Question about Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television
The picture is too large for the screen
All of a sudden the picture is too large to fit the screen. The top and bottom of the screen does not fit in the monitor cutting off the top of people's heads and the bottom, subtittles and program information on the bottom of the screen is not visible. The remote has a vertical and horisontal adjust buttons, I have not been able to figure out how to make the image smaller. Any help?
  • 1,284 Answers
Re: The picture is too large for the screen
If you have a cable or satellite HD box see if there is a ASPECT button or look for an aspect/picture size buttn on your TV's remote control.
Posted on May 07, 2007
0 characters
3 Points
My TV picture is too large for my screen, suddenly, how do I get it formatted to fit the screen
Look on your remote for a button that says aspect or ratio. Push it until it selects what you wanted.
Sep 28, 2015 | Flat Panel Televisions
Samsung 32 LCD TV; Image horiz size is too large overruns screen L-R; See Details for more info What is the root cause & how can it be corrected? Thanks, Steve
try getting the onscreen menu up and then going to the aspect ratio setting
change that until the picture fits the screen
go -ok then exit
Sep 27, 2015 | Samsung Flat Panel Televisions
Youtube on my vizio 470i tv is off centered
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Flat Panel Televisions
Our picture is too large for the screen. Doesn't matter what format we have it on, the top, bottom and sides are all missing.
Find on the renote button said P.size or View mode change it to diffrent modes, that fit ur screen or normal or mode like 16:9.The picture should fit find now.
Sep 13, 2010 | LG 42LC2D 42 in. LCD HDTV
Picture too large for screen
mine did not fix, picture is still huge and pushed to bottom of screen so the top is black all the way across
May 27, 2010 | Westinghouse SK-32H240S Television
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
The picture is to large for the screen. The
Try changing your Aspect Ratio, look in your manual.
Feb 09, 2010 | Flat Panel Televisions
Picture is cut off
Try setting the set to 4.3 expanded on the aspect ratio. If that don't work try the other aspect ratio settings. That should make the picture fit the screen.
Jun 23, 2008 | Insignia 37" LCD Flat-Panel HDTV
Picture is too big for screen
Go into the setup menu of the TV, and you'll find a category called DISPLAY or ZOOM. That's where you can change the aspect ratio so that it fits on the screen. You'll probably get a gray band on the top and bottom of the screen due to the re-sizing.
Sep 02, 2007 | Flat Panel Televisions
Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television Logo
1,267 people viewed this question
Top Sylvania Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Justin Peters
Are you a Sylvania Flat Panel Television Expert? Answer questions, earn points and help others
