Question about Toshiba CZ36T31 36" TV
Toshiba 289X6M CRT TV has no power with a blown T3.15A/250V fuse
A Toshiba 289X6M 29" CRT TV has no power and cannot be turned on. I found a blown T3.15A/250V fuse. What could be the cause of it? After I replaced the blown fuse, it blew again every time a short while after I turned on the TV. Could you tell me how can I fix the problem?
  • 163 Answers
SOURCE: Toshiba 27A30 that blows Fuse
hey this one was posted agust 6 do I geting crazy or what? agust 7 agust 6 the same day?
Posted on Aug 07, 2006
  • 81 Answers
SOURCE: TV Problem After Lightning Strike
check the diodes or the regulator. the diode are most likly shorted that the 4 d's like d800, d801,d802,d803
Posted on Mar 20, 2007
  • 700 Answers
SOURCE: Toshiba TV Red Color turns black and regains after a long time
If this is a crt type, it could be a loose connection. Check its RGB board usually located at the backend of the crt tube. Dust, cobweb, carbon built up might be the one causing it.
Posted on Apr 18, 2009
  • 139 Answers
SOURCE: Moving TV. Got bumped twice. Plugged in and no
MOVING CAUSES. ITS A GOOD CHANCE THESE BUMPS CRACKED THE CIRCUIT BOARD. ALSO IF THE TUBE IS BROKEN, LOST ITS VACUUM.
Posted on Dec 27, 2009
  • 19 Answers
SOURCE: TV blew fuse. Replaced with
replacing the fuses with random values is prolly not a good thing...but one thing to check is a big transistor know as the HOT. This will more than likely be clipped or screwed to a heat sink NEAR the flyback (big transformer, has a wire going into the big glass tube). That causes fuses to blow...If this does not work, let me know.
Posted on Dec 01, 2010
Fuse blown on incoming power replaced fuse but no luck
replaced the t8ah 250v fuse and it still blow when i turned on the tv
Oct 19, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Does toshiba 27d46 have a reset button? my tv will not turn on and the led light is not on either. checked the power cord & outlets. help!!!
check for the blown FUSE after the power cord.Check standby power section for a defective component.
Apr 27, 2010 | Toshiba 27D46 27" TV
No power to TV - No Screen - No sound
check the fuse, I found my had blown and that's what it was sort of. Light doesn't flash any more but nothing comes on
Aug 10, 2009 | Toshiba 32HFX72 32" TV
I have a Philips 42" Plasma that will not power up, blown T8AH
http://www.newark.com/littelfuse/0215008-mxp/cartridge-fuse/dp/42K9308
Fuse is a "Littelfuse 0215008.MXP"
8A 250V Slow-blow ceramic
Jul 29, 2009 | Toshiba 50HP95 50 in. Plasma Television
I have a wega 29 inch tv. it does not turn on no
Check the fuse in the plug has not blown.
Check that the power socket is working for other devices by trying them where the TV would normally plug in.
Jul 07, 2009 | Televison & Video
TV WONT TURN ON
I fixed it myself. I found that the t6.3 amp/250v fuse had blown. I bought the fuse at a television parts supplier for $2.00 put it in and it worked.Hooray! It has been working just fine now.
Nov 23, 2008 | Sony KV-36FS17 36" TV
No power no picture no sound
You have a shorted power component. Probably either the voltage regulator or the Horiz. output transistor. Both will be mounted to a heat siink of some type. The Horiz. power circuits along with the flyback transformer power up 90% of most TV sets.
Geno
Feb 16, 2008 | Televison & Video
Philips 27PT6442/37 power
Sounds like you have a short in your power supply load. Probably the high voltage transformer and/or horizontal output transistor. Stargazer P.S. I've found that a lot of the newer sets are prone to high voltage transformer failure.
Aug 11, 2007 | Philips Magnavox 27MS343S 27" TV
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
Toshiba CZ36T31 36" TV Logo
810 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
