Question about Kitchen Appliances - Others
Nordyne intertherm mgha-056abfc-01 won't turn on...HELP!!!!
I have the above unit. the pilot light is working but the furnace is not kicking on. the fuses are fine and it is switched to heat
its freezing outside and i have 2 babies in the house what do i do???
meBNme
  • 334 Answers
SOURCE: Smell Coming From Intertherm Furnace
It could be several things.
The most alarming being a cracked heat exchanger allowing the exhaust fumes to enter the living space.
Exhaust fumes that contain carbon monoxide.
I HIGHLY RECCOMEND that you purchase carbon monoxide detectors, and/or check the batteries in any you might already have.
Carbon monoxide can be deadly at high concentrations.
It could be burning wires, but would smell like burnt rubber.
It could be mold/mildew but would smell musty like dirty socks.
It could be a build up of dust oil etc on the heat exchanger, but that is usually only smelled when it is started up for the first time in months.
Make sure the filters are clean. Dirty filters can cause overheating of the heat exchanger and sometimes cause smells.
This is one of those times I will recommend you have a professional look at your unit.
Specifically the heat exchanger to look for cracks.
A pro will know where to look, where the usual stress points are etc.
Posted on Dec 10, 2008
SOURCE: Nordyne LP Furnace wont fire
might be the flame sensor need replacing.
Posted on Apr 15, 2009
  • 136 Answers
SOURCE: the pilot lights on both furnace and water heater
have then replace your thermo couplers in them it'll solve your problem its a sensor for your pilots
Posted on Nov 25, 2009
lkh_cprr
  • 3 Answers
SOURCE: i have a intertherm gas furnace mgha-056abfc-01 the pilot light will not stay light.
If it's not the limit switch, perhaps the thermocouple or gas valve is defective.
Was there a gas outage?
Posted on Feb 24, 2014
I have a pilot light but furnace will not kick on,we replace control module but still will not kick on
your positive you have the gas turned on going to this furnas?
also make sure the power going to the furnace is on, it should have a switch with a fuse located close to it and the switch may be off or the fuse is blown out.
if so does the control valve have 2 wires going out to the t-state? if so for a test jumper those wires either at the furnas or at the t-state and see if the furnace turns on, don't forget to remove the jumper as the furnace will not shut off if you don't, this is just to test the wires and or valve.
Sep 27, 2017 | Heating & Cooling
Intertherm wiring diagram for model number MGHA-056ABFC-05
you have a 24 volt shorts check your thermostat wires to see if they are frayed or if they are touching anything. Check your outside wires also go to the thermostat.
Jul 12, 2014 | Intertherm Heating & Cooling
Nordyne furnace FEH017HA-04 the fan runs full force when the ac is on but half speed when the furnace kicks in
That is probably normal if it is electric heat to slow the air over the heating elements. Even some gas units do this. Check to see if the unit blower motor has wires for multiple speeds.
Oct 24, 2013 | Coleman Intertherm Nordyne Miller Furnace...
Where is the flame sensor on Intertherm MGHA-070abfc-01?
There is no flame sensor per se, unless it has an ignition type pilot. Only temperature activated switches employed.
The limit switch to the left of fan switch is "Nordyne" part #626259. This switch is rated at140 degrees. When the temperature inside firebox exceeds 140 degrees, switch "opens" removing power from the secondary of 24vac xfmr.
The fan switch to the right of the limit switch is "Nordyne" part #626337. This switch closes when firebox temp reaches 115 degrees. Opens at 70 degrees.
At the top to the left of fan is a smaller limit switch, which is a secondary safety switch. The increased temperature within the heat exchanger box activates this switch. It is wired in series with the thermostat wiring.
Hope this info helps.
Feb 05, 2013 | Intertherm Heating & Cooling
I have a intertherm gas furnace mgha-056abfc-01 the pilot light will not stay light.
Oct 24, 2012 | Heating & Cooling
Hi i have a york diamond heater in my attic. I went up in the attic and revomed the grill and the four burners are not coming on. it clicks and u smeal gas but it will shut off. the little blower motor...
If your furnace uses an electrical glow element to light the pilot light, the Glow Element will need to be replaced. Glow Elements are general used on 90+ High Efficiency Gas Furnaces.
If it uses a standing pilot light rather than the Electrical Glow Element, you need to manually relight the pilot. Since I can't see your furnace, you will need to locate and read your Owners Manual on how to do this or look in the side or inside the pilot light compartment for instructions on how to light it.
Be sure you have stick match or a butane grill lighter with you before you try to light it.
If it's a manual pilot ... if after lighting it, it doesn't hold when turned to the ON position, more thank likely you'll need to have the Thermocouple replaced.
And above all, BE CAREFUL. If you don't feel comfortable lighting a gas furnace, call a professional.
Feb 07, 2011 | Heating & Cooling
Kitchen Appliances - Others Logo
412 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
