Question about Toshiba Satellite A105 Notebook
Laptop will not come on
I have a toshiba laptop. A few days ago the computer was frozen on the screen saver so I tried ctrl-alt-del and that did not work so I turned it off and waited and turned it back on again. Well nothing happened. The lights come on, the hard drive light just for a second, but nothing else happens.
Please help.
  • Toshiba Master
  • 5,568 Answers
Although other possibilities can be at fault, if it does so little after power on, the CPU itself may have failed. The very first actions a PC does when turned on is to read the information stored in the CMOS to determine what hardware is on board. After doing this, it turns to the hard drive for a check to see if it is readable and then the CPU (your microprocessor) Intel or AMD takes command. If the hard drive is at fault, a message will inform you that the hard drive either cannot be found or is unreadable. If the hard drive light flashes once, then the BIOS  has made contact and then the hand-off to the CPU begins. If it is stopping dead at that point, the CPU is the prime suspect.
What fairly often happens is first a failure of the CPU fan that sits directly on the heatsink that transfers the heat from the CPU and then the heatsink is bathed in air from the fan. If the fan has failed (all too common) or is impeded by a dust accumulation, the CPU overheats and if the maker has not made any provisions to shut down the CPU, it dies.
There is a possibility that this kind of problem can be caused by a failure of the RAM (memory) but establishing what has failed is only possible through substitution of one or both of those devices.
If you are somewhat skilled, opening a laptop requires small Phillips screwdrivers to remove case screws from the side(s) and bottom, then the case still (in most cases) needs to be carefully pried open. The mating halves normally snap together as well as being fastened with said screws.
Most likely the keyboard will also have to be freed from a couple of screws and, depending on the length of the flat cable connecting it to the system board, can be pulled forward before or after the cable is pulled.
The CPU will be easy to spot; it's one of the large clumps on the board. Check its fan to see if the blade turns freely and is not impeded by dust (these things have hardly any torque), then with two fingers, positioned on either side of the blade, check to see if it rocks side to side. This would be an indication that the bearings have failed and it will need to be replaced.    The CPU is held by clips but make sure you have no static charge before removing any internal part. Just 'equalize' the charge by touching an exposed metal cover or other chassis part. Memory is normally accessible from the bottom of the case.
Now comes the bad news; there are still myriad other components that can keep a PC from booting when no error message is present since there are numerous support functions which can interfere with the startup of system. I've given you the most likely points of failure; CPU or memory.
Posted on Jan 01, 2009
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Apr 03, 2015 | Computers & Internet
Laptop screen upside down
Nope. Hold the CTRL key and the ALT key down, and at the SAME time tap on the Up arrow key. That\'s about it
Regards,
joecoolvette
May 07, 2013 | Toshiba Satellite A105 Notebook
My toshiba c850 is in flight mode, how do i get out of this?
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
If this fails you might try some of these Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Feb 04, 2013 | Toshiba Satellite Computers & Internet
I have a Toshiba A505-S6960 laptop. Never have had a problem until today.......when I turn the laptop on it goes through the boot process but only makes it to the Toshiba logo screen with the F2 and F12...
It seems that your computer is not seeing your hard drive. This could either be because of bios settings or more likely because the hard drive has failed. If the unit is under warranty, call Toshiba support and describe the issue to them. If not, places like Best Buy can determine for sure the cause of the issue.
Toshiba Support
May 16, 2011 | Computers & Internet
MY LAPTOP WONT GO TO THE START MENU
you need to click ctrl+alt+del hit cancel and it will work :)
Jan 17, 2010 | Toshiba Satellite M55-S135 Notebook
Screen saver freeze
Its probably your graphics card or driver. Try changing your screensaver to one without animations, if that fixes it you need to look into your graphics processing.
Mar 25, 2009 | E-Machines T6520 PC Desktop
TOSHIBA A135-S2386- I HAVE AN ERROR WHEN TURNING ON MY LAPTOP
You most likely have a faulty hard drive, especially if it is making a clicking sound.
You wil need to purchase a new hard drive and install Windows again with the Toshiba Recovery CD.
Jan 21, 2009 | Toshiba Satellite A135-S2386 Notebook
Can not get laptop to enter bios
On many of the MPC laptops, the bios can be brought up at boot by pressing the F2 key. Generally, while booting, the screen will show you the button to push. Here are some more of the most used key combinations you can also try. On our mpc support site, there is no manual available yet for this model. Also, mpc laptops have the capability to lock out the bios at users request so many used models obtained cannot be changed. We'll have a new support site for mpc up this summer. Details at mpcsupport@cox.net
Most of the time during boot-up the key (combination) will be shown. If it is not, then you could try the following key combinations:
  • Del
  • F1
  • F2
  • F10
  • Ins
  • Esc
  • Ctrl+Alt+Esc
  • Ctrl+Alt+Enter
  • Ctrl+Alt+Ins after Ctrl+Alt+Del
  • Ctrl+Ins
  • Ctrl+Alt+S
  • Ctrl+S
  • Ctrl+Shift+Esc
  • Shift+Ctrl+Alt + Num Pad Del
  • Ctrl+Esc
  • Ctrl+Alt and +
Dec 25, 2008 | MPC Computers TransPort T3000 Notebook
I hit a button or something and it made my toshiba computer into a tablet or somthing. i dont know how to make it go back into a normal mode. its toshiba a215
Is your screen sideways or upside down? If so, use this:
Just like a ctrl-alt-del except
press ctrl-alt-up arrow
ctrl-alt-down arrow flips it upside down.
ctrl-alt-left and right arrows will rotate the screen sideways.
Dec 12, 2008 | Toshiba Satellite A215-S7422 Notebook
Won't Stay On
http://www.laptoprepair101.com/laptop/2006/04/06/satellite-m35x-a70-a75-lockup-freezes-reboots/comment-page-7/
May 19, 2008 | Toshiba Satellite 1115-S103 Notebook
Toshiba Satellite A105 Notebook Logo
76 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
