Question about 3M Projection Panel 6400 Multimedia Projector
3M Projection Panel. Model Number 4180
I have purchased the above projection panel from a car boot sale for £5 but I dont know how it works, what power I require, I have tried a old power supply from a laptop 24v DC at 1.5amp and nothing seems to hapen also I presume this would plug into my computer so any idea wher I could get the software that would be required. The equipment looks in very good condition and I can see no reason why it should not work. Do you think you could possibly help me with this. Thank You.
  • peter walker May 07, 2007
    I now know what this actualy does I stand it in or on a overhead projector and then a computer image can be projected through same however I am still unable to find any spec on it (Power Requirements) and (Software)
    Can any one help please.
Input ac 120V 60HZ 40 W
output DC 12V 1.5A
as to any other functions I have no idea
Posted on May 24, 2008
How do i fix the red screen projection
the lcd panels are fault,you need a new ones
USD200
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Dec 02, 2014 | 3M DT00841 Compatible Lamp for 64W
Dont have the model number as i am at work however it is an older model projection tv. I think it is 65in looks like the one above. However i came home turned the tv and the picture is distorted. the...
Picture distortion in your rear projection TV is because of failure of convergence out ICs that need to be replaced.
Qualified TV tech will fix it under $150 or $200 and if your are good in part soldering in circuit boards and have electronics knowledge then can replace by yourself.
Required ICs can be purchased from Part Store.
Oct 27, 2009 | Sony KP-57WS500 57" Rear Projection...
Don't have a remote control for this lxi projection television purchased at garage sale, not getting channels, can only view movies
hi, doesn`t have tv/video button on front of set ? LXI is a sears trademark, bring complete model number to any sears repair center and they can get you a remote for it, gl, video-tek
Jun 04, 2009 | Televison & Video
MAGNAVOX PROJECTION TV- GOOD PICTURE , BUT NO COLOR
you need the ssm panel. You can get a replacement panel for your model at the following link.Which is the correct board for your model it controls color, convergence and etc.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-ptv900-series-ssm/cName/sale-items
Apr 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Info
Hi, the M3 6400 doesn't have a lamp; it is an overhead projector (dynamic) display which needs an external light source. When you start it en put a ordinary lamp behind it and after connected it to a 'source' (computor...video) you will see images appear.
Aug 21, 2008 | 3M Projection Panel 6400 Multimedia...
Mitsubishi tv won't turn on.
Whats the model number of your set? Also try pressing in the menu and input/device buttons both in together on the front panel for 5 seconds to see if the set blinks a two digit error code. Then let me know the blinks and your model number. Please respond to this same post when replying.
Aug 09, 2008 | Televison & Video
Convergence is not working...i've been reading about it and i know that's the prob.The prob for me is that i dont know what kind cause i don't have the exact model for my tv i just know it's 50 inch and...
The model number should be on a tag on the back panel. If you can post the moel number I can post the correct Ics and also a link where you can get replacements with free instalation instructions. If you cant locate the model number does the tag satet the year of manufacture?
Jul 04, 2008 | Televison & Video
3M Projection Panel
Based on your post/description, I will assume that you would want to connect a PC to a Projector.
For a 3M DY-0205-1002-9, pls contact:
3M Customer Information Center
Hale Avenue Business Center
3M bldg. 506, POCS Destination Code 0444
835 Hale Ave. North
Oakdale, MN 55128 Fax: 651-736-6320
or try
3M Visual Systems
1-800-328-1371
(Fax) 512-984-5105
Internet: www.3m.com/presentation
Email: OHP - presentations@mmm.com
EPS - techsupport@mmm.com
Should you opt for a replacement, you may want to consider DVI to VGA Analog Video Cable or similar products.
Alternately, you can use a converter box that will accept VGA inputs but whose output is DVI-D compatible. A fine example is VGA to DVI Converter/Scaler but of course any comparable brand/model should also work.
Hope that these be of help/idea. Pls post back how things work out or should you need further information.
Good luck and kind regards.
Dec 23, 2007 | 3M Projection Panel 6400 Multimedia...
Green lamp/bulb
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence
Dec 07, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Need user''s manual for 3M 6650 Projection Panel
do a search 3m's website or on price.com or pricewatch.com or pricescan.com or pricegrabber.com, then look for "specifications" link...sometimes you may find a downloadable pdf file there.
May 24, 2007 | 3M Projection Panel 6650 Multimedia...
3M Projection Panel 6400 Multimedia Projector Logo
531 people viewed this question
Top 3M Office Equipment & Supplies Experts
ray gallant
Tom Chichester
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
