the dip switches. Takes all sorts of changes to have success and then next time you try, it's changed again.
Feb 15, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Cable?
I'm not jaylex, but fax machines use a standard RJ-11 phone cord.
Jan 06, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Computers & Internet Logo
6,156 people viewed this question
David Payne
David Payne
