Question about Mitsubishi VS-60607 TV
My vs-60607 has waving lines
10 to 15 minutes after start up the lines go away, and a couple of times the top half of the screen has gone black, what might be the problem, thanks a loyal mitsubishi tv owner
  • Frank Heusser
    Frank Heusser Mar 13, 2009
    my vs60607 has all lines through the tv until it gets warm. that could take up to an hour. what might be the cause.
    Problem Solver:
  • 7 Answers
Postive 9v regulator on the signal board and possible capacitor right next to it. the regulator is generic 7809. if you test the output it will be 6 or 7v needs to be 9. when the lines go away it is warm and will read 9v. so do the test cold. i'm assuming you know how to use a multimeter. if not then a local repair shop can do this for you.
Posted on Feb 05, 2009
Mitsubishi vs-60607 60" screen is
when picture is getting smaller in size or goes away or moves towards one side then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 22, 2011 | Mitsubishi VS-60607 TV
I have a 9 year old mitsubishi projection tv
Could be a problem in the high voltage section or a bad signal board. Let the TV tech do it.
Good luck
N Sabre
Nov 08, 2009 | Mitsubishi VS-60607 TV
Horizontal lines running on screen
There are some transistors attached to heatsinks (small heatsinks) on the left portion of the chassis. this board that has the input board attached to it is the signal board. those transistors are regulators they are labled 7809 or 7805 depeding if they are 9 or 5 volt regulators. use a multimeter to determine if one pin has 9v (or 5v) coming from it. if not this is your problem. i see alot 9v regulators going bad, some take the cap attached to the 3rd leg with it so check that too. if this sounds overwhelming it might be a job for a repair tech.
Jan 07, 2009 | Mitsubishi VS-60607 TV
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Lines across the screen
we just picked upi a VS-60607 60 inch projectoin tv,  There are several issues with this television.  when powered on the colors are allconstrued and teh image is often chopped and warped, we hooked upi the cable yet there are only two local channels recieved and the power will turn off randomly every severl minutes.   Any thooughts?
Jul 07, 2008 | Mitsubishi VS-60607 TV
I get sound but the sreen is black
Try a "hard restart" , which simply means unplugging the power cord of the TV, then replugging it after 4 hours have passed. This technique helps to reprogram the electronics of the TV.
Hope this suggestion works for you.
Jun 21, 2008 | Mitsubishi VS-60607 TV
Vs-60607 brightness problems
This sounds like it is a problem with the tv. Mitsubishi does have a problem with filter caps in thier regulator circuits. A repair tech will have to fix it.
Mar 06, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Dark Screen and red and blue lines
Those lines tell me that you may have a leaky electrolytic capacitor in your vertical circuit.
Feb 10, 2008 | Mitsubishi VS-60607 TV
Black screen with green smiley face
If your tv has a picture tube,your problem is in it. If you have only one line now,the vertical circuit is not working. You could have jarred something loose around the picture tube.Maybe a yoke lead ???
Jan 13, 2007 | Mitsubishi VS-60607 TV
Mitsubishi VS-60607 TV Logo
252 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
