Question about Rockford Fosgate Punch 401S Car Audio Amplifier
401s Rockford Fosgate Amp. Not turning on. No power light. Pos+ and GR- are solid. Thought it may be remote, so tried running a wire from the POS+ to REM to test it, no luck
  • 15,935 Answers
Amp Failure:
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors:
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note:
I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit.
These repairs are best left to a repair tech familiar with car audio amplifiers. Check with your local shop to get a reccomendation. If the light isnt even coming on, chances are your input or power supply has been taken out.
Posted on Jan 01, 2009
Amp wont turn on and theres power to the amp and the fuses are good
check the ground to the amp. then check the remote wire. make sure u have the sub option on ur stereo turned on. if all is wired up correct an u do not have the subs turned on in ur stereo settings then the stereo will not send power through the remote wire an therfore your amp will not power on.
Apr 04, 2010 | Rockford Fosgate Power T3002 Car Audio...
How to install a rocksford fosgate power 800a4 amplifier?
you will have to get a amp kit. run a power line from the battery to the am and a remote line from the radio to the amp then run a ground from your car from (scratch the paint off) and connect that to the amp,connect your speakers to the amp.
Mar 23, 2010 | Rockford Fosgate Punch 401S Car Audio...
What is the auctual watts fpr the Rockford Fosgate Punch 401S?
rockford fosgate doesnt have watts its considered monoblock it gives off watever the speakers want....it gives them the power they need
Dec 29, 2009 | Rockford Fosgate Punch 401S Car Audio...
Does the Rockford 401s amp have a fuse?
Yes. Rockford fosgate has a cover over all of the connections, crossovers, and various other controls. Just remove the cover with the allen wrench they sent with the amp or find a set of allen wrenches if you don't have one. Under this cover you'll find what you're looking for.
Nov 28, 2009 | Rockford Fosgate Punch 401S Car Audio...
401s Rockford Fosgate Amp. Not powering on,just protect lite is on.
try hooking the remote wire to a rem wire on the back of stereo. post and let me know results
May 30, 2009 | Rockford Fosgate Punch 401S Car Audio...
Amp or something cutting out.
Power caps store power from the battery and they feed constant power to the amp so you dont get no drainage! this could be one reason..
have you bridged both subs and wat gauge wire are you using.
these amps can only handle one bridged sub at 4ohms and this amp is recommended that u use 8gauge or higher. if your running to subs i normally reccomend using 4 gauge power wire as you get more rms power feed to the amp
you can get a power cap or anyother accersory cheap online at my suppliers.. caraudiosecurity << click to enter >> hope this helps and please rate me :)
Apr 22, 2009 | Rockford Fosgate Punch 401S Car Audio...
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Rockford Fosgate Punch 401s starts then smokes
Can somebody email me the schematic for the Rockford Fosgate 401S?
Feb 04, 2009 | Rockford Fosgate Punch 401S Car Audio...
Rockford Fosgate Power T20001bd goes into protect upon power up.
In most of Rockford's amps, the low voltage detection is connected to the remote input. If the remote voltage is too low and they use the same circuit on this amp, it could trigger the protection circuit.
Disconnect the head unit's remote from the amp. Use a fuse holder with a 3 amp fuse to jump between the B+ connection and the remote terminal of the amp. If the amp powers up, the head unit's remote output may be defective. If it blows the fuse, the remote input or part of the power supply is damaged. Do not try it with an unfused jumper.
Oct 21, 2007 | Rockford Fosgate T20001 bd Car Audio...
Rockford Fosgate Punch 401S Car Audio Amplifier Logo
574 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
