Power cord cut
I recently got my brother's old Sansui receiver amplifier (for home stereo, not auto) from my mother. At some point in time, the power cord was severed. Can it be spliced to put a new plug on the end, or is that a bad idea?
  • 8,197 Answers
Yes you can splice to put on a new plug that is ok.
Good Luck and Please Rate FixYa!
Posted on Jan 01, 2009
I have a sansui 14" tv.14 yrs old.there is showing 220volt supply at antenna & audio video receiver point.what's the fault.how I will rectify it.thanks
The antenna & Audio Video receiver point should not have mains power getting to it. Especially the antenna which is the aerial. If the aerial has 220 volts on it you would get a lethal electric shock every time you plugged in the aerial lead!
There is clearly something wrong with the units power supply if 220 volts is getting to that part of the unit.
Aug 31, 2016 | Sansui Audio Players & Recorders
Tip
Tips on how to get the best value with your home entertainment music system
1.Your largest investment after your HDTV should be in your home audio amplifiers, not your speakers 2. Specific brands of AV receivers are known for having exceptional music fidelity
3. You need a specific minimum power capability to achieve great audio sound
4. Why you want a 2 channel stereo music system
5. Stereo music and home theater surround sound need completely different power amplifiers
6. AV receiver vs separate audio power amplifier components
on Aug 23, 2010 | Audio Players & Recorders
K&K AT-306 RECEIVER AC220V/50HZ THE POWER CORD IS A two prong Converter For 110V Voltage WHAT KIND OF Adapter DO I USED
It depends which supply you are plugging the unit into. If it's 220-250 mains supply in your home, you can just cut off the old plug and stick a European plug on it. Since the unit is designed to run on that. If it has a voltage selector on the receiver make certain it set to the 220 one.
Jun 13, 2016 | Audio Players & Recorders
Where to find the owners manual for the Sansui QRX 7500A?
Sansui QRX-7500 Manual - Four Channel Receiver - HiFi ...
www.hifiengine.com/manual_library/sansui/qrx-7500.shtml
May 21, 2014 - sansui qrx-7500 four channel receiver. Sansui QRX-7500 ... service manual English - honestsoul99. Related Catalogues. HiFi Buyers Guide.
Sansui ' Hifi Manuals Free: Service Manuals, Owners ...
Dec 19, 2015 | Audio Players & Recorders
Where can i buy a power transformer for Sansui 3900z ?
Let me guess...you took it somewhere for repair, and they told you it had a bad transformer and they couldn't fix it (after they took your money). Sansui began life as a transformer company, and unless something really silly was done (like replacing the stock fuse, which is probably 3 or 4A with a 15A fuse of something). I might mention that 'some' units sold for various locations have a thermal fuse installed internally to the transformer. I dunno if your model has this or not. I mention all of this because often times the phrase 'it has a bad transformer' is lame techspeak for 'I don't wanna fool with this thing'. If it blows the mains fuse on power up, then the most likely fault is that it has blown power transistors at the output of the amplifier. If it 'really' has an open primary winding in the power transformer, then it may well have a thermal fuse that has opened. Gary Brown in Orono, ME has fixed a few transformers for me with this issue. Google can help you find him.
Dec 24, 2014 | Sansui 3900z Stereo Receiver
Sansui A200 amplifier dead right channel
Usually is a capacitor or diode blown open up the amp and look for any burnt marks on the motherboard
Feb 07, 2014 | Sansui Audio Players & Recorders
I have a Sansui 2000A Stereo Tuner Amplifies that powers up but has no sound. the fuse for the 220-250V 2A was blown and replaced. The speaker fuses look good. Should I replace them too or is there...
If the fuse was blown on the 220-250 V side, I am assuming that you are in the UK, if you aren't , but are in the US, change the power setting dial/switch on the back to 100-120v and you might be good to go. Also, I know this may sound silly, but make sure that the speaker selector switch is pressed in or set to a speaker set ( A or B). Love the Sansui gear, have many complete systems myself!
Oct 17, 2013 | Sansui Classic Vintage 2000a Stereo...
I need a power cord for a Brother typewriter model no. 3112
There are 2 basoc cords one looks like a figure 8 the other looks like a 1.5 x 1/2 inch rectangle with 2 corners cut off used as a power cord for most computers.
DickyO
Mar 28, 2013 | Brother Office Equipment & Supplies
Stereo Amplifier fades out. My Sansui dolby pro
No that's how to describe a problem, folks - with details. Using internal FM as the source is always the preferred way of troubleshooting system-wide receiver audio problems (no cables or setting in the way).
Does the sound come on immediately with power and then fade or is there a small delay while the electronics stabilize, a click and then sound that fades?
The fizzle probably means something is rapidly overheating or a capacitor is malfunctioning. If both channels do it, I'd suspect a common power supply problem. Can't help much more than that.
Dec 12, 2009 | Audio Players & Recorders
Stereo integrated amplifier a30, turns on some times
A few things to check:
- a bad power cord or connector to the unit on the cord (if any), bad power connector on the unit (if any) or bad connector soldering on the circuit board (replace cord or resolder/replace connector if necessary)
- main power switch could have dirty contacts or some damage (needs to be cleaned or replaced)
- an electrolytic filter capacitor (any of them) could be dried out, blown (bulged at the top), badly soldered or otherwise faulty (should be replaced if faulty and resoldered if there is a loose solder joint)
- a connector (any of them) could be loosely plugged, oxydized or have bad solder joints on any pins (connections should be checked, dirty contacts cleaned, loosely soldered pins resoldered)
- any other components could be poorly soldered or damaged (resolder or replace, as necessary - might require technical service to establish which components are bad, if any)
Note that the problem may be any of the above, a combination of any of the above or something entirely different, i'm just pointing to some possible causes/solutions.
Hope you can fix it.
regards
Triarcuate
Sep 21, 2009 | Audio Players & Recorders
54 people viewed this question
 Grubhead
Grubhead
