Question about Pentax Optio 30 Digital Camera
Lcd No image on the LCD monitor, the monitor stays black at all times.I need help, I can't take any pictures.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 60 Answers
Hi, i too had the same problem, try to zoom in and out after power on and check any image on lcd. This is due to zoom unit movement had broken the contacts with the sensor. Mine got corrected in pentax service with $40(india) sreejith
Posted on Jul 06, 2007
When I turn my Toshiba laptop on,it's black
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 26, 2009 | Toshiba Computers & Internet
Screen comes on then goes out in 5 seconds. The backlight goes dark but the seen is working, just can't see it. The backlight is out...
mark587, Did you shine a very bright flashlight 1" from the screen to try and see the WIN-desktop ?? Even though the screen appears BLACK. Your words above said: JUST CAN'T SEE IT Did you really NOT see anything? Have you seen any of the longer video clips of "LCD Monitor Disassembly" on YOUTUBE? Some BLACK screen "symptom" lcd displays can be repaired for less than $10 in parts. Capacitors! Also check videos on lcd repair. Then get back here to fixya and I or any of the guys can help you decide what to do with your display whoose screen is now dark and lifeless. After doing the YOUTUBE thing you may even tell us what you will do!!! Hope this was helpful. Yes we do want to hear back from you. please rate this response on fixya. I'm louie12fix on fixya or lmistyrel @ aol.com. Bye for now.
Oct 07, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Monitor blacks out
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 12, 2009 | E-Machines eMachines Monitor E15T4
I have a Gateway M-6843 Notebook PC that won't power up.
Check out
www.lcdparts.net
Sep 06, 2009 | Gateway 7405GX Notebook
Monitor flickers or 1/3 turns black, have tried wiggling cable, and moving/tapping monitor, sometime it works great, other times i fight this every few min. Doesn't matter if i turn computer all the way...
You may have a faulty inverter or loose power inverter connection. OR
Check out
www.lcdparts.net
Aug 31, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Computer is on, screen stays black
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 04, 2009 | Acer Aspire 3690-2196 Notebook
Toshiba satellite a135 monitor goes black
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S2386 Notebook
Lcd screen black on laptop. External monitor works.
Defective CCFL backlight may has the following symptom:
Mar 31, 2009 | Dell Precision M60 Notebook
Pentax Optio 30 Digital Camera Logo
71 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
