Cars & Trucks Logo
Posted on Jan 01, 2009
I have a 2000 subaru legacy on which the battery was was connected wrong, something got fried i think, not sure what. I can't get the ignition light on.
Donald Laurie Thunder
Level 1:
  • Contributor 34 Answers
  • Posted on Jan 01, 2009
Contributor
Level 1:
Answers
34
Questions
Helped
5420
Points
56
Check the fuses, they're located under the hood and in most vehicles they are under the dash or in the glove box. and check the fuse able link the leads from the alternator to your ignition module. When the battery was hooked up wrong it fried some fuse or the fuse able link, or even the bulb for the ignition light located behind the dash board. you can email me at [email protected] and I'll check my manuals.
Nissan maxima 2000, related ignition switch but still as soon as battery is connected the relay clicks (near battery 3rd one) and tries to start the car without even key in the ignition...
the relay should not have any power to it. i would think there is a sort some were on the ignition. i would check the ignition wiring and make sure its not damaged or assembled wrong. relay should only get power when the key is in ignition and turned to start engine.
I have a 2001 Subaru legacy limited When I connected a new battery to it you did nothing but honk along with no dash lights or ignition I've gone through the fuses and the Relay and disconnected horn
I think maybe your security has locked you out, look in your manual for security relearn instructions.
to show your appreciation press the helpful button and follow me on fixya for more tips and info.
2answers
Replaced battery about a month ago. After about as
Could be a poor connection on one of the battery terminals - be sure they are tight.
Could also be a starter solenoid that is sticking.
1helpful
Brake light and battery light keep coming on without any particular reason
Have the charging system checked it sounds like an alternator problem
3helpful
I dont know where my thermostat is in my 92 subaru legacy, but i think theirs something wrong with it. I have a brand new adiator, but my car is overheating still?
The thermostat is mounted low down on the bottom of the engine where the large radiator hose connects to the radiator. The housing is bolted to the engine block and the thermostat is inside. Don't attempt to replace it unless the engine is cold otherwise you will burn your hands. Make sure you bleed all of the air out of the system before driving off.
2000 legacy
Absolutely! This could Definately Fry the Computer System!
6helpful
My running lights will not turn off unless I unhook the battery.
Subaru Outback Legacy Flashing
Q. I have a 1996 Subaru Outback Legacy AWD manual transmission. the hazards flash when I turn the car off. I tried to reset the system by pushing the little black button under the drivers' side dash but it won't reset the system. I had problems with the brakes so I did not drive it for about two months and when I tried to start the car the battery was dead.
mechanic.jpg Now the brakes are fixed but the hazards won't quit flashing and the guy who repaired the car said I needed to reset the system by pushing the little black button. And I don't know if I should have it looked at, or change the battery, or if it is something very simple I can fix by my self.
Thank you very much,
Patrick
A. Patrick, you are the third person in the last two days that has come to me with this same exact problem under the same conditions. As of now I don't have any concrete information on this, but I believe the problem to be in the alarm system.
I believe the battery being disconnected or dying does something to the Anti-theft and Alarm System module and having a Subaru dealer reset the system will correct it.
If you do this and it works, please, let me know and I will pass the information on to the others.
Added 11/7/2003
Dear Mr. Ciulla,
I read your Q&A titled "Subaru Outback Legacy Flashing". I recently had the same problem on my 1996 2.5 liter Subaru Legacy Outback and your response is correct but I can give you a little more detail on what worked for me to stop the light flashing (which occurs sometimes if the battery had been dead):
There is a black reset button under the I/P near the anti-theft module.
  1. Turn ignition on
  2. Hold button 20+ seconds (door locks will lock/unlock 3 times)
  3. Turn ignition off
This also resets the key FOB so as step 2.5 you should also press the "lock" button on the key FOB before releasing the black reset button (door locks will lock/unlock one more time--do this with each key FOB you own). That's all!
The questioner in your Q&A said he tried the reset button; I suspect he either didn't turn the ignition on/off or didn't hold it in for over 20 seconds.
PS... pulling the door lock fuse will stop it temporarily if you can't get the above to work and have to take it to the dealer
Regards,
John
Photo Courtesy John Spieth ©2003
Additional Information provided courtesy of ALLDATA
Top Subaru Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Oliver Street
Are you a Subaru Expert? Answer questions, earn points and help others
