SOURCE: Toshiba TLP S30 projector
http://www.projectorcentral.com/projector-lamps-faq.cfm
see this
Sergio
SOURCE: how to reset lamp timer for a TLP 671
Hi there folow the link bellow for the manual
Regards Al "alstech"
http://www.fixya.com/support/p147512-toshiba_tlp_671_multimedia_projector/manual-15037
SOURCE: toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
SOURCE: I have a Toshiba TLP
If you let the lamp go all the way out, there is a chance that it took out a fuse when it went out. This would require you to get the unit serviced and it will not be cheap.
Please dont forget to vote this answer was helpful
Many thanks
