Need to close vent on fridgedaire windo a/c - Heating & Cooling
Found the lever to close vent
Posted on Jan 01, 2009
Partsl news a 5 inch hose to vent out throu windo
Home depot or lowes should have 5 inch flex and a vent
Jun 12, 2014 | Windchaser PACR10 Portable Air Conditioner
I have a fridgedaire dryer, front loader. It gets wet inside on the door down through the lint filter, under the drum and out the exhaust. Think the problem is with the vent but can't figure out why. ...
2 questions are there more then 3 elbows in your vent run
and is any of it flexible pipe?
Humidity will infiltrate but should be infiltrating that much. One thing they make for dryer vents is a flap that opens one way to let air out, while dryer is running and closes when dryer is off. I don't think its humidity causing your issue. When you say the vent is straight does it run horizontal (even with the floor) or does elbow down and then run straight/horizontal?
Also about how long is the pipe run?
Aug 22, 2013 | Frigidaire FDE336RE Dryer
Picfica 2005 driver side come less hot air
Driver side vent is not pushing heat to the window, vent may be closed, or you may need to replace the cabin filter.
Nov 07, 2011 | Cars & Trucks
Fridgedaire Upright Freezer Door won't stay shut. Normally when closed, you hear the seal take place, now it pops open
Check the seal in the corners on the side of the door your hinges are on, ya may need to tack it down with crazy glue, but usually it'll curl in the corners preventing door from closing or pop open after you walk away
May 06, 2011 | Kitchen Ranges
I bought the fridgedaire dryer in 2005 and it has to run 3 times for ~40 min each to get the clothes dry. At first I thought it was from the # of turns prior to vent access in my apt (3 elbows and 30 ft...
due to the issue you had in your old home this is what id look for,,,,lint is bilt up in your unit remove the filter and use a dryer brush to clean lint as best you can,,,,,,second remove the vent hose from the back of dryer then with vent OFF try a load to dry if it drys in one setting then you have deturmind the dryer is ok but the vent hose is bad,,finally a bad thermostate or broken heater coil may be the issue and wold needservice,,,try the free stuff first thoe and good luckwww.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
My fridgedaire dryer will beep (cycle signal) intermitently during the drying cycle
Clean exhaust vent on rear of machine. Could be a overheating alarm going off.
Jul 08, 2009 | Dryers
1993 F-250 Vent windo broken
It's been along time but I think I remember the weather strip and all coming out together.
Nov 19, 2008 | 1994 Ford F250 Supercab
1990 dodge dakota windo wipers
I had the same problem and here is what I did. First remove the wiper arm from the motor using a 7/16 wrench. Once the arm is off remove the old bushing ( mine fell off completely). Next I moved the washer arm so it sticks out of the vent cover. Get the new bushing and line it up to the arm. I then put a socket ( I used 11/16)on the back of the arm and used a c clamp to push the bushing into the slotted hole. Back the clamp off and line up the drive arm with the hole in the bushing and retighten the clamp. Apply pressure until it seats completely.Once done you can replace arm to the motor. Test wipers to see if the bushing is going to stay seated. You are now ready to replace vent cover and cowl.
p.s. I have pictures that need to be resized before I can post
Oct 15, 2008 | 1990 Dodge Dakota
Fridgedaire FWX233RES4 top loading washer won't drain or spin.
check the lid switch. it is the one closing when ever you close the lid of the unit.
once the lid is close, the contact should be closed, if the lid is open, the contact is open also.
tnx 4 using fixya,
drcool
Sep 15, 2008 | Washing Machines
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
