Question about SanDisk Sansa e250 MP3 Player
I need help..!my mp3 player wont charge - SanDisk Sansa e250 MP3 Player
  • 8,596 Answers
Make sure the lock switch is not engaged. If it is not, you may have a hardware problem which will require replacement. If none of the methods below work, call Sandisk and get your player replaced if it is still under warranty:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
My coby mp705 wont turn on but when i plug it to my computer it works.. what kind of assistance shall i do to make my coby back to normal? any kind of answer would be wonderful
sounds like the battery is the problem if it wont start wothout a power source
Check the system requirements for the MP3 player.
Most Coby players require Windows XP or higher and at least 1 GB of RAM to function correctly.
Check your Coby owner's manual to ensure that your machine meets all the required specifications before proceeding.
Charge the MP3 player fully.
Often, a player will act unexpectedly if it has a low charge.
A charge can also help reset the MP3 player if it has frozen or locked up.
Once the player has finished charging to 100%, see if the problem persists.
Re-sync your player.
Plug the MP3 player back in to the computer and then remove all the files.
If you have not done so already, make sure they are backed up to your hard drive.
Unplug your MP3 player and then re-load all of your files.
Check for corrupted and wrong format files.
Most Coby MP3 players only play back MP3 files, and will perform unexpected operations
if files of other formats are uploaded to the device.
Go through your uploaded files and check the extensions.
Anything that does not say ".mp3" or is not listed in your owner's manual needs to be deleted from the device.
hope this helps
Sep 30, 2012 | Coby MP-705 Digital Media Player
My coby mp610-2g wont charge i plug in my usb cable it wont do any thing please help me
Try to change the usb cable. If still can't, that means your mp3 player usb port is damaged. You will need to get it fix.
Apr 27, 2010 | Coby MP-610 MP3 Player
Sansa e250 wont charge when plugged into the computer.
Sounds like the internal battery needs to be replaced.
Hope this helps. Good Luck!
Aug 07, 2009 | SanDisk Sansa e250 MP3 Player
My fully charged MP3 player wont stay on. It
Yeap , time to replace the battery. after a certain amount of used hours all MP3 players will start to do this until it no longer has power.
Jun 03, 2009 | Audio Players & Recorders
Wont charge
Your mp3 player is shot. Your circuit board in your mp3 player has fried. You will need to go out and buy a new one.
Mike
May 28, 2009 | Element Electronics Zr-Element Digital...
Y wont the razor phone charger charge my MP3
Well it wont be compatible with the mp3. even if it does seem to fit into the slot where it charges you still wont get it to charge. also different chargers deliver a different ammount of energy to the device so it either wouldnt be enough or it would be too much. I hope this helps you solve your problem.
Feb 28, 2009 | Philips GoGear SA3125/37 MP3 Player
Coby MP3 mp550 -1g
my mp3 player wont turn off or charge some one please help me.............. help help help
Oct 15, 2008 | Coby MP-C7085 MP3 Player
Mp3 player wont charge
you must buy a new USB cable or it is destoryed i am not sure if it is destored but you get a new usb cable
Sep 19, 2008 | Samsung YP-K3 MP3 Player
Recharge
you probably have charged the battery when it wasn't empty and got a memory effect
Nov 12, 2007 | Samsung YP-U2X Digital Media Player
SanDisk Sansa e250 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
