Question about E-Machines eMachines Desktop PC
Computer won't start
I moved my computer (an eMachines, not yet six years old) from one room to the other this morning (long story), and when I went to turn on the CPU, it wouldn't. It was working fine up through yesterday evening, no sign of any trouble at all. (This includes a total absence of any of the kind of grindy or whirry noises that suggest a fan going bad.) The monitor, together with a lamp and a small calculator, are plugged into the same power strip that I used for the CPU; all turn on. The tiny green light on the back of the CPU blinks on very quickly when I first stick the prongs of the plug into the strip, then blacks out again. I tried it in another socket and the same thing happens. I have a suspicion it's the power source that has died, but can anyone tell from this whether I'm right? And if I am, what can I do about it?
    Problem Solver:
  • 15 Answers
95% of the time when they do that the power supply is gone could be a weak component in it.but unless you are a technician i would just replace it with the same type or same wattage this can be located on the sticker on the Power supply unit...
Posted on Nov 08, 2008
Unplug the power cords and let it sit for about 5 to 10 min. just like the cable box sometimes the brains have to be reset than make sure all plugs a lined up and tight good luck Dawn
Posted on May 06, 2007
MY GARMIN STREETPILOT C310 WORKED THIS MORNING, BUT NOW WILL NOT SWITCH ON?
It is also 7+ years old. in technology years that is like 140 years old. retire it and get a Nuvi.
Remember that time you went to start your car and it worked yesterday but today it would not start... bad stuff happens.
If you are holding out hope, try leaving it plugged into the car or outlet
try holding the power button for a long time (30 sec)
try plugging it into a computer and see if anything happens.
Mar 22, 2015 | Garmin GPS
White screen
test your computer with another monitor, if same issue occurs, problem is on video card/cables of your computer, if it runs good on another monitor, old monitor has problem.
Mar 22, 2014 | eMachines 15 inch Monitor
I have a 5 year old Emachines computer, a few weeks ago I bumped my foot on the desk that was holding the computer and the screen turned off and the tower started beeping. It was long continuous beeps. I...
Usually when you hear long beeps coming from your computer it telling you that there is hardware loose . You may have knocked something loose. Check cd roms , ports and cards , memory to make sure they are fitted in correctly . good luck
Aug 03, 2017 | Computers & Internet
Windows XP won't load on my emachine t3516
You may need to check to make sure Windows XP was installed properly, if the computer had crashed, you can do a repair, I am a computer technician, and I can tell you, that replacing the power supply will not do that.
May 20, 2012 | E-Machines eMachines Desktop PC
Emachines W5243, two years old, cuts off during wake-up
Possible solution
If this is an i/o problem then i would suggest that you clean the computer out. Go to the computer store and buy yourself one or two cans of compressed air. When you get them you are going to want to shut down your computer and disconnect the power from everything since the next step involves opening the computer case up. Remove the screws on thew back of the unit that hold the cover on, you will be able to see which screws do what. Open the cover up and take a look, the cpu cooler plugged with dust etc. Take the air can and styart blowing the dust and dirt out of the computer, also make sure that you clean out the poiwer supply as well. This will be the place where the plugin connects to the computer. There are fans and other things in the computer as well that you should blow out. If this problem is i/o this may just fix it for you.
Hope this helps
Jun 18, 2010 | E-Machines eMachines Desktop PC
My download stoped after it was sopposed to be done but stopd after it was done and then went to 50% because it became double what it was sopposed to at the end how do i fix it or do i hav to redownload...
Is your hard-drive out of room? Perhaps there is no room for your computer *to* install whatever it is. In your computer there should be a defragmentation option to make more room. Otherwise I'd recommend A: a seprate storage device or server to place everything in. B: A new computer. C: and if all else fails, I'd just try deleting useless software and old files you won't need.
Mar 21, 2010 | E-Machines eMachines Desktop PC
Hi, my 9 month old emachines monitor keeps turning off by itself, sometimes as much as five or six times a minute, otehr times not for 30 minutes. Any ideas?
Sounds like its the motherboard that is failing.
Since it's only 9 months old it should still be under warranty.
This computer will need to be taken in for service and the motherboard replaced.
Sep 27, 2009 | E-Machines eMachines Monitor E15T4
I bought the computer on january in walmart and now is not working and i went back to walmart and they told me that the company is the one that has to help me because they have one year guarantee what can...
Wallmart should have put you in touch with eMachine's support site so you can take advantage of the warranty, here is the web address >>>>>>>>
http://www.emachines.com/support/
Make sure you have all the documents that you got with the computer when you contact them including your receipt.
Good luck.
Jun 29, 2009 | eMachines W5243 Refurbished AMD Desktop...
Amana Air Command 80, 20 years old. Electronic ignition. Furnace does not start. Good power to furnace. Themostat properly set. Where do I start looking? Bob
Hello Bob,
Welcome to fixya,
You said, Amana Air Command 80, 20 years old.
Thermostat properly set.
Sounds like you possibly have one or more bad jets if the unit is a gas furnace!
Let me know how it goes.
Huuum
WOW, listen to this story!
I understand you are looking for the solution to fix your furnace your self.
But I want to tell you my story about my smart wife and our furnace.
When we moved into this house the furnace was 20 years old and she suggested that we put a new one that it will save us money.
I laughed at her and replied if it's not broken why fix it!
Six years later it finally broke down and I replaced the whole furnace and central air unit with a new one.
Our utility bill went down $100 dollars a month!
That's $7200. that I lost over 6 years due to not respecting my wife's power of reasoning!
If you can afford it or can get financing replace any unit 20 years old and it will pay for it self.
Can you imaging $1200. a year for 20 years is $24,000 dollars I'm saving with a new and efficient unit.
Do the math!!!!!!!!!
Thank You,
Huuum, Hope I gave you some good fatherly advice.
Please remember to leave a rating
Oct 12, 2008 | Amana Heating & Cooling
Monitor
Same thing is happening with my emchine as well. Mine is a T6412 series machine. I boought this machine a year and a half ago. Suddenly one morning the monitor started flickering. At first I thought may be some problem with the cables. I tried with different cables. Same problem. then I thought maybe my monitor has gone bad. So I went and bought a new Samsung monitor. Even with this new monitor the problem remained. So, I am assumng now that the problem is with my computer and not the monitor. Can someone please help. I do not usually come to this site. Can you please email me your solutions and help directly to amalandy@hotmail.com. Thank you so much for your help.
Jul 08, 2008 | E-Machines eMachines Monitor E15T4
E-Machines eMachines Desktop PC Logo
115 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
