Question about LG LSC121PMA Split System Air Conditioner
LG C12AWR Air conditioner head fan not working
My airconditioner internal fan on my split system stopped working in the middle of the night and i have reset the power and checked the gas pressure and it is sitting at 0 degress celcius the evaporator is getting cold and the compressor and condensor fan are both running but for some reason the internal fan will not go anyone have any ideas
  • CJTdeA Jan 02, 2009
    LG split Lsk2463hl.
    Internal fan not working (suddenly). All else functioning. Any advice would be appreciated.
    C and L.
  • Ken Bledsoe May 11, 2010
    Fan could be bad. Do you have volt ohm meter?
  • 400 Answers
Check that the fanmotor can spin freely. If not, can be caused by seized bearing on left side of fanblade, or foreign object, insect nest stuck in fanblade. If however it spins freely, check that fanmotor is being supplied with voltage (you sound technically capable of operating a volt meter). If power is supplied, fanmotor is faulty and needs replacing. If no voltage, problem lies with the pc board. If you know someone who is capable let them check the relays on the board. Also you can check that all plug on connectors are making good connection.
Posted on Mar 05, 2009
I got a C9 error on a C12AWR artcool split ac which doesn't work anymore i replaced the mainboard of the outdoor unit which didn't help i replaced the fan motor which didn't help either does...
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB. Multi V
= indoor PCB failure. Replace PCB.
Let me informed again if problem persists,.
Oct 25, 2011 | LG LA185HV Split System Air Conditioner
Error code E6 Pioneer Split system room airconditioner
E-6 Outlet pipe sensor open/short circuit. Replace it.
Nov 13, 2010 | LG LA141CE Split System Air Conditioner
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | LG Art Cool LA181CNW Split System Air...
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Heating part of split system not working but fan outside is
if the cooling is ok then the reversing valve outside may be faulty
May 28, 2009 | Heating & Cooling
Dont know what symbol on remote is for heating for LG split system airconditioner
On mine, it's the symbol on the right-most one of 4; looks like a sun-symbol with several single lines emanating outward from the circle.
May 19, 2009 | LG LSC121PMA Split System Air Conditioner
Hi my split airconditioner is leaking water inside the house
YOU DRAIN IS STOPPED UP, FIND WHERE YOUR WATER DRAINS OUT AND CHECK THE END AND SEE IF IT IS BLOCKED OR YOUR DRAINED IS STOPPED UP INSIDE WHERE THE COIL IS.
Jan 05, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
423 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
